Thread: Signal Quality 119 & 110 |
New member Username: Bozza
Post Number: 5 Registered: Oct-05
| Posted on Sunday, November 20, 2005 - 12:46 pm: |
When adjusting the dish and looking for signal quality for 119 and 110 which TP I should look under to get the best signal?
Letmeon Unregistered guest |
| Posted on Sunday, November 20, 2005 - 12:50 pm: |
almost equal on all , mostly middle ones. some will be zero between 2 good ones. trial and error......... |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 662 Registered: Oct-05
| Posted on Sunday, November 20, 2005 - 01:06 pm: |
@Igz A weak TP would be only specific to your area, some TP's are weak on the east coast some on the west. |
Post Number: 6 Registered: Oct-05
| Posted on Sunday, November 20, 2005 - 11:27 pm: |
thanks |
