Home > Message Board > Home Video > DVD Players > Archive through December 25, 2005 > Any way to get a Hdmi upconverted sig...
Author Thread: Any way to get a Hdmi upconverted signal to a TV without HDMI or DVI?
Username: Catcher12
Is this possible? I see AV receivers out there that have HDMI inputs and Component outputs would this work? Th eset I have supports 1080i. Any input or sugestions would be appreciated.
Thank you,
Jack
Praetorian
you can send an upconverted signal through component, apparently it is not as clear as through HDMI/DVI. Your hardware has to be configured for it though. The LG Up Convert DVD player is set up for it, roughly $200, I have not searched the market for alternatives since this is what I already have.
orion
The upconverting Samsung hd-841 can give real 1080i through a component connection. You need the special ANGLE code and then it upgrades beautifully...verified using resolution screens from Digital Video Essencials.
Home > Message Board > Home Video > DVD Players > Archive through December 25, 2005 > Any way to get a Hdmi upconverted sig... [ « Previous ] [ Next » ]
