Thread: Cant find 119 |
| Posted on Saturday, October 29, 2005 - 04:04 pm: |
i liive in edmonton alberta, no prob finding 110 but cant find 119.can anyone help me,I NEED HOCKEY. in relation to 110 where is 119? thanx in advance. CHEERS |
| Posted on Saturday, October 29, 2005 - 04:12 pm: |
KENBOB 119 is about 3" to the right of 110 and about 2" higher so skew the dish |
| Posted on Saturday, October 29, 2005 - 04:21 pm: |
so move the dish so the lnb is 3" to the right, and 119 bird is higher 2" in the horizon. is this correct. Thanx in advance Ken |
| Posted on Saturday, October 29, 2005 - 04:37 pm: |
KENBOB your very close if you have 110 don't move the dish just yet, try skewing it first, it's approx.2" higher if looking from the back, |
| Posted on Saturday, October 29, 2005 - 04:43 pm: |
I will do that, and thank you for your time and knowledge it is grrrrreatly apprciated. Ken |
New member Username: Mironiu
Post Number: 7 Registered: Oct-05
| Posted on Sunday, October 30, 2005 - 10:15 pm: |
Kenbob, let me know if you found it ,couse I have same problem and I live in Edmonton. |
Silver Member Username: Spank
Post Number: 155 Registered: Oct-05
| Posted on Monday, October 31, 2005 - 12:27 am: |
Here are some helpful sites to find satellites: http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm http://www.remotesat.com/lookangle.htm
Post Number: 8 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 02:07 am: |
Thanks, for helpful sites. Can I receive 119 sat signal on my 20" dish in Edmonton? Tried some many times without any luck. |
Silver Member Username: Thill1951akalk
Post Number: 417 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 08:50 am: |
sure can with circular LNB and proper alignment |
newbiehere Unregistered guest |
| Posted on Tuesday, November 01, 2005 - 11:20 am: |
Can't get all local channels on 119? Do I need a channel list that has those channels? I've been doing blind scans but I always get the same channels. |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 220 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 11:54 am: |
@newbiehere Channel lists won't help if your dish is not aligned properly. |
newbiehee Unregistered guest |
| Posted on Tuesday, November 01, 2005 - 12:17 pm: |
Thx h3lt3r Mainly, I trying to get all Los Angeles local channels. So far I can get ABC, CBS, Fox so I don't think the dish is misaligned. I'm trying to get the rest of them. I've done several blind scans but always get the same channels. Any other suggestion? |
Post Number: 222 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 12:30 pm: |
@newbiehee Almost all other locals if you're on the west coast are on 148w sat, if you're not on the west coast they're on 121w sat. |
| Posted on Tuesday, November 01, 2005 - 12:55 pm: |
I'll try that. However on lyngsat.c I noticed the LA channels are on 119 not 148 or 121. As I mentioned before I'm getting a couple of channels already in the LA region but not all of them. Thanks for your inputs, h3lt3r. |
Post Number: 227 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 01:15 pm: |
@newbiehere I'm sorry they are on 119, TP15, don't know what I was thinking. Try scanning that TP, coordinates are TP15: 12428 V 20000. If that doesn't work try loading a channel list, won't hurt checking that. |
