Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > Help Me Please HDTV Problems
Author Thread: Help Me Please HDTV Problems
Username: Shrimpboat
I recently bought a xbox 360. I wanted to hook it up to my big screen in HD well I got all the cables hooked up and configured and when I turned it on it comes up but only in green but it looks good. HHEELLPP
Username: Wildbear6
thats like me, I have an Atec AV320W HDTV. when I use the xbox360 in standard tv mode using either YRW (Yellow, Red, White) and if I use scart its fine. BUT when I try it in HD mode, using wither VGA or RBG (Red, Blue, Green) my colour is all messed-up, wither to pink or to green and I cant change it much no matter what I do with the colour, contrast,ect.. settings for the tv. Have you had any luck in finding what the problem was?
Username: Cabletech
Post Number: 7
The cable that you are using should have 3 main colors, red blue green and 2 for audio red and white. there is a possibility that the green and blue are backwards.
Username: Cabletech
Post Number: 8
Also you may want to check to see if there is a setting in the xbox that may need changed to an HD setting.
Username: Mistrmike
Well... This sucks, I just bought a xBox 360 aswell. Not cool. Im getting awesome 1080dpi jet im only getting greens, blues, and a lil yellows. This is not a uncommon problem so im gathering and would like to do without a $150 service call. Shoulda bought the ext. warrenty i guess. Please if anyone knows of a quick fix please, plesae respond.
Username: Mistrmike
P.S. I have running >> JVC HDTV 48" 1080 dpi component out >> Standard and varified working component xbox cables >> xbox 360
Home > Message Board > Home Video > HDTV Reception > Archive through November 02, 2006 > Help Me Please HDTV Problems [ « Previous ] [ Next » ]
