Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Resolution question
Author Thread: Resolution question
Username: Balix
Hi, the specs i see on a panasonic edtv plasma tv is 852x480 so is that the best i can get when i connect my laptop or computer to the tv?
Ann Gelina
Yes. Whatever you send the tv will be scaled up or down to this native resolution.
Username: Rysa4
Post Number: 181
Yes. If you send a 1080i signal or 720 P signal to the ED plasma the internal scaler will downscale it to 852 x 480.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Resolution question [ « Previous ] [ Next » ]
