Home > Message Board > Home Video > DVD Recorders > Archive through November 29, 2005 > DirecTv/Tivo to Sony GX315 problems
Author Thread: DirecTv/Tivo to Sony GX315 problems
ratm
Hey all,
I recently bought a SonyGX315 recorder and have it properly set up. When I record something, no matter what it is, I can play it on the same machine without any problems. I beleive this is when I am recording in "VR" mode. When I try to record in "video" mode, I get the annoying copyright protected box and it stops. This only happens on movies that I TiVo from the DirecTv, ie., IRobot or Bourne Supremacy. When I want to record kids program like the Wiggles, it gives me no problems. Please help!!!
Thanks
Matt
Username: Samijubal
Post Number: 1881
It's the copy protection the premium channels are using. Record straight to the Sony and you'll be fine. The quality will be better anyway.
ratm
Dave,
Thanks for the quick reply. What do you mean record straight to the Sony?
Matt
Username: Samijubal
Post Number: 1887
Record straight from Direct TV to DVD, not TiVo then DVD.
ratm
then how would i use the tivo?
Username: Samijubal
Post Number: 1903
Use the TiVo for stuff you don't want to put on DVD.
Home > Message Board > Home Video > DVD Recorders > Archive through November 29, 2005 > DirecTv/Tivo to Sony GX315 problems [ « Previous ] [ Next » ]
