Thread: Help for pansat 2500a |
New member Username: Teddyv
Post Number: 6 Registered: Nov-05
| Posted on Sunday, December 11, 2005 - 08:45 pm: |
can any one teach me how to find new key? so, I can help every body. |
Key Updates Unregistered guest |
| Posted on Sunday, December 11, 2005 - 11:44 pm: |
Download one of these Key Updater Program: http://www.keybin.com/modules/PDdownloads/visit.php?cid=107&lid=675 http://www.keybin.com/modules/PDdownloads/visit.php?cid=111&lid=474 |
New member Username: Ckwisi
Post Number: 1 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 12:01 am: |
hi everybody... i just need to know what do you put in STB model ???? |
| Posted on Monday, December 12, 2005 - 12:02 am: |
Put in the model of your receiver to flash a newer bin file. For example: Pansat 2500A |
Post Number: 2 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 12:09 am: |
i did but it says model does not correct |
| Posted on Monday, December 12, 2005 - 12:19 am: |
Type out exactly like this: Pansat 2500A or key:global
Post Number: 3 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 12:46 am: |
i did but still the same..........  |
| Posted on Monday, December 12, 2005 - 12:56 am: |
Make sure your Com1 in your device manager Baud Rate port setting is 115200. Check all connections. |
| Posted on Monday, December 12, 2005 - 01:09 am: |
This will give you a better understanding on Pansat 2500A. A Complete Guide for Pansat 2500a. javascript:View148('74'); |
| Posted on Monday, December 12, 2005 - 01:14 am: |
check out the file: Pansat_complete.pfd (www.dsscommunity .com/content.php?content.3)
| Posted on Tuesday, December 13, 2005 - 12:00 am: |
use this www.pantecf2a.com/Bangs_262p_v5c_limited.zip it autorolls. no keys needed. |
reciversha Unregistered guest |
| Posted on Tuesday, December 20, 2005 - 11:54 am: |
Hello everyone.... um... how do you guys enter the key for Pansat 2500A ?.. there is no such a thing as "enter the key" or "enter the code"? where to go from the main menu? :$ Thank you a lott
Gold Member Username: Thill1951akalk
Post Number: 1119 Registered: Oct-05
| Posted on Tuesday, December 20, 2005 - 12:14 pm: |
Its posted at every DSS site with files...U should join some...they are FREE.. For All Pansats -------------------------------------------------------------------------------- Press menu button on your remote: #1 Go to parental control... #2 Go down to "second pin" option & enter 0000 #3 Then go to nagravision and select it by pressing ok button on your remote... #4 In Nagravision window you should be in the box that is Entitled "Provider ID"...scroll to the right (press right arrow button on remote) until it switches to Dishnetwork (00 01) #5 Now In Nagravision window go down (press down arrow on remote) to the box that contains "00" entitled "Key Number" #6 While in the box (highlighted "Key Number") that contains "00", scroll to the right until you see nagravision 2 at the top left of your screen #7 While in Nagravision2 you should still be in "Key Number" box and the number in that same box should be "00"...this is for Key 00 #8 Scroll down (press down arrow on remote) to key data and enter the new supplied key for 00 (within this site is the key change for Nagravision2)..take note on how to enter letters in the lower portion of the screen (ex. letter E=FAV button on remote) #9 Once key is edited select OK button on your remote (OK-STORE confirmation blinks twice in lower right of screen) #10 go back to the "00" box and move one click to the right which should take you to "01"..this is to edit the "01" key #11 Follow Steps 8 & 9 above (this time enter key data for key 01 instead of 00) #12 Click exit and click ok or yes to save changes then exit all the way out and you should be watching tv Note...For /Bell keys at step #4, "Provider ID" is 09 - 01
New member Username: Clistenes
| Posted on Sunday, December 25, 2005 - 07:00 pm: |
i can't get the 110 sat with the new 267bin for 2500a. i need help please. |
osamabinladin Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 06:42 pm: |
this is clone ...made in stupid usa domp this junk ....only from Korea ara ok eny made in usa ...junk |
Bronze Member Username: Miss_nessa_905
Post Number: 12 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 07:00 pm: |
i can only put in one 00 and one 01 i cant put in 4 keys....plz help....rite now im using a pansat 2300A |
nordenstar Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 07:41 pm: |
p() f( S(((((((((((((( |
