Thread: Unlock code for Alba DVD59 |
New member Username: Luciane
Post Number: 1 Registered: Nov-05
| Posted on Tuesday, November 08, 2005 - 02:33 pm: |
Does anyone know the code to unlock the Alba dvd 59?? It should be multi region but it is not. |
| Posted on Monday, November 21, 2005 - 03:00 pm: |
ALBA DVD59 press open/close once press prog once press enter 3 times using up/down buttons select region 0 then press stop to confirm it has just worked for me |
Unregistered guest |
| Posted on Friday, November 25, 2005 - 02:40 pm: |
Thank you. That code worked like a dream straight away. |
| Posted on Saturday, November 26, 2005 - 07:09 pm: |
Thank you so much, ive had like a fewq U.S dvd's that never worked untill now, you rule  |
