Thread: Vhs tapes to sony vaio |
New member Username: Akshaey
Post Number: 1 Registered: Apr-04
| Posted on Monday, April 26, 2004 - 12:13 pm: |
hello, i really needs some help. I recently bought a new sony vaio,. I later learned that my vcr could be hooked up to it, i tried but i could not get anything to play on my monitor. Can some one give me some details how to do so. Basically, what i want is: i have a few vhs tapes that i want to convert to dvd. So i guess if i can capture them into the memory of my pc, i can digitilize them. thanks |
New member Username: Bucketweet
California
Post Number: 4 Registered: May-04
| Posted on Sunday, May 16, 2004 - 12:39 am: |
I have a Sony Vaio as well. You first need to determine if you have any video software installed. I have the Gigapocket software package which allows viewing of a video signal through the inputs. If you have Gigapocket you should have no problem. Remeber that you will use up quite a bit of memory when recording to the hard drive. Just be sure you have enough memory. |
| Posted on Thursday, June 03, 2004 - 06:40 am: |
Hey what cable did you use to connect your laptop to your VCR? on my vaio i have a small yellow connector, the size of a 3.5mm headphone jack, so far i have not found any cable that seems to fit into this connection? i have brought a s video cable, maybe that will fit?! Any help will be nice! Thanks! Jamer |
New member Username: Xol
Post Number: 5 Registered: Jun-04
| Posted on Thursday, June 03, 2004 - 07:21 am: |
If your tapes are commercial ( for instance Disney ) you will have protection problem as well |
| Posted on Friday, October 15, 2004 - 07:29 pm: |
I had the same problem for a long time. I was so frustrated. Then I realized that I had plugged the video cables into the IN port of the VCR. IF it doesn't pop up in Giga that is what you might be doing. |
