Home > Message Board > Home Video > DVD Players > LG dvd models DV6812P and V8824W - code to make them region free? > Archive through May 15, 2005
Author Thread: Archive through May 15, 2005
I've unlocked our DVD player lg v8824w, and a million thanks for thatone, but still can't get it to recognise computer burnt cd/dvd's of downloads, anyone got any advice?
Relevant Product Info
Julia Munns
I have a DV2000 combined dvd/video and at the moment cannot get it to switch to dvd mode . When you try to switch it just shows vcr in display window and 'no disc' even when there is one in there !! .
Any ideas ?
ScottyEmmons
Hey, Guys with the 314159 code, how do u know it works, does it display a message? thanks in advance
andyq
Cheers guys, this is great
I HAVE PROBLEMS WITH MY DVD dc-596m for zone free code
Hello, can anyone help with an LG combo model LH-C6235?
hi, just tried the reg free on my v8824w i thinked it worked, the one dvd that has been copied from a o/seas dvd dose not work but my other dvds do so no harm done, but i am trying to get my new sanyo cp29af2x(a) to work from the same remote not having any luck can anyone help me? thanks
Username: Midman
Söderhamn, Hälsingland
Sweden
Hi
I dont know if anyone have seen the page for unlocking LG DVD:s?...i put it here anyway :-)
http://lgregionfree.tripod.com/menu.htm
It´s mostly for them who have a cd-burner in the pc but runs like clockwork.
Jola
Hi. All these LG models have different names in different countries. Can anyone tell if my swedish v8706 combo is amongst the verified models to survive AlexKKK´s cure? Some of you have described problems... (yes, I'm too chicken to just try:-)
Alnic
good site and good advice here people. I just used the code for the LG V782W (and others) to unlock my LG DK6922P.
Alnic
Sissi
Hello!
is there anyone here who kindly has some tips to unlock my LG RH 4820V dvd recorder with HHD, bought in Italy?
Many thanks!!
Silvia
Username: Haggis
Hi Guys, I have been trying to open the Zones on an LG DV8821P for days. LG gave me the 314159 code but it didn't work. Eventually joy by opening tray, pressing "000" for the menu then "0" for all zones, pause and power off. I hope this helps someone else
Sissi
Hi!!!
I have solved my problem!!
Here's the trick,it may help someone else!!
For LG RH 4820V dvd recorder with HHD, try this easy steps:
1. Power on
2. Open DVD tray
3. Press 7 times 0 on the remote control
4. You will see a "Now zonefree" confirmation message on the screen...Enjoy the best dvd recorder with no region limits!!!
Cheers,
Silvia
scutchwa
I've just used your code Alexkkk, thanks a million. I couldn't find anything for my player which is Lg DT-777w anywhere. Thanks mate
does anyone know how to make my lg dvd/video v8824w be able to change channels through the one remote?? i have misplaced my instruction manual
Alben
My dvd player plays black & white what should I do.
it playes all regions it is pal & NTSC system but I don't know the code or what can I do please help me.
thank you..
alben
ops model is LH-D6230
SORRY Thanks Alben
Hi There
i have the same problem as AVA..this was part of the reply "However, you need to make sure that your TV display can support NTSC. If not, you can check whether you can set the video output of the DVD to PAL, if so done, the US NTSC dvds will be converted by your dvd player to Pal signal and displayed on your Pal TV."
My old Dvd player had a switch on it to convert it to PAL..but my new LG v8824w doesn't seem to have one and it won't play certian copied dvd's on my teac ct-f6860s..can anyone help me with this..please..the tv manual says it does have ntsc playback..and i have my dvd player multiregion with the codes from this site, nut still won't play certian copied DVD's..sorry haven't got any US dvd to try it on and see if it plays them..or not...thanks
efro
Millie
THank you Thank you Thank you!!!!
I was unaware of the whole "region" business when I bought my LG V8824W recently. No surprise I was shocked and disappointed not to be able to play certain DVDs. But thanks the "magic" code I will be able to. So to whomever is responsible, again-THANKS!!!
Millie
I have a DVD/VCR Combo Player V8824W and I would like to use the remote to control my Sanyo CP29AF2 TV . The Sanyo code is not one listed in the owner's manual. Can anyone help me, please?
where can i get the software that unlocks dvd players?
Please help me! I´ve installed my new DVD LG DVX-8651C. Can you do it regionsfree? Im living in Sweden. Please help me.
Hi - can anyone give me the codes to make SAMSUNG DVD model DVD-P148 zone free?
Thanks!
Sebastijan Markovic, Kigali, Rwanda
Does anyone knows how to unlock the LG RC5900M
ok tnx man, worked on a lg dv8700H.
Can watch my canadian dvd's on my Dutch playa.
Oh yeah extra note: use the pause button on the player(not the remote) or else it won't work.
just some key words to help other people in google: dv8700H, telfort, dvd speler, aanbieding.
Ohh.. it was so easy! check otu www.videohelp.com awsome site for dvd-fix region free!!!
I´ve found my LG DVX 8651 fix for region!! Here it is! takes one second!!! JIHHAA!
LG DVX 8651
To set Region free:
- Open the tray;
- press 3 times the number 0 (zero);
it opens a blue and white screen;
- press 0 to set region free;
- press pause on the remote control to set the changes;
- close tray and switch off.
Now you can play it!!!
Dear All,
I have bought an LG DR4922W DVD recorder. Does anyone know how to unlock this unit so it can:
1. Play DVDs from all regions
2. Record video with NTSC format
Thanks
Richard
mab1009
Hi,
Please help. Have tried Alex KKK's 314159 tip and have found my country code in the setup menu has changed from UK to US even though i entered 0 for region free. My model is LG 5063. I have tried a region 2 disc and it still works. does this mean it has worked>
Does the unlocking CODE do any damage or create any OTHER restrictions once you punch it in? Can reverse this unlocking also?
Thank you.
Username: Little_angel
Hi I was wondering if anyone had the region free dvd code for Rowa RDV 750
Hi there,
I have a LG DVD, DS8421P, and its locked to region 5. Could anyone please hook me up with the code to unlock it. Thanks, Willy.
Hi there, I have a LG DV5612E I can't even know which region it's locked to. I'd like to unlock it, I have dvds from china and canada I can't see either of them.
kate
Please help, here is my email just in case yourananais@yahoo.com thanks in advance
elGuille
Hey guys it works great in a LG DVS-8521N
Thanks a lot!
Larga vida al rock'n roll!
Username: Bellasolang
Benin, Edo
Nigeria
This is the best thing that has ever happened to my `hi-fi` world.I bless the day i joined this forum
hoi
I have tried the code 314159 for my player (LG DV8700C) but it didn't work, so I tried something else and now my player is region free, i will tell you how i did it.
- turned on the player, no disk inside.
- opened the disk tray
- pushed 3 times the 0 button on the remote
- pushed the pause button on de player
- pushed the 0 button on the remote
- closed the dvd tray
- turned the player off.
now my player is region free.
I'm from Holland but i'm sure it will help others in other countries as well. Just try it.
Here another confirmation that the "alex" procedure also works for the LG DV8700H (Dutch model number; it is the one that plays DivX as well). Thanks for the good work!
Hello, does anyone know by chance how to unlock the region code for the JVC DR-MX1S DVD Recorder/Player
I just made my LG dvd player region free too!!!! Same code! Thanks xx
LUIS ABA
How to convert your LG DC-596M DVD/VCR combo player into a multi-region compatible machine
- Ensure that there is no disc in the player (ie: "no disc" is displayed – disc tray close).
- Using the Remote Control:
- Press PAUSE and
- Enter 314159 immediately without delay
- (You see in the displays FF)
- Enter the region code (0 for region free, or 1-6).
- (You see in the displays 00 for region free)
- Press PAUSE
- (You see in the displays no disc)
- Turn the player off for a few seconds.
- Turn the player back on
- Ready
Username: Totallyclueless
Anyone know how to crack the DVB418?
I just tried the hack by AlexKKK on my LG V8824W and it woked first time. You are all doing great work here. Keep it up!
Hayrulla
Attention to those who have LG DV-3781 please visit web site and select LG 6000 series for instructions. http://lgregionfree.tripod.com/menu.htm
And to those who have LG LX56320 (micro hifi w/ DVD) please:
Open tray
Press PAUSE
As soon as you see PAL/NTSC/AUTO press zero three times.
You see interface and press zero one more time to make your DVD region free.
Press PAUSE to exit
Here it goes!!!
Please how to convert LG dvd/vcr VC8706V in multiregion mode
geof
I have tried to change my LG V774W dvd/vcr region from 4 to 0. When i use the method that requires "no disc" then enter "pause" then enter "314159" then "0" for all regions then "pause" etc... it doesn's seem to be doing anything. The "no disc" is displayed throughout the whole process. Can someone help?
Username: Smeghead
Hi I just got a LG Portable DVD player dvp7772 and Im trying to get it region free. The 314159 thing doesnt seem to work any other ideas??
Ivo
Hello, I need an advice how to unlock DVD player LG make, model DVD-6044/6045. Thanks
P.S. the method "314159" doesn't work.
laputa
alexKKK.. i've just unlock my LG DvD player.. and it works!!! thanks alot! now i can watch any DVDs now... =) you are the man!!
claire
Wonderful!!
Used hack for LG dvc 8700 - quick, easy and it works!! thank you
Username: Shank1230_1
Dartford
England
Can anyone show me the process to make a Phillips R70 DVD available for all regions , will be for ever grateful
basic
Thanx you guys for your pst in this forum!
I need a help for my DVD/VCR player, the model is: DVC 5930
Wills
Hi guys & Gals,
Any one know how to get the codes for the TV IE: Mitsubishi would love it if some one could work this out that way I can use just the one remote
Regards Wills
Mr V Man
hi Guys, LG DR4922W region free hack is the same as the DR-6921
1) Press setup on remote control
2) Move down to the "lock" picture
3) Press "0000000"
4) Press Yes
Got my player today, used the above and played discs from all zones perfectly.
Rachel Cakes
success! i just used the unlock code (provided by AlexKKK the second post on the top of this page) on my australian lg V8824W vcr/dvd combo, and it worked the first time! thanks :-) now i can watch dvds from the usa :o)
HI IT SEEMS IM THE ONLY ONE WHO HAS AN LG DC593W,
DOES ANYONE KNOW THE UNLOCK CODE..
MY EMAIL IS normr@iprimus.com.au.
Marv
hey, does anyone can unlock lg gcc-4521bbu?
I've already buy a LG DVD Recorder with the reference DR-4912M ( NTSC) and it comes to Region 4 only, and i need it to be "Region Free". Anyone can help me to solve that problem? thanks a lot in advance .
pleeeease help me unlock my lg DS8451ECA.it was manufactured April 2004.i want it to play all region
pleASE with LG 6054 FREE REASON.PLSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
please help i live in US i have LG6184 got it from my niece as a gift i tried to make it as a region free didnt work also a need to reset the factory codes because i messed up the audio is way behind pleeeease anyone can help meeee.... thanx Alex
Top of pagePrevious message
