Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Koolsat
Author Thread: Koolsat
Username: Sexton8
Post Number: 9
can anyone tell me how to enter keys on a koolsat reicever, also what flash should i use. thanks
dan tran man
use the latest bin that was release today.
Username: Sat
Y, Y
N
Post Number: 32
yes Key10...3D 73 19 22 27 5DC2C9
Key 11..97 96 5A 0C A5 79 27 F9
Key20..3D 73 19 22 27 5D C2 C9
Key21..97 96 5A 0C A5 79 27 F9
HAVE FUN PRESS 82 82
Username: Tnt
Sat: Do you have new key of koolsat4000???
killbillians
To correct the key change for 12-20-2005, you just need to change key 10 and key 11.
Go to channel 8282
Arrow down to appropriate line to edit key data.
Press OK for a keyboard to enter A B C D E F.
Press EXIT to remove keyboard and move to the next line to edit.
Be sure to save changes when you finish.
Key 10...AF 0C BD 48 D8 51 6D DC
Key 11...FE 44 D6 0C A3 6E 59 42
Key 20...3D 73 19 22 27 5D C2 C9
Key 21...97 96 5A 0C A5 79 27 F9
Jessica Notgniddaw
Thanks hope these work. Will try tonight when I get home, I have been searching for these all over the Internet.
thank you guy
Home > Message Board > Home Video > Satellite TV > Archive through December 23, 2005 > Koolsat [ « Previous ] [ Next » ]
