Thread: Help with Connection |
New member Username: Jan21
Post Number: 1 Registered: Nov-05
| Posted on Sunday, November 13, 2005 - 02:23 pm: |
Just purchased an Insignia DVD Recorder and am having trouble connecting the TV to the cable box to the DVD recorder. Would appreciate any input, thanks. |
Gold Member Username: Samijubal
Post Number: 1856 Registered: Jul-04
| Posted on Sunday, November 13, 2005 - 03:04 pm: |
Connect the cable box to the recorder with s-video or RCA cables, and set the recorder on whatever input you used. Connect the recorder to the TV with, in order of preference, component cables, s-video, RCA cables. Then set the TV on whatever input you used. If using component or s-video, you still need RCAs for audio. |
New member Username: Dakota05
| Posted on Thursday, November 17, 2005 - 04:34 pm: |
I too just bought a DVD-R120 Samsung along with a Sony Wega HD TV. The cables from the DVD are connected to HD/DVD on back of the TV. The TV is also connected to a cable box and the box is connected to a VCR. My problem is that when I go the the Video 5 screen on the TV, it shows 'no signal'. I disconnected the cable from the VCR and then connected it to the DVD, but I still receive 'no signal. In addition, I put a disc in the player and didn't have sound. This is my first DVD and Im at my wits end. Can u help me?
Post Number: 1895 Registered: Jul-04
| Posted on Thursday, November 17, 2005 - 05:15 pm: |
Connect the DVD to the TV with the triple component cables for video and the 2 RCAs for audio. Use the progressive scan on the DVD for better quality video. Connect the box to the recorder with s-video or RCA cables and set the recorder on whatever input you used. If using s-video, preferable, you still need RCAs for audio. |
Unregistered guest |
| Posted on Monday, December 12, 2005 - 11:29 am: |
I have purchased the insignia DVD recorder/vcr combo and am trying to connect it to a television and my Bose stereo system. The TV has a million input positions and I am just lost. The cable system does not have a box, so that everything runs throught the TV, not a cable box. I have tried several connections, but cannot get the TV or DVD to play through the audio on the Bose. Help!! |
| Posted on Wednesday, December 14, 2005 - 01:36 pm: |
Please help. I am new to all this stuff so bear with me. I am having trouble hearing my audio on both TV speakers when I want to record a VCR tape to my DVD recorder. I hear both speakers on the right and left on the VCR imput channel but when I go to Video 1 (DVD imput) and record off the VCR, I only hear the right speaker on the TV during DVD playback. (all equipment is Sony brand and brand new) TV is HD. I do have the split Y wire to the two left and right plugs for audio and have the output(back of VCR) and imput (in on front of DVD recorder)for the yellow (video) and audio R&L plugs. It's an old plug, red and black but I do plug in the red one to the red jack. The VCR is new and has stereo selected in the audio setup. Why is this happening? What am I doing wrong? Thanks for your help. |
rosendo Unregistered guest |
| Posted on Wednesday, December 14, 2005 - 07:01 pm: |
i have a cable box and a vcr hooked up and they both work and i want to install a dvd player but i need help. |
| Posted on Sunday, January 08, 2006 - 01:13 pm: |
I just installed insignia on our Tv and everything is working but when I playback something I have recorded, the recording timer appears on the top left of the screen. How can I get rid of it ? I've looked everywhere on all menus, setup and edit sub menus and basically punch every possible button on the remote but to no avail....help anyone ? |
sherchat Unregistered guest |
| Posted on Thursday, January 12, 2006 - 04:22 pm: |
Sofee - you can turn off that timer by using the OSD button on the bottom right of your remote - you may need to push a few times as it has 4-5 views that it will show.. |
Bruce Robinson Unregistered guest |
| Posted on Tuesday, February 28, 2006 - 08:25 pm: |
I bought an Insignia DVD recorder, and connected it to our Motorola DVR via a s-video cable. I connected the DVD to my TV set. The video signal passes through the DVD recorder fine and is visible on the TV set. But after I insert a DVD disk, set up recording parameters, and press the record button, I get a "recording prohibited" error message and no recording is made. Same error messages when I ran through the first 30 cable channels and on a half-dozen programs recorded on the DVR. What now? |
