Thread: Need Help finding Echostar 9 |
New member Username: Kev_one75
Post Number: 1 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 03:43 pm: |
I have my FTA Pansat set up for Echo Star 6/8 and Echostar 7 on a separate dish, those are working fine. i just got an 80 cm dish from Winegard and i am trying to find Echostar 9, i get the signal but no quality. am i getting no signal because i'm not focused on the proper dish. Any help with dish pointing would be appreciated. First time setting up a dish. Thanks |
Post Number: 2 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 04:15 pm: |
i should add that i'm getting 82% signal but no quality. |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 202 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 04:32 pm: |
@bobby Make sure you're using a linear lnb for 121w (echo9). You might want to check out this software: http://www.arachnoid.com/satfinder As well as these links for dish pointing (thanks to Spanky). http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm http://www.remotesat.com/lookangle.htm |
Post Number: 203 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 04:35 pm: |
@bobby If you already ARE using a linear lnb, check on your receiver that the settings for its frequency are set to: 10750 instead of 11250. |
Post Number: 3 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 03:02 pm: |
I've lowered the dish to the co ordiantes on the satfinder website, but still unable to get the quality signal. I have the Universal Twin LNB 0.3dB Horn. is there a site for settings of the LNB?
Silver Member Username: Spank
Post Number: 162 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 08:38 pm: |
What are your settings for Echo9 in your Pansats Antenna Setup screen? Try setting LNB Type to Universal - 10600 Turn on 22Khz |
Post Number: 4 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 09:57 pm: |
sorry i've got the fortec life time ultra receiver, my settings are Universal 10600 but it seems i still cant get any quality even though signal stregth is above 75. does anything need to be done to the receiver? |
