Home > Message Board > Home Video > Satellite TV > Archive through November 25, 2005 > Fortec Users Read This.
Author Thread: Fortec Users Read This.
Username: H3lt3r_sk3lt3r
Post Number: 437
Here's a c&p from al7bar that might help you:
"Lifetime Ultra NTSC. If you read and do all of this you will have less questions at the end.
Use a STRAIGHT THROUGH CABLE RS232C hooked up to your receiver from the computer. Take the cable off going to the LNB.
If you have the year model Dec 2004 or 2005 receiver then you may need to use a USB to Serial cable 26-183 at Radio Shack. Get detailed instructions here http://www.beaglesoft .com/232usb.htm
Download Al7bar FTA Ultra 050926 282t3_12H_clock api(NTSC).zip
You can get it here http://forums.al7bar .tk/showthread.php?t=113827
Download to your computer Blacklist STB UPDATER.ZIP It don't ask you as many questions.
You can get it here http://forums.al7bar .tk/showthread.php?p=300891#post300891
UNZIP both files. You can use WinZip or Winace.
You can get them here http://www.winzip.com/ http://www.winace.com/
Click on UPDATER.EXE to start it.
Set the COM PORT and put a dot in BIN.
Click on BROWES then put in Al7bar FTA Ultra 050926 282t api(NTSC).bin (note it is a bin)
Turn receiver on from the back, when FIRST bar starts then click FIX on your computer.
After you get compleat on the computer the ON will display in the receiver, then it will displays a channel number if you have channels in your receiver. Your receiver is flashed."
Username: Coolie11
@h3lt3r_sk3lt3r
I tried the links you listed above but they said page cannot be displayed
Username: Reach_honey
@h3lt3r_sk3lt3r
I uploaded with loader all i get it Scambled or Bad signal.
Post Number: 439
@coolie11
delete the space in between the site name and .com or .tk
Username: Coolie11
@h3lt3r_sk3lt3r
It's the same
Username: Coolie11
@h3lt3r_sk3lt3r
any surgestions?
Post Number: 443
@coolie11
The al7bar servers are overloaded right now, that's why you get the time out error, keep trying.
Username: Coolie11
@h3lt3r_sk3lt3r
thnx
Username: Coolie11
Post Number: 7
@h3lt3r_sk3lt3r
Is it possible for you to e-mail me the files?
Post Number: 444
@coolie11
Sorry dude I don't want my email (even if it's a dummy one) to be out in public.
Just keep reloading the page, I just got through I'm sure you will too.
cool hand luke
again iam asking, i just got a
lifetime ultra receiver. i have
a bin file that says this.
ultra-050926-282napi (ntsc)
(11-7-05)-zip i have never
done this before could someone
tell me step by step what to do
or print it out for me.
Post Number: 446
@cool hand luke
Why don't you read the very first post in this thread, if you still need help I'm sure Kneegrows might help.
WHAT WE HAVE HERE IS FAILURE TO COMMUNICATE
A Kne-grow (31-4 skins) told me you are the best
for helping others out....How do I get my new
lifetime Ultra receiver working using 050926-282
ben file...Could you print it out step by step
for me.....This Silly Thilly punch woun't or
can't do it because all they do is bash people and eat SPAM with chimp sh*it in it....Kne-grow
I think they are all full of spam chimp sh*it and
their eyes turned brown because they are full of
SPAM Chimp sh*it and a quart low....(He-Ha-He-Ha)
Post Number: 453
hahahahaha Kneegs can't get his POS fortec to work hahahahha damn Kneegs for someone hanging around DSS board you sure are one dumb psycho ba$tard, sorry I mean chimp banned douche bag hahahahahah
MR CHIMP sh*it
(31-4skins)-You are right....Iam only a chimp...
I got a excuse, whats yours?...O I
know, you have being eating to much
SPAM with chimp sh*it in it....Thats
why you are acting like us....Did you
grow a tail yet...ROTF
Username: Thill1951akalk
Post Number: 571
The admins/mods here are the troublemakers...after last night,can't U see that!...the admins/mods were not here helping...and neither were the troublemakers!...they are one and the same people!
h3lt3r_sk3lt3r
YOu.............
ARE Awesome!!!!!!!!!!!!!!!!!
Post Number: 459
Yes kneegs and it's a fine one too, I turn channels with it, even enter new keys hahahahahah tooo bad your as$ got baaaanned hahahahaha
Post Number: 461
@Anonymous
Uuuuhhh you're welcome......? :-)
Username: Patches
can someone just email me the fortec files (zipped) since I can't download them anywhere...all sites are busy..
patchkoho2@aol.com
thanks
Username: Whatzzzuppp
Montreal, Quebec
Post Number: 8
thnxxxxxxxxxxxxxxxxxxx any way
am try 2 figure it out cause i have no idea what u wrote to be honest with u mrrrrrrrrrrrrrrr
h3it3r-sk3it3r
stop pulling my leg
WHERE IS THE BLACK LIST UPLOADER!!!!!!!!!
WHAT A BUNCH OF CRAP, NO BLACK LIST!
Post Number: 483
@stop pulling my leg
Why don't you calm down first, and not blame others just because you are TOO LAZY to look.
Go to this thread and look at Spanky's post:
http://forum.ecoustics.com/bbs/messages/2/173780.html
coldgirl
I tried your fix above and it says write failed. I have used blacklist stb updater v3.21 and fortecstar stb updater v3.21 (flash update failed) your 282 fix and 276 fix. any other suggestions?
Username: Prfrmnj
Post Number: 24
Coldgirl - What operating system do you have on your PC? If it's WIN2K it won't work. You need either ME or XP to flash.
coldgirl
Just downloaded windows XP Professional yesterday before I started all this. Tried before with Windows 98SE and it didn't work. The port setting should be at 115200, which I changed on the device manager. But when I go to system information and to the port setting the Baud rate for com1 is on 9600. Could this be my problem?
Post Number: 488
@coldgirl
Don't change any settings the bits per second in com1 properties in device manager should be 9600, you might however try switching to a different com port in the loader, also try shutting down any antivirus or firewalls running on your pc.
And are you sure you have the right cable? it should be straight-through for fortec ultra.
Username: Prfrmnj
Post Number: 25
coldgirl - If you are using the Blacklist Loader, you do not need to change anything and as far as the baud rate on your pc is set by the device manager so that's not the problem.
I agree with h3lt3r, sounds like a cable problem.
Username: Konfused
Post Number: 9
so what is the scoop with firtec ultra
is anything working or not?
Post Number: 504
@Kon Fused
everything is up and running.
Username: Konfused
Post Number: 10
huh!
thanks h3lt..
will try in the evening n let everyone know
keeping fingers crossed!
south asian boy
hey guyz i need to know how to flash a bin for my fortec reciever but its really a pansat clone can u plz tell me ??? and if u could also tell me which bin to download im really new to this stuff !
coldgirl
I went to a friends house and tried to download off his computer with my cable. Flash failed. Hooked up his computer and it worked. How come they give you cables with the receivers that don't work.
HOT-AZZ
-You didn't bend over far enought to let him
smell your fur-burger coldgirl....He wanted
to give you the long stroke....ROTF
Username: Spank
Post Number: 234
Coldgirl, depends where you buy it. A lot of the dealers are known to give you the wrong cable. At least you got it working and now know what cable to use in the future.
Username: Konfused
Post Number: 11
guys
other than this bull crap bingo site http://forums.al7ba, is there any other site from where i can download the patch for fortec?
have been trying to register for the last bl**dy one hour but that site is slower than a snail
Post Number: 513
@Kon Fused
dsscentral .net no need to register.
Username: Konfused
Post Number: 12
thanks again h3
you are very nice indeed
the file names at the dss are a bit different than what is mentioned in 1st port in this thread
any idea if they are still the same??
Post Number: 525
@Kon Fused
There should be a short description to the right of the file name, it tells you whats in the new bin.
Once you unzip it, the bin should have the same name as one above.
You might also want to check here:
http://www.curious-contraptions .com/forums/forumdisplay.php?f=9
cold-b1tch
A spanky, whats up....Do you want some of coldgirls fur-burger....For get it boy....Its
pushed so far back in her azz o that she as a
set of tail-lights....You would be one of many
many, many dick-s boy....You are dum...ROTF
barbspeaking
I would like to flash my fortec ultra lifetime back to factory settings....is there a bin for that or is it something you do with your remote? I have a fortec lifetime ultra that didn't take the bin right and the menu seems messed up - it keeps going to 'language' whenever I try to exit the menu. Would really appreciate a little help. Thanks in advance!
FTACENTRAL DOT COM
DSSCENTRAL DOT COM
AND OTHERS
new_to_fta
I just flashed a fortec receiver with the bin file "Al7bar_FTA_Ultra_050926_282_api_NTSC__11_7_05". The channels work fine, but the receiver does not seem to respond to the remote. Is there something else I need to do? I'd appreciate all the help. Thanks.
I need the dish setings for my fortec ultra
echo 7 and echo 6.8 [110 ;119 ] skew and horizontal. Toronto ont.
Username: Prfrmnj
Post Number: 32
Change the batteries on your remote!
Username: Wazup
I have a Fortec Star Lifetime ultra and one DISH pro 500 antenna towards 110 and 119, How could I hook another receiver using the same antenna?
And
When I disconnect the box, for the occasional upgrade, and I connect it again it completelly looses the 110 channel. The signal stength is looks good but I get not signal. Then a couple of days or weeks later image could be seen on the 110 channels, Is that normal?
Thanks
wazup
Username: Wazup
And
When I disconnect the box, for the occasional upgrade, and I connect it again, it completelly looses the 110 channels. The signal stength looks good but I get not signal. Then a couple of days or weeks later image could be seen on the 110 channels, Is that normal?
Thanks
wazup
Username: Sonirohi
I just installed Fortec Ultra using single LNB to a Echo 3 61.5 satellite. I am not getting any channels. My receiver has:
AI7bar - 2.81t, Boot version 6.0 dated Sept 26, 2005. The signal strength is 75%.
When I do Power scan it says 0 Transponders found.
Thanks
Username: Prfrmnj
Post Number: 34
@Rohit - Load Bin 282t.
Home > Message Board > Home Video > Satellite TV > Archive through November 25, 2005 > Fortec Users Read This. [ « Previous ] [ Next » ]
