Where I can buy FTA in Toronto
Username: Kudr
Toronto, Ontario Canada
Where I can buy Fortec Lifetime Ultra in Toronto or Richmond Hill....I believe this one is better than Cool sat, because you can edit keys in bin file by yourself, what you cannot with stb files.
Username: H3lt3r_sk3lt3r
Post Number: 118
You'll be better off with pansat 2700a (if you're tight on money), less of a headache, and you can also enter n2 keys manually by loading the latest bin.
Check out ebay, alot of stores are either based in canada or will ship there.
Username: Decko
Post Number: 15
http://www.dishexperts.net/b2c/
they are goood and very cheap
