Thread: Archive through September 09, 2005 |
| Posted on Sunday, August 21, 2005 - 11:43 am: |
How do U know U have Bev,not Dishnet?...if thats true then, of course U MUST realign the roof dish!... "scrambled channels" fix many times is a reboot/reset of receiver....BACK of receiver,power off,wait 1 minute,power on,turn to channels 300 or a known working channels.. |
| Posted on Sunday, August 21, 2005 - 11:44 am: |
How do U know U have Bev,not Dishnet?...if thats true then, of course U MUST realign the roof dish!... "scrambled channels" fix many times is a reboot/reset of receiver....BACK of receiver,power off,wait 1 minute,power on,turn to channel 300 or a known working channel.. |
New member Username: Lazeress
Post Number: 2 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 06:39 pm: |
Can any one help ??????? I have a fortec life time Ultra And have put the new Keys in but all i get is a black screen and scrambled or bad channel what can I do |
| Posted on Sunday, August 21, 2005 - 07:24 pm: |
| Posted on Sunday, August 21, 2005 - 07:48 pm: |
LK...I did what u said and still cant get any chanel ..it keep scrambled channel..what should i do? |
New member Username: Bobbyc
Post Number: 9 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 08:27 pm: |
LK, Sunday evening. Are there new keys? BC |
Post Number: 10 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 08:33 pm: |
LK, Sorry! I entered one wrong. Thanks any way. BC |
Post Number: 3 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 09:01 pm: |
HI I still can't get my receiver its a Fortec lifetime Ultra I have flashed it with a STB updater ver 3.31 and used Al7bar FTA 050613_276_api(NTSC) after that I input the new Keys but I still can not get anything to work all I get is it to say scrambled or blocked station. What am I doing wrong |
| Posted on Sunday, August 21, 2005 - 10:07 pm: |
KEY0 is active, changed Fri Aug 19 16:48:34 2005 KEY0: CF 2B 37 83 17 B2 CC 87 ...active KEY1: C4 B1 B5 B5 DD 6E AF 81 same keys...no changes...and these work now! |
Bronze Member Username: Bobbyc
Post Number: 11 Registered: Aug-05
| Posted on Sunday, August 21, 2005 - 11:16 pm: |
LK, As usual, thanks, BC |
Post Number: 4 Registered: Aug-05
| Posted on Monday, August 22, 2005 - 04:02 am: |
what does it mean when you say active key |
Post Number: 5 Registered: Aug-05
| Posted on Monday, August 22, 2005 - 05:34 am: |
I have rebooted the receiver for over one min. and still no channels ? |
| Posted on Monday, August 22, 2005 - 07:22 pm: |
DISHNET KEYS Current 08-22-05 5:15pm EST Key0: CF 2B 37 83 17 B2 CC 87 Key1: 74 0B 5F BD E6 04 29 1A ** Active and then ALWAYS do a reboot/reset! |
| Posted on Monday, August 22, 2005 - 11:22 pm: |
I have been reading instructions about how to setup the Fortec Lifetime ULTRA. I have tried all that I have read. But like others, I still get the "Scrambled or bad channel" message. I have been through the instruction several times, making sure I've used the latest keys as given by LK this evening. LK can you verify the keys right now? I need help!! What am I doing wrong? |
Post Number: 6 Registered: Aug-05
| Posted on Tuesday, August 23, 2005 - 06:45 am: |
flam I am in the same boat that you are I have a Fortec Lifetime ULTRA and get the same message can someone please walk us thur this ? |
| Posted on Tuesday, August 23, 2005 - 08:08 am: |
Fortec key change method 1)With receiver hooked up to TV and satellite: 2)Press MENU on the remote control 3)Then right side arrow to CHANNEL EDIT 4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688) 5)Then right side arrow to turn OFF, KEYCODE FUNCTION 6)Go to NAGRAVISION and press OK 7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK)) 8)Go down to KEY Number, then right side arrow to set to "00". 9)Go down to Key Data and enter the latest KEY with your remote control. D5 6F BB 83 00 D8 B0 4E ...(example only) 10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “00” is saved. 11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01 12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only) 13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number “01” is saved. 14)Press EXIT once. 15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT. 16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d audio=e |
| Posted on Tuesday, August 23, 2005 - 10:59 am: |
LK, I did your instruction step by step verbatum. It still did not work. Let me give you some more info about my setup. My dish is set to Sat. AMC-4. I am able to view/hear several FTA channels (Hope Chennal, Esperanza TV,ATN/ACN Service, 3ABN English, 3ABN Latino, LLBN, Peoples Network, KRUL Fox64 then some radio stations - 3ABN Radio, Radio 74,Lifetalk Radio). I am able to only hear the audio of the following: Court TV, MSNBC, Starz!, National Geographic, Fox News, Weather Channel, CNBC, AE History, AE Biography. Does Dish Network carry anything on this Sat? Also, the System Info on my unit is as follows: Al7bar FTA Ultra Al6bar - 2.76 Boot ver: 6.0 Jun. 13, 2005(Nt) Is this what it should be? One thing that I should note: When I was FLASHING the unit with the above version, it stopped a couple of times with the "Retry or Cancel" message. After pressing retry several times it continued to the end, then gave me the Download Complete message. Do you think that could have affected it in any way? Is there anything that you could possibly think of why it does not function as it should? |
Kilty_McBagpipe Unregistered guest |
| Posted on Tuesday, August 23, 2005 - 05:09 pm: |
Has anyone else using the Fortec Lifetime Ultra dish lost their PPV channels? I am able to get basically all of the other channels except the ppv and many other movie channels. |
RANTone Unregistered guest |
| Posted on Tuesday, August 23, 2005 - 05:18 pm: |
yeah, me too. just came in to see if it happened to anyone else. |
Silver Member Username: Maple_leaf
Post Number: 751 Registered: Apr-05
| Posted on Tuesday, August 23, 2005 - 07:12 pm: |
No we have them you must done something wrong . Like got the wrong fta. LMAO . |
| Posted on Tuesday, August 23, 2005 - 10:08 pm: |
-He didn't do nothing wrong except talking to U Mable U FOOL.LMAO up your azz |
| Posted on Wednesday, August 24, 2005 - 07:20 am: |
having problem entering keys I am on nagra but were it should say dish it says unknown 01 01 00 if I push the right arrow once it says unknown 00 01 00 also every time someone post new key they put **active dont see this on my screen no way to enter this in. do I enter both keys in both dish areas or one in 01 01 00 or 00 01 00 |
| Posted on Wednesday, August 24, 2005 - 07:02 pm: |
active means just that...its the ACTIVE key that was just/last changed..pushing the right arrow is changing it from Key0 to Key1...U will NOT see the word ACTIVE on the screen (LOL) and U do not enter/input that word.....U ONLY need to change the ACTIVE key, since thats the ONLY one that has changed....the other key should still be good from the last time U changed it,because it is NOT active and has not changed... Now do U get it?...a little common sense goes a long ways! Everybody has lost MANY channels to Nagra2 now...all PPV and PPV events are dead and gone to N2 now..after 31 August, U will only have the basic top 60 channels for a very short period of time.. |
| Posted on Thursday, August 25, 2005 - 10:31 am: |
DISHNET KEYS Current 08-25-05 9:15am EST Key0: E2 FC 16 1C D7 F5 1F 48 ** Active Key1: 74 0B 5F BD E6 04 29 1A |
| Posted on Thursday, August 25, 2005 - 11:47 am: |
Thank you |
| Posted on Thursday, August 25, 2005 - 12:03 pm: |
Post Number: 13 Registered: Aug-05
| Posted on Thursday, August 25, 2005 - 01:04 pm: |
LK, As usual, Thanks, BC |
| Posted on Thursday, August 25, 2005 - 04:16 pm: |
Bc you can not get those on amc4 because it's differant encryption. (powervu) |
| Posted on Thursday, August 25, 2005 - 04:43 pm: |
Seriously, you guys still have your ppv channels... I probably broke the damn thing. |
| Posted on Thursday, August 25, 2005 - 05:55 pm: |
are these keys universal for all boxes-----i have a pansat 2700a and getting a bit frustrated with this whol nagra2 bs |
| Posted on Thursday, August 25, 2005 - 07:26 pm: |
what are the keys for today 25 of august |
| Posted on Thursday, August 25, 2005 - 09:35 pm: |
Does anyone know the new keys for today??? Please hook me up |
Post Number: 14 Registered: Aug-05
| Posted on Thursday, August 25, 2005 - 09:48 pm: |
missa, Run back about ten...or so messages. LK posted them this morning at about 11:40 A.M. BC |
Post Number: 15 Registered: Aug-05
| Posted on Thursday, August 25, 2005 - 09:50 pm: |
Missa. I mispoke....10:31 A.M. BC |
greenhand Unregistered guest |
| Posted on Thursday, August 25, 2005 - 11:09 pm: |
currently with dish network, 301 receiver, is there a card will make the receiver still work when contract is due? thanks. |
Sat man 11 Unregistered guest |
| Posted on Friday, August 26, 2005 - 12:00 am: |
how do i over ride the parental controle with out changeing the password |
| Posted on Friday, August 26, 2005 - 12:07 am: |
| Posted on Friday, August 26, 2005 - 12:12 am: |
i nead a password that will over ride the parental control without changeing the password or nowing it
| Posted on Friday, August 26, 2005 - 08:18 am: |
Load the bin/flash on it again.. |
| Posted on Friday, August 26, 2005 - 09:46 am: |
LK Thanks for the info on how to enter the keys it works great! I dont seem to get any channels on 119 when I do a scan it fails got lots on 110 and the signal for 119 and 110 is at 98% you think I have a file missing? |
| Posted on Friday, August 26, 2005 - 11:24 am: |
Anyone have new keys for today, August 26 dish just went down |
Christa Unregistered guest |
| Posted on Friday, August 26, 2005 - 11:39 am: |
Christa wants to know when the new keywords are so if anyone has them please give it to us. |
Post Number: 767 Registered: Apr-05
| Posted on Friday, August 26, 2005 - 12:26 pm: |
Key0: E2 FC 16 1C D7 F5 1F 48 Key1: FB 18 30 83 ED ED 5B AC ** Active
| Posted on Friday, August 26, 2005 - 01:12 pm: |
Thank You! Maple Leaf |
| Posted on Friday, August 26, 2005 - 01:17 pm: |
Thank you Mapleleaf. Have a great weekend!!! |
| Posted on Friday, August 26, 2005 - 01:54 pm: |
LK: currently with dish network, 301 receiver, is there a card will make the receiver still work when contract is due? thanks. |
| Posted on Saturday, August 27, 2005 - 01:07 am: |
HELP! the TP can not be fixed on #17, when exits from the setting, it is automatically to be changed into other #. Is this normal, or my Pansat 2500a has a problem? Thanks to anyone that can give me a clue. greenhand |
Whitemouse Unregistered guest |
| Posted on Saturday, August 27, 2005 - 01:16 am: |
LK, my pansat 2500a was setup with bin file before (not by me). But by accident, I pressed the factory default key somedays ago. Does this mean that the bin was deleted by pressing that key? so, the bin file need to be reinstalled? If yes, what is the "appropriate loader" for doing that? Thanks, Whitemouse |
| Posted on Saturday, August 27, 2005 - 01:21 am: |
any one has new codes??? |
white mouse Unregistered guest |
| Posted on Saturday, August 27, 2005 - 03:32 am: |
LK-I finally got it work. It is really not easy for a person at my level. Thanks, whitemouse |
| Posted on Saturday, August 27, 2005 - 11:31 am: |
why I can't switch key code from 0 to 1...please help me |
| Posted on Saturday, August 27, 2005 - 11:52 am: |
does anyone have the new codes? |
| Posted on Saturday, August 27, 2005 - 01:06 pm: |
Anyone hsa new keys for Aug 27? |
| Posted on Saturday, August 27, 2005 - 05:29 pm: |
yo wasup who got da codes we need deem hurry ^ there's something i want 2 watch!!!!!!!!!!! |
| Posted on Saturday, August 27, 2005 - 05:37 pm: |
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old & i can score on people& roast on dem whish means I've always got an comeback HURRY ^W/THEM CODES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 |
| Posted on Saturday, August 27, 2005 - 05:38 pm: |
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old HURRY UP W/THEM CODES!!!!!!!!!1 |
| Posted on Saturday, August 27, 2005 - 05:39 pm: |
| Posted on Saturday, August 27, 2005 - 05:43 pm: |
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old HURRY UP W/THEM CODES!!!!!!!!!!!!!!!!!! |
| Posted on Saturday, August 27, 2005 - 06:09 pm: |
U are the slow one...they were posted over 29 hours ago here in this same thread...LOOK ABOVE! (about 10 posts above yours here)...dah!.(oviously U didn't look or are not too bright)..if 13 then U shouldn't be here...either way, 13 year olds should be able to read and write!...and find something they want, thats STARING them right in the face.. |
crapshoot Unregistered guest |
| Posted on Saturday, August 27, 2005 - 06:11 pm: |
F U C K . O F F .stupit kid |
| Posted on Saturday, August 27, 2005 - 08:15 pm: |
oops I'm sorry who ever this is but please give me the freaki'n keys and crapshoot why would you say that and I aint stupid I'm just ghetto dill with id yo my dad wants the keys okay.you don't even know me so how are you going 2 call me stupid. |
| Posted on Saturday, August 27, 2005 - 08:17 pm: |
does anyone have the new codes????? |
| Posted on Saturday, August 27, 2005 - 08:27 pm: |
And 4 this person LK I wasn't on the computer I was @ Venus Beach then went 2 my friends house and i just got home and my dad asked me 2 get the keys.....OH YEAH HOW DO YOU KNOW THAT i'M BRIGHT OR NOT JUST BY THE COMPUTER? |
| Posted on Saturday, August 27, 2005 - 08:38 pm: |
hello 2 who ever is Bendsm LK and crapshoot wont give me the codes no matter how nice I ask |
B1TCH BOY Unregistered guest |
| Posted on Saturday, August 27, 2005 - 09:39 pm: |
-A kid, got s_u_c_k your old mans dick...U little B-A-S-T-A-R-D...U and your old man are both f_u-c-ked in the head to let U come on this sight...Both U and your dad are two f_u_c-kin stupid to known whats going on, Your dad needs his azz kicked and then f_u_c_k in the O...Where is your B1tch mother giving head to all the boys in the hood? So kid f_u_c_k of or else I will have to put my dick in your azz o to. |
| Posted on Saturday, August 27, 2005 - 09:49 pm: |
-A KID-Are U a jirk or is it your father, or both of u?...Kid U don't need to come on this sight and talk crap...If U want, I will stick my very large dick up your azz. Your dad is a Dirt Ball for letting U on this sight...He need me to f_u_c-k some brains in his head. A kid where is the mother out to BINGO meeting RINGO...Or is she being screwed by all the boys in the hood....Kid I want to stick my dick in your azz and then screw your azz o father for leting U come on this sight. A kid does dad make U play with his balls? U smart azz little c_o_c_k s_u_c_ker. |
Post Number: 782 Registered: Apr-05
| Posted on Saturday, August 27, 2005 - 10:13 pm: |
SMALL MINDS SMALL POST LMAO. |
| Posted on Sunday, August 28, 2005 - 01:32 am: |
MAPLE LEAF......SMALL DICK . |
| Posted on Sunday, August 28, 2005 - 07:31 pm: |
hi guys any one has new keys for dishnetwork ??? |
Anonymous2 Unregistered guest |
| Posted on Monday, August 29, 2005 - 05:13 pm: |
Does anyone have the new dishnetwork keys?? |
| Posted on Monday, August 29, 2005 - 08:02 pm: |
hey - can anyone post instructions on how to use keymaster>? much thanks! |
New member Username: Lucky4
Pt. buewell,
Ontario
| Posted on Wednesday, August 31, 2005 - 08:49 pm: |
hi ftaers does anyone have keys for aug 31/5 thanks lucky4 |
New member Username: Sharpes84
Post Number: 9 Registered: Mar-05
| Posted on Wednesday, August 31, 2005 - 08:55 pm: |
do we think that the locals wil go down too???i need to know for the nfl games any idea? thanks |
Post Number: 10 Registered: Mar-05
| Posted on Wednesday, August 31, 2005 - 08:57 pm: |
also pansat and fortec are the effected the same way? |
| Posted on Wednesday, August 31, 2005 - 11:17 pm: |
DISHNET KEYS Current 08-31-05 Key0: C0 25 28 E7 22 F5 1F 48 ** Active Key1: 12 0C 9F BD E3 00 19 2A |
| Posted on Wednesday, August 31, 2005 - 11:31 pm: |
Thank you LK. Have a great night!!! |
| Posted on Wednesday, August 31, 2005 - 11:47 pm: |
LK i changed the keys like you said and i have picture but no sound. Are others having this problem? |
supersmoothguy Unregistered guest |
| Posted on Thursday, September 01, 2005 - 12:26 am: |
i tried these keys and they did not work dont waste your time. |
| Posted on Thursday, September 01, 2005 - 01:16 am: |
Key1: FB 18 30 83 ED ED 5B AC ** STILL ACTIVE CNN STILL WORKING. IF CHANNEL DOES NOT COME UP AND RUN, IT HAS BEEN CHANGED OVER TO THE NEW SYSTEM. THIS IS PROBABLY THE LAST UNTIL A NEW FIX COMES OUT......  |
New member Username: 555
Post Number: 4 Registered: Jun-05
| Posted on Thursday, September 01, 2005 - 05:35 pm: |
I CAN´T SEE PPV, HBO, PORNCHANNEL,DISCOVERY,ETC. IN DISHNETWORKS WHAT IS HAPPENNIG, MI LIFE TIME ULTRA SAY IN THE TV ¨SCRAMBLED OR BAD CHANNEL¨ |
| Posted on Friday, September 02, 2005 - 04:50 am: |
will we get the nfl games on their local channels? does anyone know yet? |
Bronze Member Username: Whatareyoudoing
Post Number: 24 Registered: Jul-05
| Posted on Friday, September 02, 2005 - 09:54 am: |
WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER”WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER”WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER”WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER”WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER”WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX WANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148 GTL-DXWANKER” WANKER” WANKER” WANKER” WANKER” WANKER”148GTL-DX |
MIKEY R Unregistered guest |
| Posted on Friday, September 02, 2005 - 12:44 pm: |
hey the guy above really must be a wanker. does anyone know if it is operation if the england vs. wales games is available on pansat |
MICKY R Unregistered guest |
| Posted on Friday, September 02, 2005 - 02:06 pm: |
the sad thing he is a registreed memeber so it wont be that hard for the admin to track him down to his home state then crack a 2x4 over his head. |
| Posted on Saturday, September 03, 2005 - 01:09 pm: |
where aree thee keysss peoplee |
New member Username: Ardvrk
Mississauga,
Ontario
Post Number: 1 Registered: Sep-05
| Posted on Saturday, September 03, 2005 - 02:48 pm: |
anyone have the Digiwave7000 files |
Don't Buy Pansat's Unregistered guest |
| Posted on Saturday, September 03, 2005 - 09:59 pm: |
We will say this, we do not trust any of those factories, Fortec and Pansat, all run and owned by the same peoples, sharing and controlling the market. Today is the fix for the Ultra, no, maybe in three weeks, yes ? We visited Al7bar-soft1.com, checked if there was any new updates, no. We looked into the Technical Discsussion Forum. Keep in mind this is Fortec, only. There was BlackList, making a statement that there will be no release for the Ultra until the clone issue was fixed, 2 to 3 weeks. So, BL represents both, Fortec and Pansat, no fixes until the Pansat2700a generates more sales. This well may be a hoax, but it did cause me to reflect on how all of us are controlled and manipulated by the factories, one of the same. We recommend no further support of Fortec and Pansat and C00lsat. We recommend a pci card, all the software is free without kissing azz, however not for everyone. We recommend, a Dreambox, but not for everyone. We have reservations in regards to the ViewSat, but possibly the best substitute
do not buy from efta.us Unregistered guest |
| Posted on Tuesday, September 06, 2005 - 07:23 pm: |
DO NOT BUY anything from efta.us or Pansat. efta.us is run by Pansat and they through their websites have distributed this file that kills all Pansats. Mine is dead and I now have to buy another thanks to this SCAM!!!!!!!!!!!!!!!! |
| Posted on Thursday, September 08, 2005 - 01:34 am: |
Alright, I get quite a few channels. My friend hooked me up with keyz that worked pretty good, but is there any way to get the PPV channels or what? |
| Posted on Thursday, September 08, 2005 - 10:48 am: |
JDoc, can you share the "keyz" Pleeease D |
| Posted on Thursday, September 08, 2005 - 08:53 pm: |
E1 FC 16 1C D7 F5 1F 48 FA 18 30 83 ED ED 5B AC |
New member Username: 2700
| Posted on Friday, September 09, 2005 - 05:46 pm: |
I bought a Pansat 2700a. I would like to know how can i see the channels from dish networks, What software i need and procedure on how to do it. I'm new to this. Please help. |
| Posted on Friday, September 09, 2005 - 05:51 pm: |
I bought a Pansat 2700a. I would like to know how can i see dish network channels. I have the dish hooked up. What else do i need. |
for luisfavarez Unregistered guest |
| Posted on Friday, September 09, 2005 - 05:54 pm: |
read,download,read,download,read,download,install bin, cry help, receiver is dead |
| Posted on Friday, September 09, 2005 - 05:57 pm: |
4 LuisFavarez Unregistered guest |
| Posted on Friday, September 09, 2005 - 06:11 pm: |
with the 2700 just goto al7bar .tk or al7bar .tc whichever one you want. Then get the bin file called X-87BL_050901_114_api.bin. Put this bin on your pansat with a current Blacklist loader which can also be found on these sites. You need to hook it up to your computer with the cable that hopefully came with the unit in order to put the bin file on there. After that just hook it back up to the dish and tv then go into the the menu and scan for channels. Now you have NAG1&2 up and running. |
New member Username: Help_me
| Posted on Friday, September 09, 2005 - 06:37 pm: |
is there anyone with a pansat 2500a that is still able to see ppv sports and ppv movies? |
FTA help Unregistered guest |
| Posted on Friday, September 09, 2005 - 06:50 pm: |
does anyone got new dish network keys for a multistar pantec ultra system?
