Thread: Check DVD-RW Disk |
Bronze Member Username: Retiredjetp
Post Number: 22 Registered: Dec-04
| Posted on Thursday, October 27, 2005 - 09:20 am: |
I should have included this question in my first post, I apologize. Is there any way to check a DVD-RW disk for errors prior to using it in a stand alone dvd recorder to record from the tv ? My computer does not have a dvd recorder, it does have a dvd rom drive and a cd-rw drive. Reason I ask this is due to the fact I get a lot of failed DVD-RW disk when recording tv programs on my Panasonic DMR-ES10 recorder. Thanks, Chuck |
Gold Member Username: Samijubal
Post Number: 1766 Registered: Jul-04
| Posted on Thursday, October 27, 2005 - 01:26 pm: |
DVDInfoPro will scan for errors, I don't know if it works with ROM drives or not, but it's free. http://www.dvdinfopro.com/ |
Post Number: 23 Registered: Dec-04
| Posted on Thursday, October 27, 2005 - 04:10 pm: |
David, >> don't know if it works with ROM drives or not<< No it doesn't, I just followed your link and tried the program, I guess it has to be a DVD recorder drive to work. Thanks, Chuck |
