Thread: Digiwave7000 Time Settings |
digiboy Unregistered guest |
| Posted on Thursday, November 17, 2005 - 06:17 pm: |
I installed the latest file but the time in the egp is wrong. ie IT's 6pm and the time says 1pm??? |
Bronze Member Username: Cmoore
Windsor,
Ontario
Post Number: 23 Registered: Nov-05
| Posted on Thursday, November 17, 2005 - 08:21 pm: |
You gotta go in the menu and set your clock. Look for "Time Adjust" |
| Posted on Friday, November 18, 2005 - 05:01 pm: |
If you mean the GMT setting i have done that. The local time is correct but the time above where it show what time the program starts and end is wrong? Is anyone else having this problem or is there something i'm doing wrong? I located in the eastern time zone so i set the GMT to -05:00. Anyone have any suggestions? |
Windsor,
Ontario
Post Number: 27 Registered: Nov-05
| Posted on Saturday, November 19, 2005 - 11:40 am: |
In your Time Adjust Menu: Set Local Time = 0:00 Summer Time = OFF Year = 2005 Month = Nov Date = 19 Hour = "Your Time" (Mine is Military) 12AM = 00:00 12PM = 12:00 1PM = 13:00 11PM = 23:00
Silver Member Username: Thill1951akalk
Post Number: 773 Registered: Oct-05
| Posted on Saturday, November 19, 2005 - 12:32 pm: |
GMT and military time are the same..all based upon Greenwich England which is ZULU time related.. |
| Posted on Monday, November 21, 2005 - 01:29 pm: |
@ cmoore Can you tell me which file you're using so i can hopefully get the problem resolved. |
Windsor,
Ontario
Post Number: 28 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 07:42 pm: |
@digiboy The file is Called DIGIWAVE FIX.zip which includes:CasLink_v1.11.exe Channel List.txt Digiwave Nosing manual update key features.bin FtLink3.01.exe Read me 1st.rtf Softcam.key I used FtLink3.4 to load the bin only. Loaded my own Channel List. In Menu: System Settings: go to Key Editor: find Nagra 2, not Nagra 1, 0001 DishNetwork, and enter current Keys together in 1 string on Key00 line. Go to Time Adjust and set as above. F29874441C6577D817E3E11D894E5345
