Thread: LG rh7500 timer problems |
New member Username: Andy_franks
Post Number: 2 Registered: Nov-05
| Posted on Monday, November 07, 2005 - 07:07 pm: |
Has anyone here had problems with the clock on this model I noticed that the clock had stopped and when i change the time nothing happens the only way it works is when i unplug it from the wall and start it up again ..... |
Unregistered guest |
| Posted on Friday, December 23, 2005 - 01:18 pm: |
my problem with the timer is that the recorder only allows 16 recordings despite the large hard drive space. HELP |
ChrisFlynn Unregistered guest |
| Posted on Sunday, December 25, 2005 - 01:24 pm: |
Andy - I think the unit needs to be in Standby for the timer to work (press Power). Jacob - that's the max number of timers allowed! (See manual) |
| Posted on Monday, January 16, 2006 - 03:01 pm: |
My LG RH7500 is 2 weeks old and for the last week has `Please Wait` scrolling across the display.Despite trying to reset the unit as the instuctions and disconnecting from the wall I have had no luck.Does anyone have the answer before I take it back to Currys. |
New member Username: Donut
Post Number: 1 Registered: Feb-06
| Posted on Monday, February 06, 2006 - 07:01 am: |
I have an LG 7400 recorder which will only record the first programme despite the number of programmes it is set to record. Once it has recorded the first programme it finalises the disc. Any ideas? |
| Posted on Thursday, February 16, 2006 - 03:23 pm: |
Manual SAYS after setting timer to record to HD or DISK [insrt disk first] PRESS THE POWER BUTTON ONCE to put the unit in STANDBY !!! read manual !!! p42 point 6 !!! I know it's stupid , TIMER only while unit is in STANDBY ==================== RECORD TO HD not DVD blank !!!!! then burn later at high speed !!! dub> fast
