Thread: Pansat 2500 A Bin256 gone by Friday |
its true Unregistered guest |
| Posted on Wednesday, November 16, 2005 - 02:16 pm: |
The new program is out |
New member Username: Keithm2223
Greenlawn,
Ny
Post Number: 3 Registered: Sep-05
| Posted on Wednesday, November 16, 2005 - 10:53 pm: |
where can i download the new bin file for Pansat 2500 A |
Silver Member Username: Thill1951akalk
Post Number: 734 Registered: Oct-05
| Posted on Wednesday, November 16, 2005 - 11:33 pm: |
READ and U will find...in less than 1 minute |
ThrillsAfag Unregistered guest |
| Posted on Sunday, November 20, 2005 - 08:42 pm: |
Thrill your a fuking turd |
Silver Member Username: Timscarlet
Dayton,
Oh
Usa
Post Number: 149 Registered: Feb-05
| Posted on Monday, November 21, 2005 - 12:01 am: |
GET YOUR RECEIVER MAILED TO YOUR HOME, FULLY LOADED WITH NAG2, CHANNEL LISTS, READY TO WATCH TV, THIS SITE IS ONE OF THE ONLY SITES THAT DOES THIS!! PANSAT 2700'S, PANSAT 3500'S, COOLSATTS, VIEWSATTS, FORTECS. ALL OF THEM FULLY LOADED, READY TO GO! http://www.bestftafiles.com/pansat2700order.html |
bestftafiles sux Unregistered guest |
| Posted on Monday, November 21, 2005 - 01:30 am: |
Tim that site you posted has adware and viruses, are you nuts |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 675 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 01:51 am: |
He didn't JUST post, it's his site and this is his nonchalante way of spamming. Tim at least pay someone to redesign that POS, try to make it look like it's an actual ecommerce site, look at the page title, IT'S A FRIGGIN "PAGE TITLE"! make an effort. |
| Posted on Monday, November 21, 2005 - 07:09 am: |
of course this is my site, and there is no adware, its a domain name i got, and there is no spyware, adware, how stupid can you get? without knowing chit? where else can i put this site in a forum, an ecoustics.com forum, its easy. |
New member Username: Coco11676
Haverhill,
MA
Usa
Post Number: 1 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 06:54 pm: |
Can any one help me with my Pansat 2500A (not a clone) I have put every bin on my system from the orginal pansat 222-236, and then tried the 255, 256, 257, 258 bins. I'm not sure what i'm doing wrong? I set default keys. I have done a bind scan got T5, echo6,8, with quailty 87% level 84%. I have put channel list on, and blind scan. scambled channel, and the F___ $ signs. on every channel, please help!!! |
Silver Member Username: Spank
Post Number: 302 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 07:05 pm: |
When you are saying you set default keys, please explain a little further - just curious to make sure you are doing the right thing.
Haverhill,
MA
Usa
Post Number: 2 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 07:18 pm: |
I set the key on after I have put on 258 bin, then added a channel list, when that didn't work i then loaded then 258 bin again and set default keys. If this doesn't help then, could you tell me what to do after i put on the new bin and set default keys, do i load a channel list or scan for channels?thanks for any help you can give me. |
Post Number: 304 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 07:24 pm: |
I am just trying to make sure you are not actually manually entering keys. You should just be going into the CAS Menu and hitting "Set Default Key"- I think it is the last option in the menu (I don't own a 2500). For the channels, it is your choice if you want to scan or get a list, just make sure you get or make the list that correctly matches your setup ie. Dishpro or Legacy. |
Haverhill,
MA
Usa
Post Number: 3 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 07:34 pm: |
I click on (set Default keys) button. I have a legacy dish. If i do a scan what do i do with the list after? Do i have to open it in Gtools to get the $ sighs out? what do i do after the scan? thanks |
Post Number: 305 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 08:32 pm: |
No the $ signs indicate if it is an encrypted channel or not. Turn to the free stations like ch.101, or GOL(ch.407) are they coming in? Where are you getting your bin files? |
Haverhill,
MA
Usa
Post Number: 4 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 08:49 pm: |
yes they are coming in (the free channels) I tried files from differenet sites. DssCentral, (a17bar), (dssftp.com), I got the 258 bin from the last two sites. any thing so far that you see i'm doing wrong? I just loaded the 222 bin then reloaded the 258 bin, now what do I do? this is where i'm going to stop, please let me know what to do next. Thanks |
Post Number: 306 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 09:35 pm: |
Blind Scan, then Set Default Key. That should be all you need to do. |
Haverhill,
MA
Usa
Post Number: 5 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 09:59 pm: |
i did a blind scan and got T-5/ku, then set keys, got nothing scambled channel only. Sould i scan in under the echo 7, or should the blind scan have picked it up? I get quality 79% level 79% on echostar 8,6, and 7 and T-5\KU, well thats what the machine says. I only have a 18" DirecTV dish with one dual LMB with one cable directly to my receiver. I have a Pansat diseqc switch but it not hooked up. can you think of anything? |
Haverhill,
MA
Usa
Post Number: 6 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 10:05 pm: |
I just did a scan on echo 7 and found 320 channels and then reset keys again. I only get the free channels. |
Post Number: 823 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 10:07 pm: |
corey... 1 dual LNB = 1 satelitte and 2 outputs for 2 receivers 1 twin LNB = 2 satellites and 2 outputs for 2 receivers SO your dual LNB can only get either E7...E6/8 or T5...but NOT all 3 satellites |
Haverhill,
MA
Usa
Post Number: 7 Registered: Nov-05
I get the radio channels, but scambled channel on every thing thats not free |
Haverhill,
MA
Usa
Post Number: 8 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 10:22 pm: |
I know but why I'm i getting singnal from all three? from quality & level. |
Greenlawn,
Ny
Post Number: 4 Registered: Sep-05
| Posted on Monday, November 21, 2005 - 10:43 pm: |
Any luck finding solution Cory? I have the same problem too. Let me know what's the solution. |
Haverhill,
MA
Usa
Post Number: 9 Registered: Nov-05
| Posted on Monday, November 21, 2005 - 10:46 pm: |
not yet i set my receiver to echo 7 110, but it shows levels 78% and 82 quality. but nothing but $ next to the channels but i can see free channels and most audio. |
Post Number: 307 Registered: Oct-05
| Posted on Monday, November 21, 2005 - 11:47 pm: |
Try this: reset to factory settings from setup menu, then load this bin: http://www.future-fta.com/forum/showthread.php?t=6 . Now put this bin on: http://www.future-fta.com/forum/showthread.php?t=5876 ,now blind scan, then set default key. One more thing : Echo 6,8 is 110 and Echo 7 is 119. Which one are you pointed at? |
New member Username: Thrill_is_gay
| Posted on Tuesday, November 22, 2005 - 01:12 am: |
hey dickwad spanky...why don't you run along and start whining to the admin that I am posting again...I'm sure he wants to hear from a fcuking little twirp who has nothing better to do then fcuking whine about a brother who tells it like it is...fcuking dumbazz...ROTF |
| Posted on Tuesday, November 22, 2005 - 02:26 am: |
So did you get it yet as I have the same issue? Been looking for the answer |
| Posted on Tuesday, November 22, 2005 - 02:36 am: |
I hate to be annoying myself, but I've spent a good while searching this forum and I still can't find a link to the new bin. I wouldn't normally be asking, but ftacentral uses some stupid adware ridden site to host their files. The site tries to use activex - and linux doesn't react well to that =P. A point in the right direction anyone? |
HönkyÐ!©k¹ Unregistered guest |
| Posted on Tuesday, November 22, 2005 - 05:48 am: |
Bend over "thrill_is_gay I have a flag pole with ur no life looser name on it.. |
Haverhill,
MA
Usa
Post Number: 10 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 11:26 am: |
i did what you said, pansat 2500A file, then 258bin, then blind scan, got sat T-5/KU, does this mean wrong sat? set key, nothing. i think I'm picking up the wrong sat. but when i first setup i got all goos signals level, and quality. |
Bronze Member Username: Coco11676
Haverhill,
MA
Usa
Post Number: 11 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 11:28 am: |
if i do a scan on echo 6,8, i find channels? not a blind scan. and get a good signal |
Post Number: 685 Registered: Oct-05
| Posted on Tuesday, November 22, 2005 - 12:14 pm: |
@corey You'll have to realign your dish to whatever sat you're trying to catch. @m1nd dsscentral .net |
Post Number: 828 Registered: Oct-05
| Posted on Tuesday, November 22, 2005 - 12:37 pm: |
here is the latest Pansat 2500 bin for genuine Pansat 2500's,not CLONES.....released 20 Nov...get all the Pansat genuine files at www.future-fta.com.. Pansat 2500A Updated Release Ver.258 -------------------------------------------------------------------------------- Updates are 1. Nagravision 2 Keys EDIT 2. Closed Caption Improved, Option to On/OFF 3. Timing has been changed to AM/PM Enjoy Regards Blacklist Attached Files X-85BL_051120_258_api(N).zip (352.4 KB, 2690 views)
Haverhill,
MA
Usa
Post Number: 12 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 01:09 pm: |
i'm trying to catch sat 6,8 echo 110, I got good singnal levels, but when i do a blind scan i only find T-5/ku, i'm i not at the right dish? If i can only find T-5/ku can i get anything on this sat? with the 258 bin |
Haverhill,
MA
Usa
Post Number: 13 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 02:04 pm: |
I only picked up T-5/ku channel info reads(BellexpressVu) DFreq 11754 named sat<. |
Post Number: 309 Registered: Oct-05
| Posted on Tuesday, November 22, 2005 - 03:50 pm: |
Did you do a factory reset before installing the bins? When I asked if you were getting the free channels did you check ch407 GolTV? That one is specific to 110 and you would know if you are at least aligned properly. |
Haverhill,
MA
Usa
Post Number: 14 Registered: Nov-05
| Posted on Tuesday, November 22, 2005 - 09:07 pm: |
i'm getting CHANNEL $9 NFLSP free, ch 61 Vu free, 138 MCTV, 139 CBCa, 142 CBCA, 143 OMN1, 144 MCTV, 145 FREEP, 146 FREEp, 147 GAME, 148 XPRS, 149 BRKR. The channels go from 1-366, what satellite am i on? please help. |
Post Number: 311 Registered: Oct-05
| Posted on Tuesday, November 22, 2005 - 11:26 pm: |
Sounds like you're pointed at one of the Nimiq sats(Bell). Did you use a look angle calculator to point your satellite? - And did you do a factory reset before you put those bins on? |
Haverhill,
MA
Usa
Post Number: 15 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 09:48 am: |
i used this site for my calculator, i have a 18" legacy dish came with a directv package. but i didn't know what calculator to use because there are two to choose from. http://www.kusat.com/go.php?path=/install/look.php check out this site and let my know, or could you give me a better site? yes i did a factory reset. |
Post Number: 312 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 10:17 am: |
You could compare your look angle to the one given at the site below to check if it matches up. Pick Echo 6/8 and either pick a city close to yours or look up your latitude and longitude and enter them in. http://www.satellitenut.com/calculators/SatelliteHeading.html |
Haverhill,
MA
Usa
Post Number: 16 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 11:09 am: |
what do i do with the lnbf polarization tilt skew, do i change the skew in the settings? do i tilt the lnb? my lnb is attached to the arm. |
Post Number: 313 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 11:43 am: |
No, the skew is for other types of dishes. You just look at elevation and azimuth. |
| Posted on Wednesday, November 23, 2005 - 12:56 pm: |
hey spanky, I have a channel data file how do i install that on the reciever? |
New member Username: Ck1n4l
| Posted on Wednesday, November 23, 2005 - 01:02 pm: |
I accidently hit the factory setting button on the remote and now I can't get the channels that I was, after doing a blind scan. Plus, when I pull up the installation menu I have alot more satellites listed than just the 2. What do I need to do to correct this. Thanks! PS:I got the recvr from someone else |
Post Number: 314 Registered: Oct-05
Use channel master. You can get it here: http://sharpc.dyndns.info/CM/Update.aspx What receiver do you have? |
Post Number: 315 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 01:04 pm: |
The Channel master post was for Anonymous. CK14NL - What receiver do you have? |
Post Number: 701 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 01:30 pm: |
Sounds like a pansat, he probably had a channel list with just 110 and 119, then did a factory restore and now has...well what he has . |
| Posted on Wednesday, November 23, 2005 - 04:26 pm: |
I have a pansat 2700A. What can I do to reset it to get what I was? Only picked up T-5/ku when I did a blind scan. Do I need to have it redone with a download? |
Post Number: 702 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 04:48 pm: |
@CK1N4L What's your setup, ie dish, lnbs, switches? |
