Thread: Is this a good deal... |
| Posted on Monday, October 31, 2005 - 05:22 am: |
Im new to all this i just bought a viewsat platinum 2000, now which dish do i buy? is this a good ( http://cgi.ebay.com/SATELLITE-DISH-31-INCH-WINEGARD-STANDARD-KU-LNB-FTA_W0QQitem Z5823090128QQcategoryZ11726QQrdZ1QQcmdZViewItem ) or which dish do you guys recommend. Any advice or comments is greatly appreciated. |
Silver Member Username: Thill1951akalk
Post Number: 414 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 09:25 am: |
Wingard is OK..all depends what U plan on watching...which satellites?..The type and # of LNB's is MOST important!... |
| Posted on Monday, October 31, 2005 - 04:59 pm: |
i want to watch 110 and 119, since they seem to have more channels |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 205 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 05:07 pm: |
@josef As stated in the auction the dish's primary use is FTA not DN, AND both 110 and 119 use a circular lnb not linear (like the one in that auction). If you are only looking for DN, you'll be better off with dish500. |
| Posted on Monday, October 31, 2005 - 09:15 pm: |
ok, Is that all I need to receive channels on 110 and 119, a stock Dish 500. |
Post Number: 211 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 09:24 pm: |
@josef Yes |
| Posted on Tuesday, November 01, 2005 - 12:10 am: |
h3lt3r_sk3lt3r and thill1951 thanks for the help. |
