Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Can't get all channels on Dish 148
Author Thread: Can't get all channels on Dish 148
Username: Mironiu
Using C___T 4000 Pro with 2 dishes 110 and 148. Missing some channels on Dish 148. Any idea or suggestion?
when doing a scan make sure network search buutton is on and use manual scan
Username: Mironiu
Thanks, sure thing will do it.
One more thing, got 2 dishes 110 and 148 and using DiSEqc switch.Doesn't look like I can combine these 2 satellites.148 is plugged to swich #1 and 110 to #2.Is this correct?
Username: H3lt3r_sk3lt3r
Post Number: 156
@Myron Zane
Yes, your question was answered in another thread, it doesn't really matter if you plug 148 into 1 and 110 into 2 or vise versa, BUT you have to match your physical setup in receiver's diseq configuration.
If you're scanning both sats (one by one of course) and running the coax from lnb to switch to box and still can't get both, try scanning each sat individualy by plugging the coax from lnb straight to receiver, then after you're done, plug the switch back, configure the diseq settings on the box.
P.S. also in receiver's config, for 110 turn the 22khz to OFF and 148's 22khz to ON.
Username: Mironiu
Thanks a lot for the info. New to FTA receivers.
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Can't get all channels on Dish 148 [ « Previous ] [ Next » ]
