Thread: Nag2 FIX, new keys. |
Kash123 Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:05 am: |
For thill or any I tried exactly same way as thill said on fortec, but still not working, what to do now? |
Bronze Member Username: Mty
Mexico
Post Number: 67 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 01:12 am: |
I HAVA PANSAT 2500 A WITH A BIN 255. WHAT BIN DO I NEED TO HAVE TO MAKE IT WORK |
Peter Bob Smith Unregistered guest |
satlover - are the steps the same for 3500? |
Mexico
Post Number: 68 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 01:14 am: |
KUK WHAT DID YOU DO? |
| Posted on Tuesday, November 08, 2005 - 01:25 am: |
http://www.fsfta.com/viewtopic.php?t=1087 it work |
New member Username: Trucker
Post Number: 8 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 01:26 am: |
if you have a fortec star liftime ultra, the keys won't work. they are working on a new bin at this time. but if you want to watch tv right now. go to pantecdvb.com, upload pansat/pantec clone patch file, dated 07-11-05 to your fortec. you now have a pantec receiver. note you have to go into parental control to turn the key function on and off. the menus are laid out little different. this worked for me, all channels working. make sure you take the time to read the posts on pansat clones. |
ijerkoffwhenitype Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:29 am: |
vince2422 turn off your diseq switch when doing a new scan |
imjerkingoffwhenitypethis Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:37 am: |
Also my peeps please read and accept this n2 no more key changes its all about the bins holmes like the good ole Dave days yall member yo had yo loader cleaned yo card loaded the latest bin yeah all about the BINjamins!!! |
Super-X Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:38 am: |
http://news.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=504358#POST504358 Patricia, what you have should work. did you go to parental control screen - second pin - enter 0000 - then go to nagravision - scroll to dish network and enter keys for 00 and 01. then exit out. then instead of nagravision choose "set default key". press that several times and then exit out. all my channels came in when I did that! |
Vince2424 Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:39 am: |
ijerkoff when i do that I only get those 3 stupid channels and nothing else, i'm trying to get the channels on echostar3, do you what the antenna settings should be |
Jolisma Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:42 am: |
What's working for Pansat 3500?? Anyone?? please help!!! |
Mexico
Post Number: 70 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 01:45 am: |
SUPER X WHAT BIN DO YOU HAVE? |
imexhausted Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:46 am: |
LyngSat.kum does |
| Posted on Tuesday, November 08, 2005 - 01:48 am: |
Hello, I've uploaded bin file in to receiver and works great with 2500A. Didn't have to enter key or anything, no scan or nothing just upload bin file and ready to watch!! Though, keys are not same as listed on this page. I thought bin file should have same keys that are some people entered manualy by hand. does anybody know why? Good luck too all. |
New member Username: Tomtom
Post Number: 1 Registered: Nov-05
| Posted on Tuesday, November 08, 2005 - 01:49 am: |
Okay guys and gals. If you still got stuck here is a fix for 2500A. 1. First you need to download bin 256 (255 and below will not recognized Nagra 2) 2. Write down this code (from expert in here and they are: Key 00: F2 98 74 44 1C 65 77 D8 Key 01: 17 E3 E1 1D 89 4E 53 45 3. Apply bin 256 to P 2500A, and GTools local channels. 4. Connect P 2500A to TV and ready to enter keys just like usual, except for to select Nagra 2 instead of regular Nagra 5. - The first 4 digits stay the same at 0001 (for Dishnet, some recommended to use the menu buttons to select Dishnet instead of enter code 0001) - The next 2 digit numbers are enter diferently from before. Once apply bin 256, now you have an option to go to Nagra 2 menu and there are 2 set of numbers you need to enter. Nagra2/00 and Nagra2/01 - Select Nagra2/00 enter the code above,store, then do the same with Nagra2/01 (code above), and store. 6. That's it. Hope it works for you as it worked for me. Thanks all for the help Tomtom, |
New member Username: Lude
| Posted on Tuesday, November 08, 2005 - 01:50 am: |
what are the key for Fortec lifetime ultra, do u have to get a new bin, is that the only way? |
Mexico
Post Number: 71 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 01:53 am: |
ANONYMOUS WHAT BIEN DO YOU HAVE? |
ifeelgreat Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:54 am: |
maybe its because the keys don't matter see A Few Good Men "YOU can't handle the TRUTH" |
Post Number: 2 Registered: Nov-05
| Posted on Tuesday, November 08, 2005 - 01:56 am: |
what do u gotta do to watch tv right now if u have a fortec lifetime ultra?? |
imgettingsomenachos Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 01:57 am: |
Patricia http://pentiger.kom/BL255c-11-07-05-fix.bin change the 'k' |
Post Number: 3 Registered: Nov-05
| Posted on Tuesday, November 08, 2005 - 02:00 am: |
and that won't screw up the fortec reciever?
what'sup Unregistered guest |
http://pentiger.kom/BL255c-11-07-05-fix.bin (notice: kom should be replaced by com) once you load this file in 2500A it will run 100% not need to add any keys and not need to scan.
| Posted on Tuesday, November 08, 2005 - 02:01 am: |
how do i do BL255c-11-07-05-fix can anyone show me, is bin file i do not know how to do it,thanks |
Post Number: 4 Registered: Nov-05
| Posted on Tuesday, November 08, 2005 - 02:02 am: |
do u load the bin with the same fortec lifetime updater |
New member Username: Zzgoocean
| Posted on Tuesday, November 08, 2005 - 02:03 am: |
how do i do BL255c-11-07-05-fix can anyone show me, is bin file i do not know how to do it,thanks i have coolsat4000 |
ialmostdonewithmenachos Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 02:10 am: |
rich blacklist STB updater my sat scans are done everything back to normal not a bad little bin "Thanks Paine Webber"
New member Username: Wishfultnkn
Post Number: 4 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 02:20 am: |
All you C00lsat testers, READ THIS THREAD!!!http://forum.ecoustics.com/bbs/messages/2/173780.html The fix is available now!!!! |
imtiredturningofmecomputer Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 02:22 am: |
program guide on this bin is cuckingfrap but channels change FAST fareheit 911 in on sho-w |
| Posted on Tuesday, November 08, 2005 - 02:33 am: |
Works for pansat 3500 S If you do not see the Nagravision 2 after clicking right twice while in the key number then make sure you have the latest BIN first. I've used UMNov's post above to edit for the pansat 3500S MY UNIT IS PANSAT 3500S -------------------------------------------------------------------------------- Guys: 1) Go to menu 2) Go to Parental controls 3) Select Second Pin 4) Type in 0000 5) Select default key 6) Then select nagravision 7) Use volume Right Button until you see "Dish Network" at the top (I think you'll push volume RIGHT 2 times) (Note: if you do not see it after 2 Clicks, check your BIN, you need 119) 8) Channel down once to select "key number" ***While on KEY NUMBER ***YOU MUST PRESS RIGHT, RIGHT to get to NAG 2 ***Postion 1 is dish key 00 NAG1 ***Postion 2 is dish key 01 NAG1 ***Postion 3 is dish key 00 NAG2 ***Postion 4 is dish key 01 NAG2 9) "key number" 00 should be set to: F2 98 74 44 1C 65 77 D8 10) Press OK to Save at this point "key number" 01 should be set to: 17 E3 E1 1D 89 4E 53 45 11) press ok (VERY IMPORTANT) 12) press exit all the way until you get back to watching TV (no need to shut it off)
NeverEndingStory Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 02:41 am: |
HEY FORTEC FOLKS!! It's finally not so busy on the other sites that I've been able to login and confirm a few things.... NO MATTER WHAT, YOU NEED THE NOV 7 BIN FOR FORTEC!!! I'll test it myself tomorrow (when I get the damned cable I loaned to a buddy lol) but you can't get N2 key change capability without this bin! I'm not sure which is best for who owns what, there is a revised 282 bin at Al7bar and then there's the bin linked by Spanky FTA in this thread as well. Even if I haven't tested it myself, I've heard enough to know we can all make it work with the new bins...it's a question of if you have/need to use a Pansat clone file or an original Fortec fix and which updater to use...the Lifetime Updater or the BL Updater... |
| Posted on Tuesday, November 08, 2005 - 02:44 am: |
hi guys i feel kindda stupid by asking this question. But how do i apply the bin that i downloaded to my pansat 2500a. Please help |
| Posted on Tuesday, November 08, 2005 - 02:45 am: |
That is correct, everyone will need the Latest BIN for their unit regardless if it's Fortec or Pansat. This should be a given during any changes to bring their unit up to the latest bin's.
New member Username: Zamzoom
Post Number: 1 Registered: Sep-05
| Posted on Tuesday, November 08, 2005 - 05:39 am: |
HOW ABOUT PANSAT 2700E IT DOES NOT HAVE NAGRA1 AND NAGRA2 ON THE TOP. 2700A WORKED 2700E DIDNOT WORK. I NEEED SOME HELP PLEASE. |
| Posted on Tuesday, November 08, 2005 - 07:11 am: |
Guys, I entered the keys in my Fortec lifetime Ultra but It didn't work. help. |
New member Username: Kojack
| Posted on Tuesday, November 08, 2005 - 07:32 am: |
Thanx guys, the keys work fine. What i found out is that you can mistake the d8 for DB, that was my problem, thanx again |
| Posted on Tuesday, November 08, 2005 - 07:33 am: |
Oh, by the way is there any word on BEV ? |
dikncider Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 07:36 am: |
For Pansat blind peeps, when in nagravision 2 you will see it on the top left of the menu, duh |
| Posted on Tuesday, November 08, 2005 - 08:00 am: |
how do i set the numbers and letters for the keys? |
| Posted on Tuesday, November 08, 2005 - 08:18 am: |
how do i change the numbers and letters using the remote? |
New member Username: Latin
Miami,
FL
Post Number: 6 Registered: Sep-05
| Posted on Tuesday, November 08, 2005 - 08:44 am: |
Pansat 2700)I push RIGHT after 01 in Nagravision, but I'm not seeing anything indicating that I'm in Nagravision2. |
| Posted on Tuesday, November 08, 2005 - 09:03 am: |
Good Morning! I have a Pansat 2500A clone. Can anybody confirm the working bin file for this machine. thank you |
Post Number: 3 Registered: Sep-05
| Posted on Tuesday, November 08, 2005 - 09:04 am: |
PANSAT 2700E IS NOT WORKING. NOTHING SHOW BESIDE NAGRAVISION ON TOP LEFT. USUALLY IT SHOW 1 OR 2 WITH 2700A RECEIVERS. ANY TALENTED GUYS COULD HELP US THANKS |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 404 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 09:06 am: |
@Al39 It's already been confirmed and working a couple hundred times. @DAN Did you first flash your receiver with the 118 bin? |
Bronze Member Username: Homer_simpson
Post Number: 13 Registered: Sep-05
| Posted on Tuesday, November 08, 2005 - 09:18 am: |
Posted instructions for Pansat 2500 and clones here http://forum.ecoustics.com/bbs/messages/2/173890.html I'll be at Moe's |
Silver Member Username: Thill1951akalk
Post Number: 557 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 09:26 am: |
U must use the latest bins...256 for 2500...118 for 2700...and then if U can't do it,throw away your receiver and subscribe!..The How To is posted here 1000x and also in the "latest keys" thread!...can't spoon feed everyone...U MUST read and follow VERY simple instructions...Pansat and Viewsat N2 key changes are cake!...This is TESTING,so TEST! |
New member Username: Rossyjess
Post Number: 1 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 11:11 am: |
Hi guys if you want to fix pansat 25000 or clones just follow the instruction to change a N2 from thill1951 i Just made and works |
theidiot Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 12:47 pm: |
so you need another device to change the bin for 2500a? |
Post Number: 412 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 01:09 pm: |
@theidiot Not another device, you need to flash your receiver with a 256 bin to get to the n2 keys screen. |
Silver Member Username: Spank
Post Number: 214 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 01:12 pm: |
Almost 250 posts in less than a day. And still, they are down.... |
New member Username: Jm_luciano
Cabo Rojo,
Puerto Rico
| Posted on Tuesday, November 08, 2005 - 02:20 pm: |
Hi guys, I'm new working with my pansat 2700a and I need to Know what can I do to see all the chanels because my dauther use the control and I see only some . I want to see USA in the 105 but I can't. Please somebody let me know. |
| Posted on Tuesday, November 08, 2005 - 02:24 pm: |
Can the Nagra 2 file open SkyAngel channels to on EchoStar 3? |
22tango Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 02:31 pm: |
i downloaded BL255c-11-07-05-fix yesterday, on my pansat 2500, and it is working, but i didn't get any N2 screen to change the keys. i got the sameone from before. Will autoroll work with this bin? |
Cabo Rojo,
Puerto Rico
| Posted on Tuesday, November 08, 2005 - 02:37 pm: |
where can I check this. |
| Posted on Tuesday, November 08, 2005 - 03:52 pm: |
i've been looking and i can't find the 256 bin could someone please point me in the right direction |
andiemom Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 03:53 pm: |
my pansat is working. thank you. For everybody else, here are some suggestions before asking for help. 1. read this thread 2. read another thread 3. read this thread again! For heavens' sake, if i can do it, so can you. You should not even have to ask for the new keys. They are posted everywhere on this site. Read! If after entering the keys, and still nothing, then you probably need a new bin. Again they are posted everywhere on this site. Read! If you don't know how to change a bin, (like I did), this site will point you to some good info, you need to read, read, read. Finally, if nothing work for you, maybe you are not meant for FTA and should probably go back to subscribing to directv or dishnetwork.
| Posted on Tuesday, November 08, 2005 - 03:59 pm: |
I have had my Pansat 2700A for only a couple of weeks. I understand that I have to downlaod a new bin in order for the new keys to work . I was wondering if someone would be so kind to tell me where to go to download this new bin and also do i need any sort of program to install it in my receiver ? Thanks |
Arsalan Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 05:01 pm: |
Hey guys u are doing fantastic work here but still i have a question in this whole thread every body point out intstructions for every receive except of FORTEC ULTRA LIFE (FTA) please for god heavens write the step by step instruction for FTA Ultra, also like if there are no keys for FTA how could we use this bin stuff i don't really know pleaseeeeeeeee... you smart guys help me out i don't even have the cable that connects my receiver to computer so i could download that bin stuff please help me out also with which cable is it and how to do it thanks a lot for all your help once again u guys are great but need to do little more work on FTA *** Just to remind u that if I didn't got any help I have to pay $50 dollars to fix thix FTA and work it back so please i request u please help me out with FTA*** |
| Posted on Tuesday, November 08, 2005 - 05:25 pm: |
Everyone wants a QUICK and INSTANT FIX....Do your homework first and then ask for help. If you can't figure the basics out yourself...then hire someone or buy a subscription. Be grateful that all this information is free. You buy a receiver for less than 200 dollars and expect everyone to spoon feed you. Grow up!!!!! |
| Posted on Tuesday, November 08, 2005 - 06:28 pm: |
They sell those cables for cheap on eBay Arsalan, like the post before don't expect to be spoon fed. I'm very new to this, about a week into it. That's what the World Wide Web is for, search & you'll find anything. Go to FTA forums & use their search feature. Some of us have real lifes you know, we can't be here all day telling you a step by step. Grow up, & good luck! |
Bronze Member Username: Geeker
Post Number: 42 Registered: Nov-04
| Posted on Tuesday, November 08, 2005 - 06:48 pm: |
chespirito, sorry for the long wait. But to check wich bin you have on the 2700A, press menu then then highlight "system information" that will the bin ver. I am almost certain if you were watching tv before this key change, you would have XBL 1.17 or XBL 1.18. Let me know if you need more help. |
| Posted on Tuesday, November 08, 2005 - 07:00 pm: |
i need the fortec keys plz
New member Username: Stilltrying
North Carolina
| Posted on Tuesday, November 08, 2005 - 07:03 pm: |
I have the pansat 2700A and the key are in the N2 and the keys are correct. I have tried the 117 bin and several 118 bin files. I have followed the direction closely. They work just like the direction say up until it is time to watch tv but no tv. Even loaded down a 118 with key already loaded. Still no luck. I have tried for a day and a half. Any help would be appreciated. Thanks |
QUICK-eeee Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 07:07 pm: |
QUICK-I will take my quick-e now, just bend over While I Butt fu@k you right now while you wait....ROTF |
Post Number: 447 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 07:08 pm: |
@T. W. Williams After you load the 118 bin (and 118 only) you HAVE to enter the n2 keys. |
Post Number: 43 Registered: Nov-04
| Posted on Tuesday, November 08, 2005 - 07:10 pm: |
twwilliams, do you have signal and a channel list loaded, or have scanned your receiver after loading the 118 bin? |
| Posted on Tuesday, November 08, 2005 - 07:22 pm: |
Can anybody plz post the new bin and keys for fortec, thnx a lot |
Bronze Member Username: Barabashka
Post Number: 32 Registered: May-05
| Posted on Tuesday, November 08, 2005 - 07:30 pm: |
HI ANY NEW BINS FOR PANSAT 2700A????   ::::  ( |
Post Number: 33 Registered: May-05
| Posted on Tuesday, November 08, 2005 - 07:31 pm: |
-------------------------------------------------------------------------------- MY UNIT IS PANSAT 2700A -------------------------------------------------------------------------------- Guys: 1) Go to menu 2) Go to Parental controls 3) Select Second Pin 4) Type in 0000 5) Select default key 6) Then select nagravision 7) Use volume up until you see "Dish Network" at the top (I think you'll push volume up 2 times) 8) Channel down once to select "key number" ***While on KEY NUMBER ***YOU MUST PRESS RIGHT, RIGHT to get to NAG 2 ***Postion 1 is dish key 00 NAG1 ***Postion 2 is dish key 01 NAG1 ***Postion 3 is dish key 00 NAG2 ***Postion 4 is dish key 01 NAG2 9) "key number" 00 should be set to: F2 98 74 44 1C 65 77 D8 "key number" 01 should be set to: 17 E3 E1 1D 89 4E 53 45 10) press ok (VERY IMPORTANT) 11) press exit all the way until you get back to watching TV             :  : |
Post Number: 456 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 07:34 pm: |
@Umnov@msn.com Are you asking and answering your own questions :/ ? |
Bronze Member Username: Pentiger
Post Number: 17 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 07:45 pm: |
I noticed some channels missing already today, -outdoor life network,HGTV, E!, Style and many more It's such shame that some of us were not able to get the yesterdays keys to work and today they start again. |
| Posted on Tuesday, November 08, 2005 - 08:02 pm: |
HGTV, E! and Life working fine on the West Coast. |
Angel_RG Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 08:10 pm: |
Get up & running with the latest N2 bin in 20 steps. I am a newbie, and on Monday 7th Nov 05 when all went down I did my homework to get things back up and running. Over a 5 hour period I read many forums, some ppl gave better instructions than others, but I did see a lack of clear instructions so many of us require. Here is my attempt: 1) First and foremost. I have a Pansat 2500a. This is a cloned Pansat. To find out whether yours is a clone visit http://www.fsfta. com/viewtopic.php?t=179 (remove the space). This site requires registration. Regisitration is free. The following instructions are for a cloned Pansat 2500a. 2) The reason some of you cannot enter N2 codes in manually is because you do not have a recent bin file. (A bin file is a binary file containing codes etc allowing us to watch satellite for free). I had a 251 bin and just like some of you could not find Nagravision 2 no matter which way I pressed the volume key. 3) How do you know the version of the current bin on your receiver? Press Menu, scoll down the System Information. If the current version of the bin has been given a meaningful name you will some some numbers in there to the effect 251a, 255, 256 or 248, or 224. 4) If you do have later version of a bin such as a 255 or 256 bin, you can enter the keys in manually. Clear instructions for that are in this thread 5) If you cannot enter N2 codes manually you need to find the latest bin and download it the receiver. And this is what I describe below: 6) Before you can download anything to the receiver you need a RS232 serial cable (straight cable not a crossed cable). You cannot proceed without this cable. 7) Then you need to locate the latest bin file. I went to www.fsfta .com (remove the space from the Web address). You first need to register (this is free). Then click on the link "Pansat 1500/2500 11 7 2005 New Keys Added No Kill". The first post on the first page has the file you need to download, namely X-85BL_051107_256_api(No-Kill).rar. (X-85 means for the Pansat 2500a, 051107 is YYMMDD for the date, and No Kill means the harmful code that kills Pansat clones has been removed). 8) It is a .rar file (which is basically another form of zip file). This cannot be unzipped by WinZip. Google a freeware unzip utility program. I used "Unzip them all" found on www.sofotex .com/UnzipThemAll-download_L9182 .html (remove the 2 spaces). 9) Once you've download the unzip utiltiy, Unzip the .rar file and you should get the bin file: X-85BL_051107_256_api(No-Kill).bin. To make sure their was no corruption in download. This file will be 640KB in size. 10) You then need a program to upload the .bin file from the computer to the receiver. There are a few Uploaders (aka Updaters) mentioned on these forums. The one I used was Blacklist STB Update v1.4. This can be found at http://ftajackass. com/html/index.php (remove the space). Click on the link Downloads. Then scroll down to subcategory "Pansat Free to Air Files". Then click link 2500a. Download Blacklist Bin Updater. Unzip the file. 11) Ok, now get back to the TV. Click Menu. Scroll down one to Parental Control, and press the OK button on the remote. Scroll down to the Second PIN and enter 0000, and click OK. Go down the Set default key, and click OK. (Some may say this step is not necessary but if you have been messing around trying to enter keys manually, then this will read the keys from the .bin you currently have installed. Like I said don't know if this is necessary but its what I did.) 12) Click Exit and number of times till you come out of all the menus. Now switch off the receiver from the switch on the back. 13) Connect the one end of the RS232 cable to the computer, and the other end to the back of the receiver. Load up the program Blacklist updater on the computer. (I disabled my wireless internet access at this point to avoid any mishaps. Wired users can disconnect the network. This is one of those steps some may say not necessary but I did it anyhow. Those of you with heavily guarded ports and firewalls may have extra problems. Turn them off if you can). 14) On Blacklist set the Comm setting to COM1 (this is default, select a different COM if req'd). Click on Select Bin, and locate the .bin file where you unzipped it to. 15) Switch on the receiver. Once the KnightRider lights have done there bit (horinzontal scrolling dash), then click on Write Bin. The .bin file is now being uploaded to the receiver. The number on the front of the receiver will match the percentage complete on your PC screen. 16) Blacklist will prompt Complete when it reaches 100%. Disconnect the RS232 cable from the computer. The receiver will have now done an automatic reset/reboot. 17) The TV screen will still read Scrambled or Bad channel. Don't panic! I also got this. Click the Menu button on the remote. Scroll down one to Parental Control, and press the OK button on the remote. Scroll down to the Second PIN and enter 0000, and click OK. Go down the Set default key, and click OK. (This step makes the current N2 keys that you just uploaded as the default keys in the receiver). 18) Click Exit a number of times to get out of all the Menus. You should now have a picture. This new bin file will also allow you to enter N2 keys in manually later on if req'd. I won't cover 'how to' on that, I think others have made good attempts at explaining that one. 19) I hope this info helps. The only credit I deserve is in taking the time to write this thread. The ppl doing the real work are the ones that write the bin files. I say a heart filled thank you to them. 20) God bless. |
| Posted on Tuesday, November 08, 2005 - 08:18 pm: |
dave tester from years back here- i agree- read read read- but one question- whats the life expectancy o these updated bins? like the old days? 3 days-, a month- 6 months if your lucky? |
Post Number: 18 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 08:23 pm: |
andiemom, those channels don't work here, I just checked with my friend. Is here someone from the eastcoast who can confirm watching the OLN, E!, Style? Thanks. |
Post Number: 569 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 08:27 pm: |
If U are from the Dave HU days then U know thats a dumb question..I had files that lasted 3 days and 1 that lasted 11 months (my own written)...they all varied...generally speaking ,about 2-6 weeks..depends when the ECM,jusyt like Dave did!FTA is not much different...its all up to Charlie! |
Post Number: 460 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 08:39 pm: |
@Pentiger The reception is poor, but they do work. |
Thanks Angel_RG Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 08:43 pm: |
To follow up on Angel_RG's post, the Fortec Ultra is one of the FTA receivers that requires a bin update. Despite what thill1951 said, you CANNOT input N2 keys into the Fortec Lifetime Ultra. Thill1951 has given very good information for some things, however, it is still not possible to input N2 keys into the Ultra even with the latest bin. I just wanted to correct this information and appreciate Angel_RG's post. |
New member Username: 88888888
| Posted on Tuesday, November 08, 2005 - 08:59 pm: |
anyone have any info about the latest bin files for a Techsat or how to enter the codes manually if it's possible on the current bin? thanks |
Shaky1967 Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 09:08 pm: |
Okay, you have ALL missed out on the Digiwave Diamond (which, besides what people say about it -is a great machine), does anyone have the new keys for it??? The keys listed on this site (and many others) do NOT work. How much can I stress the DO NOT work part of that statement?!! Just got "Zapped" yesterday, have a Digiwave Diamond" unit -which is the clone of the C**lsat 7000 unit. Anyone have the working KEYS??? |
| Posted on Tuesday, November 08, 2005 - 09:09 pm: |
Okay, you have ALL missed out on the Digiwave Diamond (which, besides what people say about it -is a great machine), does anyone have the new keys for it??? The keys listed on this site (and many others) do NOT work. How much can I stress the DO NOT work part of that statement?!! Just got "Zapped" yesterday, have a "Digiwave Diamond" unit -which is the clone of the C**lsat 7000 unit. Anyone have the working KEYS??? |
Post Number: 464 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 09:36 pm: |
@Thanks Angel_RG Actually you're wrong, if you flash your fortec with a pansat bin, you can indeed punch in the new n2 keys. |
In need of major help Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 09:59 pm: |
I have a Pansat 3000 where do i get the keys for that?? plz help!! |
dssjunkie Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 10:06 pm: |
h3lt3r_sk3lt3r is right do a flash with pansat bin and your golden! |
| Posted on Tuesday, November 08, 2005 - 10:07 pm: |
sorry for the double post! I am fairly new to this. I have a Pansat 3000(thats what it says on the box) and when i goto the menu the background says -=Pantec=- Then when i go to System information it says: Clone REI.256c.v3.0 Boot Ver:5.1 Oct 01 2005 Pantec i have no clue of what to do to get channels back if someone can explain it to me what to do , step by step i would be very greatful. (I have no software no nothing, just the reciever that says Pansat 3000. thanks , Ash |
Post Number: 473 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 10:09 pm: |
@AshKal Read this: http://forum.ecoustics.com/bbs/messages/2/173890.html |
Cabo Rojo,
Puerto Rico
| Posted on Tuesday, November 08, 2005 - 10:11 pm: |
Hey guys we lose the programing right now. |
biverland Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 10:16 pm: |
Oll FTE resivers are DAWN ............need a good PROGRAM n2 including autoroll for them ...the one from Sept.........no good. Its a time for NEW NEW .... Cant instal key in old n2 program ... |
Rodzzzzzzzzzz Unregistered guest |
| Posted on Tuesday, November 08, 2005 - 10:29 pm: |
ALL IS GOOD THANKS Umnov@msn.com I know I am being sarcastic, but when do you think we will get the Disney channel and some other missing channels back? Thanks ALL!!! |
Post Number: 477 Registered: Oct-05
| Posted on Tuesday, November 08, 2005 - 10:32 pm: |
@biverland Just READ READ and you will get the solution so your receiver can WORK WORK. |
New member Username: Ajbene
Post Number: 4 Registered: Jun-05
| Posted on Tuesday, November 08, 2005 - 10:47 pm: |
Hey DeerHunter the "This Account has been suspended" for the Fortec uploader. Any other sites with the Fortec Star uploader software. |
| Posted on Wednesday, November 09, 2005 - 12:10 am: |
hi all i have viewset v2000 i want to know how to change new keys please help me thanks handsum03@yahoo.com |
Post Number: 486 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 12:20 am: |
@Anonymous Read this thread from the beginning, your answer is here. |
| Posted on Wednesday, November 09, 2005 - 12:42 am: |
I have question to all those people who know how to deal with this dish and stuff especially in FORTEC FTA ***can someone me like for real if Fortec FTA receivers are working right now or not*** after installing those bin by uploader need it quick response from all of you please also send the full fortec guide installation Thnx for your help (in advance) you guys are great!!!! keep up the good work |
John Bor. Unregistered guest |
| Posted on Wednesday, November 09, 2005 - 01:29 am: |
I have this info on my pantec reciver: Clone ReL 256c.v3.0 Boot ver : 6.0 OCT 01_2005 .:PANTEC:. It already says that I have 256 bin. But I can not find nagra2 ? there is only nagravision. what should I do?update the bin with another 256??? please help I am totaly confused |
| Posted on Wednesday, November 09, 2005 - 02:19 am: |
Does anyone know anything about the pansat 5000 hc. I dont think I have all the menu functions as you all like I cant find set default keys on my menu please help |
| Posted on Wednesday, November 09, 2005 - 03:20 am: |
How about for the techsat? anything for this model. Please help!!! |
New member Username: Mohankumars
| Posted on Wednesday, November 09, 2005 - 03:41 am: |
Did anybody got "Multistar 2500 Maximum" hit with the recent Key change and anyone got the new Keys? I tried the above key but it doesnt work. Please help to get me the working Key 00 and 01 for "Multistar 2500 Maximum" or guide me where I can get them.. I tried under : Nagra => 0001 dish Network => Key00 : F298 7444 1C65 77D8 and Key01: 17E3 E11D 894E 5345 but no luck..Please Help!
Bronze Member Username: Laxey34
Miami,
FL
United States
Post Number: 11 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 12:03 pm: |
FTA Central dot come is down |
New member Username: Graffiti
| Posted on Wednesday, November 09, 2005 - 12:54 pm: |
ajbene, PM me and I'll send it to you. G |
Gella9052004 Unregistered guest |
| Posted on Wednesday, November 09, 2005 - 01:16 pm: |
i have tried all of the above methods i have pansat 2500A but still no picture i have the 256 on there, went down last night but i can't get it back up and running any suggestions would be appreciated thanks guys...
Post Number: 491 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 02:00 pm: |
@Gella9052004 After loading the 256 bin you HAVE to punch in the new n2 keys. |
| Posted on Wednesday, November 09, 2005 - 02:12 pm: |
witch key is that the 17E3E11D894E5345 because that on and the other one is not working
New member Username: Myan1
| Posted on Wednesday, November 09, 2005 - 02:24 pm: |
hello all, I have a fortec lifetime ultra receiver al7bar FTa Ultra Al7bar -2.81a Boot Ver: 6.0 sep 09, 2005 (nt) will i need a new bin, or just the new key codes to get my echo3 61.5 sat working again? thanks in advance.
| Posted on Wednesday, November 09, 2005 - 02:28 pm: |
Myan Patel, You need a new bin for the Fortec Ultra with the keys already loaded, the latest bin is al7bar's 282t3 bin with 12 hour clock fix. |
| Posted on Wednesday, November 09, 2005 - 03:07 pm: |
hi guys,can i use the new keys with my pansat 2700a if my reciver system imformation is the follow x-87bl api:1.18_eubx boot ver. 6.2 26 sep 2005 please let me know because i change the keys an work only one day. |
Post Number: 499 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 03:22 pm: |
@Gella9052004 Look at the first post in this thread, working keys are there. @Anonymous Yes, 118 will you an option for n2 keys. |
| Posted on Wednesday, November 09, 2005 - 03:45 pm: |
Hi guys, Anyone have any idea of how to enter the new key for Techsat? It's not like the nag 1 where it's in the menu code and change it. Would appreciate any info or help. |
| Posted on Wednesday, November 09, 2005 - 04:02 pm: |
@h3lt3r_sk3lt3r Thanks. I change the keys, but doesn't work, then if i going to check back the keys are changed,i'm sure that i press the ok botton to store the keys but i can't see nothing.Please if you have any other option let me know because is the first time that I work with this kind of receiver. Thanks |
Thanks h3lt3r_sk3lt3r Unregistered guest |
| Posted on Wednesday, November 09, 2005 - 05:07 pm: |
h3lt3r_sk3lt3r - Are there any disadvantages to flashing a Fortec Ultra with a pansat bin? If you can input new N2 keys with a pansat bin are you losing anything by not flashing a Fortec with the Fortec bin? |
Post Number: 505 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 05:53 pm: |
@Anonymous Before you input the keys press "Set Default Key". @Thanks h3lt3r_sk3lt3r No disadvantages, and you can always revert back by flashing your fortec with a factory bin. |
New member Username: Hawk1
| Posted on Wednesday, November 09, 2005 - 07:44 pm: |
where can i find the 256 bin download? |
| Posted on Wednesday, November 09, 2005 - 07:50 pm: |
can anybody help me please? |
Post Number: 508 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 07:52 pm: |
@Rusty Shackelford future-fta .com |
Post Number: 584 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 07:59 pm: |
I have NEVER seen a thread with so MUCH INCORRECT info ,except from a very few regulars here...people post BS,and have no clue what they are talking about!...all of a sudden we have these 1 day heroes,like cockroaches coming out of the wood work! |
| Posted on Wednesday, November 09, 2005 - 08:09 pm: |
so is the file i found on future-fta correct? |
| Posted on Wednesday, November 09, 2005 - 08:44 pm: |
can somebody help me post the key pansat 2500a please . |
Post Number: 511 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 09:05 pm: |
@Rusty Shackelford What do you mean? did you even try to flash your box? ---------- Thill this IS pretty insane, having a mod here would've really helped. |
| Posted on Wednesday, November 09, 2005 - 10:12 pm: |
i do the blind scan with the 110 and 119 satelite but when i check the channel programing i find only the 119 satelite information. what can i do to repair this problem,also i can't find the latin channels.would appreciate any help |
Post Number: 524 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 10:33 pm: |
@jm_luciano Did you read any of the start up 'how to's'? You can't scan 2 sats at the same time you have to do it individually, are you using a diseq switch? did you configure the diseq sett. on your receiver to match your physical setup? |
Post Number: 10 Registered: Oct-05
| Posted on Wednesday, November 09, 2005 - 10:45 pm: |
"thill1951" i don't know if your talking about my post above, but thats not bs. and i don't claim to be a hero. i just post stuff once in awhile, i don't do this full time like you guys, so my info may be old news to you. but when i came home and could not find a new bin for my fortecs. so i loaded a pansat clone bin for the hell of it, my fortecs work better than they ever had. keep up the hard work thill and other testers. you helped a lot of people, from what i read. |
Post Number: 5 Registered: Nov-05
| Posted on Wednesday, November 09, 2005 - 11:06 pm: |
how can i configure the diseq sett ,excuse but i buy this receiver last week and is the first time that i work with it.i do somes changes and works but some parts of the programing settings need that somebody that are more qualified.i really appreciate your help |
Post Number: 6 Registered: Nov-05
| Posted on Wednesday, November 09, 2005 - 11:23 pm: |
@h3ltr_sk3lt3r i find how to configure the diseq sett thanks another time |
North Carolina
| Posted on Thursday, November 10, 2005 - 06:27 pm: |
thanks everyone I finally got it going again. Scan worked geek geek. THANKS AGAIN |
| Posted on Friday, November 11, 2005 - 02:11 pm: |
I'm a newbie, I have the correct cable, what do I do to flash the box? Or do I just send new file....any help, instructions would be great!! |
| Posted on Saturday, November 12, 2005 - 09:17 am: |
TEST |
New member Username: Acxts
| Posted on Saturday, November 12, 2005 - 09:33 am: |
PANSAT 2500 FIX IS GOOD. and I am very sceptical of forum offered files. THIS IS TRUE. This really works. Took 10 min to do. Got all channels back. Flashed on top of my existing n2 flash that quit when numbers rolled on my pansat 2500. not known good for clones. thank you pentiger! Got from this origional post--> -------------------------------------------------------------------------------- download the new bin for Pansat 2500A http://pentiger.kom/BL255c-11-07-05-fix.bin change the .kom got it from different forum, which is overloaded |
mikedice Unregistered guest |
| Posted on Tuesday, November 15, 2005 - 08:47 pm: |
I am the biggest moron around, I am completely new with this. I got the pansat 3500s, Thill, I've read a llot before you kill me. I got the latest bin on the box, I got good sattellite reception (echo 8.6 ku and ech0 7 ku). I did the scan and got some channels but it says scrambled or bad channel in every channel. I am doing this because while I was deplyed to the Gulf (USMC) for 11 months and got back I had a $800.00 bill from direct tv, and I had to pay it, #%$@ them! |
| Posted on Wednesday, November 16, 2005 - 12:57 am: |
thanksssssssssss lot guys my TV back I love the GUYSSSSSSSSSSSSS |
Kernel_32 Unregistered guest |
| Posted on Wednesday, November 16, 2005 - 02:43 am: |
Angel_RG: I really, really appreciate your 20-step tutorial, thanks a lot! Since they pulled the plug off for Nagravision 1, I got mad and pulled the plug off my Pansat2500A receiver as well (that was months ago) and today I just I heard that there was finally a bin file that could resolve everything, so I researched, got and read this and another pair of articles pretty much and I just got everything fully working, thanks to this 20-step tutorial, the bin file ( bin file 256 [mine's called "X-85BL_050926_256_api(N) anti kill clone fix.bin" and got it from the dsstester.com forum], which is, I believe the same as the one linked in this very own thread like 4 times), and the program called Blacklist STB Updater v. 1.4 to upload the bin file to my Pansat through the RS232 serial cable. |
| Posted on Wednesday, November 16, 2005 - 05:14 pm: |
does Some firm have to today for fortec star 5100 diamond or keys new? |
| Posted on Saturday, November 19, 2005 - 07:17 pm: |
Can I have the new news of the doose and the effect of bin 850x on the diagmatic orfices of the semicirculatory canal with its ambula. Help please. |
Post Number: 786 Registered: Oct-05
| Posted on Saturday, November 19, 2005 - 07:33 pm: |
look next to the altimeter... |
satellitesurfer Unregistered guest |
| Posted on Saturday, November 19, 2005 - 11:22 pm: |
check these sites out: www.satellite100.com |
New member Username: Lucam22
| Posted on Monday, November 21, 2005 - 06:11 pm: |
Hi guys, i need help on my pansat 3500s, i'm not able to view any channels, i always get scrambled or bad channel, and i don't see any channel, what should i do and how, if nayone can help me please. Thanks |
Drummerboy Unregistered guest |
| Posted on Monday, November 21, 2005 - 08:44 pm: |
the latest keys worked just fine on my Pantec 2500 ultra. I believe i am using a Pansat Bin. It was flashed on Sept. 25 2005. I can only select Nagravision (not Nagravision 2) and i have to enter the two keys, 00 and 01. After all this, a reboot power off and a new channel scan it worked just fine. I think some ppl may miss a step, or the pansets are working better than the ultras, cause mine is flawless now, both 110 and 119. Thnx to Helter and Thill. Take a bow. |
