Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Some channels missing
Author Thread: Some channels missing
Username: Perry45
hi all
I just programed my reciever and i think i am using 119 and before N2 i use to get all the Starz channels but after i did the satellite scan with the new program i only recieve one starz channel.
i did a scan on the satellite not a blind scan.
I am using multistar and the fix is clone fix 256c
any help is appreciated
thanks
h3lt3r sk3lt3r
Try loading wingnut's legacy channel list and see if you get any signal on the missing channels or the tp's which those channels are on.
Sometimes channel lists work better than a blind scan.
Username: Perry45
not sure how you load the channel list, suggestions are welcome
thanks!!!!
Perry
Username: Thill1951akalk
Post Number: 123
Use Gtools or channel master to load any channel lists .GTD files
Go to www.dsstester.com and register....Its a FREE site...then go to this link and read and get channel master...
http://forums.dsstester.com/vbb/showthread.php?t=39491
FTA Newbies Useful Links.......Please read
FTA How to set up guide
How To Coo*lSat Guide
How To Setup for Pansat 2700A Guide
How to DreamBox Guide
How To Setup The Digawave Receiver Guide
Pansat 2500a Setup Guide
Instruction for Flashing PANSAT 2500A
SpaceStar Dvb-500 How To Guide
Fortec Lifetime Ultra Guide
Fortec Lifetime setup step by step Guide
Dish & LNB type for FTA receiver Guide
More set up & how to guide.
How Interpreting Lyngsat Data Guide
How To Guide: EPG with a channel list
PanSat Quick & Easy Channel List Fix Guide
Ultimate FTA Manual
FTA Receiver Testing Manual
How to spot Fake/Real Pansat
Useful Ultilities & Programs
Get all you file here: General FTA FILE FORUMS
Dido Smith Bundle Package For your FTA Channels list
All FTA Ultilites & loader
Factory TSOP flash for FTA
Channel Master Tool
FTA Receiver Repair Kit
Fortec Star Lifetime Ultra Black Death Repair Kit
All Files To Jtag Your Dead 2500A
how to Jtag your Cooltec Guide
Username: Perry45
ok thanks i ill try that
could i also try to delete my current list on the reciever and do another scan??
thanks
Username: H3lt3r_sk3lt3r
yes
Username: Perry45
ok what is the best way to do the delete and rescan
i have a ultrastar reciever
thanks a million
Delete all channels and do a blind scan :-) there is no best or worst way to go about deleting and rescanning.
Post Number: 143
To get all the channels available at this point , your best bet is to do a scan, as charlie is fu*cking around changing Tps a lot these days.
After the scan is finished, push the "SAT"button on the remote and you should have a Echostar Package option in there, all channels should be there in the same order as they are in the Dishnet numbering order.
You will probably have duplicate channels in this list because some channels are available in both satellites or three whatever you might have.
If this is the case, upload the list to your PC with Channel Master and edit the repeated channels out .Keep the channels from Echo 7 and fill the rest with echo 6,8.Save the list, load it back in to the receiver and you should now have the list updated to the most recent Tps changes.
That is the way I did , I hope it works for you.
Username: Perry45
ok well i tried the blind scan but still ended up with one starz channel???
any other suggestions
Did you get any results with a loaded channel list?
Username: Perry45
no I have not tried that as of yet because i have never done that.
where can i find channel master and what typ of channel list could i use with that program?
thanks
Post Number: 7
Channel Master on SharpC's site: http://sharpc.dyndns.info/CM/update.aspx
al7bat. tk, register there and download a channel list suited for your setup or location (search for either dido smith's channel list or wingnut's, they are often updated and have full channel names, you might need to edit sat names in CM to take advantage of the echostar package, of which LK was talking about previously.)
Also check out dsscentral. net, they have useful downloads.
P.S. if you have Dish pro setup then download a dish pro channel list, if not then download legacy list. Channel Master also gives you an option to convert legacy to dish pro.
Post Number: 8
^ al7bar. tk ^ sorry.
Post Number: 150
Its much easier just to do a scan...U must be doing something wrong if U can get ONLY 1 channel with a scan!...either your dish is not aligned correctly or U have a single or dual LNB getting only 1 satellite...or U did not reset back to factory default (password 0000-1668) ...or your menu-antennae setup is not configured according to your LNB or disque switch or U didn't do a receiver reboot..
or you need to edit or add a tp
Username: Perry45
Post Number: 7
no sorry i am getting lots of channels but not all of them??
what do you mean doing the factory reset
what does that do?
how do you add a Tp??
thanks all again for all your help
Post Number: 9
When doing a blind scan there is no need for manual tp addition.
Post Number: 10
Factory reset brings your reciever to its virgin state, resets all the settings back to what they were when the box left the factory, so in case you configured something wrong either intentionally or by mistake the factory reset will give you a fresh start.
Username: Perry45
Post Number: 8
ok thanks
two questions
how do you do the factory restet on a multistar and the other question is do i have to put the latest bin back on after i do a reset.
thanks all
Post Number: 13
Not sure as I've never actually dealt with multistar, but there should be something in the menu that either says factory reset, reset to factory or factory default (or if you have a factory bin you can flash your receiver with that as well.)
And yes, after you manage to reset your box, load the latest bin.
Username: Perry45
Post Number: 9
ok I checked and there is something there and just says factory and when i click on it you have a choice of delete or exit
is this ok?
i dont want to screw up the reciever??
thanks in advance
blind scan does not always pick up every tp..that is a fact. with that said you have a choice of either using an updated ch. list or scanning. Now if you go to lyngsat. com then u can see what chs. your missing and find out what tps. they are on and if there missing add them.a simmple change from V to H or vice versa in the polarization, maybe all thats needed
jake234
isn!t it true that dtv&dishnet will soon be transmitting in MPEG4 format in the next couple of months,making all these hardware obsolete????
Post Number: 15
Well since DN is shifting channels from tp to tp lyngsat won't be much of help since they can't keep up with the changes.
Post Number: 16
@jake234
No, not months, maybe a year or two.
wahabkhqn22
I have a Ariza 700 on 61.5W. I got it 2 days ago. Now, all the channels are blank, the signal is sill there. What do I do?
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2005 > Some channels missing [ « Previous ] [ Next » ]
