Thread: DVD and HD-Ready TV |
Chenoweth Unregistered guest |
| Posted on Saturday, November 26, 2005 - 08:11 pm: |
Hey, I just purchased an HD-Ready TV for my room, it supports 480i, 480p, 720p and 1080i. I have a Progressive scan DVD player+VCR. The TV Came with component cables (red, green and blue) - I want the best picture possible, should I hook up the dvd player via the component cables or s-video? |
Gold Member Username: Samijubal
Post Number: 1923 Registered: Jul-04
| Posted on Saturday, November 26, 2005 - 08:28 pm: |
Component, you can't use progressive scan with s-video. |
| Posted on Sunday, November 27, 2005 - 01:50 pm: |
Well there may be something wrong with this DVD player, because between interlaced and progressive, it looks the same. |
New member Username: Yenery
Post Number: 2 Registered: Dec-05
| Posted on Sunday, December 04, 2005 - 10:28 pm: |
I believe your case might be similar to mine. I have a Panasonic PT-43LC14 TV(HD Ready) and a Toshiba RD-XS32SU DVD Player connected via component cable. I can only watch 480p although both DVD player and TV supports 720p. I have no idea why it does do that. |
| Posted on Sunday, December 04, 2005 - 11:10 pm: |
yener yar have you gone into the setup of the dvd player and changed it to do progressive scan. if it is a half decent dvd player it will push 1080i |
Post Number: 3 Registered: Dec-05
| Posted on Sunday, December 04, 2005 - 11:44 pm: |
Steve, that's what I believe, I paid a lot to this DVD player and the component cables aren't cheap too. But the manual doesn't say too much about a progressive scan setup. There is a Progressive Button on the remote and it does switch to Progressive mode when clicked. But always 480p when pressed. I have read the TV's manual, DVD players manual and couldn't figure out what's wrong. If it can't be done, waste of money for me. |
Bronze Member Username: Nik3
Sacramento,
Ca
Usa
Post Number: 35 Registered: Nov-05
| Posted on Tuesday, December 06, 2005 - 07:24 am: |
just a 1 thing to say realy is that i think its time for all of us to move on to HTMI & DVI conetions. |
Sacramento,
Ca
Usa
Post Number: 36 Registered: Nov-05
| Posted on Tuesday, December 06, 2005 - 07:25 am: |
in the next year or so your gona see nothing but HTMI on the back of the dvd players componet is a thing of the past |
