Thread: Dish 500 w/ DishPro Twin |
poor soul Unregistered guest |
| Posted on Wednesday, November 23, 2005 - 10:16 pm: |
I just got heritaged the Dish Pro Twin (Black label DP in the back) but not sure how to use it. This is all I know: With this dish, I believed that I can hook up to 2 receivers, catching 110 and 119 without using the Diseqc because each line carrires both signals. I would like to be educated how to set up this dish with my 2700A. Any help is appreciative |
Silver Member Username: Spank
Post Number: 317 Registered: Oct-05
| Posted on Thursday, November 24, 2005 - 12:25 am: |
Diseqc settings: Port 1 to 119 Port 2 to 110, run cable direct to each receiver, get a dishpro channel list. |
| Posted on Thursday, November 24, 2005 - 09:32 am: |
I do not have Window XP in my computer; therefore, I can not use the Channel Master to edit the channel list. After scanning the both satelites, I have to edit the channels directly with the receiver. So, what are the set-up procedures that I need to know ??? .... Please ...
Silver Member Username: Thill1951akalk
Post Number: 842 Registered: Oct-05
| Posted on Thursday, November 24, 2005 - 10:08 am: |
Go to ANY other DSS site and Read the Pansat 2700 setup guide there...and do a blind scan instead of using channel lists.. |
Save the Turkeys Unregistered guest |
| Posted on Thursday, November 24, 2005 - 01:41 pm: |
what is the differance between a blind scan and a simple channel scan? Thanks  |
| Posted on Thursday, November 24, 2005 - 02:36 pm: |
Blind Scan is a feature commonly known in the MPEG-2 industry as "Blind Scan" and called "SMART SEARCH" by the PANSAT people. This is one of the tools available for the do-it-yourselfer to initially locate and eventually identify unknown signals. Great feature when Dick is moving channels around on transponders! |
