Home > Message Board > Home Video > Satellite TV > Archive through November 25, 2005 > Help with parental control-Cas System...
Author Thread: Help with parental control-Cas System Munu
Username: Abjack
Hi, Just trying to set up a 3500 via SD card. When I go into parental control, I can't get to the second PIN in order to enter the Cas system menu. I would appreciate any help as I've been searching for 3 hours now and can't come close to a fix.
Thanks in advance
Letmeon
1668 or 0000
Username: Spank
Post Number: 319
Have you put the latest bin for the 3500 on your unit yet?
Home > Message Board > Home Video > Satellite TV > Archive through November 25, 2005 > Help with parental control-Cas System... [ « Previous ] [ Next » ]
