Thread: Sony RDR-HX1010 or Pionner DVR-930H-S, which one ? |
masquar Unregistered guest |
| Posted on Thursday, December 08, 2005 - 06:02 pm: |
Hi everybody , I would like to buy a good quality DVD-R. Which one will you choose or suggest among the two in the subject ? Thanks Massimo
Gold Member Username: Samijubal
Post Number: 1968 Registered: Jul-04
| Posted on Thursday, December 08, 2005 - 07:02 pm: |
I haven't used either one of them, but I've seen a lot more posts with Sony problems than Pioneer problems. I've also heard that Sony is using Samsung to manufacter their recorders these days, a very good reason to stay away from Sony if it's true. |
| Posted on Friday, December 09, 2005 - 03:57 am: |
Thanks a lot, David ! That was my idea too. Massimo |
Argenon Unregistered guest |
| Posted on Monday, January 16, 2006 - 05:36 pm: |
Actually I would rate Samsung products very highly, particularly DVD and memoery. |
Post Number: 2112 Registered: Jul-04
| Posted on Monday, January 16, 2006 - 06:16 pm: |
Samtrash is junk. My sister has one of their DVD recorders, she sent me a few discs recorded on it. On my JVC player they freeze at every new chapter and won't go past there till I press search twice, or press chapter skip. On my Panasonic DVD recorder, they freeze for a couple of seconds then jump forward. They are TY discs, so it's not the discs. Samsung makes some of the most unreliable electronics you can buy. |
New member Username: Mikedonb
Coventry,
RI
Post Number: 6 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 07:33 pm: |
Hey David, I'm also looking to buy a DVD Recorder. I do have a Samsung DLP HDTV and so far it's been fantastic. Is it just the DVD players from Samsung that you think are bad? Also, does anyone know if there is a good, reliable DVD Recorder that also supports HD Upscaling or should I buy a separate unit for that? |
Post Number: 2476 Registered: Jul-04
| Posted on Friday, March 31, 2006 - 03:26 pm: |
The Toshiba D-R5 upconverts through HDMI. I have 2 D-R4s, hands down best picture quality of any recorder I've seen. Virtually everything Samsung makes is problem prone. |
