Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Koolsat failed project
Author Thread: Koolsat failed project
Username: Mike_sib
hi i have a 4000pro and tryin to get 110 and 97, so far i've tried bins 1.30 to 1.34 and no result, tried factory reset and blind search in all the cases and yet nothin. signal is good and get all the channels but only scrambled. any help is appriciated
Username: The_kneegrow
maybe if you learned how to spell the fcuking name of the reciever...I would help you...go back to school you idiot stick...ROTF
Username: Mike_sib
maybe i did but i got a error massage that i can not use that name for some reason other than that i know how to read the lable
Username: Mike_sib
hepl ppl help
Username: Thill1951akalk
Post Number: 340
Much more info is needed...Did it EVER work?...dish, LNB's ,switches, remote installation, etc...at what point is your problem...what are your error messages?
Post Number: 345
about the coo*lsat!
First you need to do a factory reset.
Then connect the box to the computer with your cable.
Power the unit up, use a program called
Coo*lsat proloader v[1].2.1 .
Then once you open the program click on Auto detect , it should find your FTA and what version software that is on it.
Then click on the browse tab and look for the bin you downloaded.
You need COOLSAT4000_133p_20050902.stb. Make sure you are on the software tab, then click connect, then start .
Let it complete the download, don't interrupt it. You are now ready to test. Hook it up to the sat and do a blind scan or you can use the channel guide of your choice to download to your FTA. Just use the same program and click on the channels tab.
Good luck hope this helps..
BTW..use the latest 134 bin
Username: Mike_sib
let me thank u thill1951 for u help, just for clearification im using an 18" for 110 and 33" for 97 also using coo*lsat 4X1 diseqc switch 1.2 and i have them set up on 3 and 2 . i get the signal and free channels for all both and the rest shows up as scrambled. problem is with all encryptions, viaaccess and nvision and bunch other. just a quick q's do i need to load just the 134 bin or all right after one another. also can i connect 110 straigh or do i need something on the way after or before switch
Post Number: 371
Not sure exzctly what U are saying about your setup and how many receivers and LNB's,LNB type,(legacy,single,twin, dish pro) etc..as U know,circular LNB on 18" for the 110w and linear on the 33" for 97w..
first run the 18" directly to 1 receiver (no switches ) then do the scan...all the 110's should show up...then do the same with the linear LNB for the 97..if U have problems at this point U have elimnated disque switch as a problem...go back and recheck all your alignments,cables, and remote installation menu scans etc..
Username: Mike_sib
i did check everything u sadi thill but what im wondring is if i had any set up problem, i shouldnt be getting any signal or even low signal, but all the channels come through with high quality the only problem is they are scrambled, im getting the info channel from 110 clearly with is free and also all the free channels on 97 but i cant unlock the other channels although they come in in perfect quality.if u could confirm what im doing is right:
i reset the STB to factory setting by downloading the defualt bin, then factory set the receiver, reboot and load the 134, without any distruptions, and finally did a blind scan on both satellite, like i said i get the channels but they are scrambled
thnx a million
Post Number: 377
all sounds good, where U should not have srambled TV and should be watching TV...but what about your hardware...and running directly with no switches?
and the 97w , U need no 134 bin...just the factory flash and settings..
Username: Mike_sib
Post Number: 7
thanx thill the problem was the switch once i ran i without the switch it worked, then i put back the switch after and thanx to ur help its running perfect
Username: Mike_sib
Post Number: 8
any reason that i can get 110 and 119 but im not able to get any 91 or 82, they still show up as scrambled.
thanx
Post Number: 404
mike.... U really need to do some basic reading here...and take a look at this www.lyngsat.c*om ...82 and 91 W are BEV satellites...there is NO hack for BEV TV..110 and 119 are Dishnet satellites...dishnet is hacked..
Username: Mike_sib
Post Number: 9
tnx thill
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Koolsat failed project [ « Previous ] [ Next » ]
