Thread: Atmega128 |
THE DON Unregistered guest |
| Posted on Saturday, October 29, 2005 - 01:30 pm: |
i just bought an atmega128 card and programmer, because i heard the nagra2 fix just came up for it, and i wanna know wat reciever i need to buy, and where i can find scripts for the card or w/e also i had a dishnetwork reciever echostar model 3000, i was wondering, if thats also up and running |
| Posted on Saturday, October 29, 2005 - 01:38 pm: |
and also can a VIEWSAT VS2000 PLATINUM FTA DIGITAL SATELLITE RECEIVER work with the atmega128
| Posted on Saturday, October 29, 2005 - 01:41 pm: |
or a PANSAT 2700A FTA DIGITAL SATELLITE RECEIVER |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 164 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 02:05 pm: |
@THE DON You'll have to read ALOT. Atmega wafers are used on DN's receivers, I haven't dealt with atmegas and programmers in quiet a while, BUT I would imagine that your existing 3000 just might work with it, because it's clock is the same as DN's 6000 receiver. |
THE_DON Unregistered guest |
| Posted on Saturday, October 29, 2005 - 02:27 pm: |
so where do i get the scripts to load unto the card |
Post Number: 171 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 02:33 pm: |
Look at these sites: http://forum.ecoustics.com/bbs/messages/2/168756.html |
| Posted on Saturday, October 29, 2005 - 04:39 pm: |
The DON Unregistered guest Posted on Saturday, October 29, 2005 - 03:33 pm: -------------------------------------------------------------------------------- i got an email saying that there is a fix for nagra2 using atmega128, but someone told me its B.S can someone confirm b4 i go and buy ................................................. Look at the times..2 hours later "the DON" says he hasn't bought one.another lying punk kid here. |
New member Username: Designer
Post Number: 2 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 08:55 am: |
I still waiting to buy a Atmega because it is more cheaper than the FTA if anybody knows the way to make it works please post it. |
Post Number: 225 Registered: Oct-05
| Posted on Tuesday, November 01, 2005 - 12:56 pm: |
@Luis Lopez Make an effort for yourself and read, why is it so hard? Here's something to let you get started: http://forum.ecoustics.com/bbs/messages/2/168756.html |
