Thread: Dual DVD860 - Region hack |
New member Username: Zuke
Post Number: 1 Registered: Oct-05
| Posted on Saturday, October 08, 2005 - 01:54 pm: |
Power on Open Drawer 1369[0] - with 0 representing the multiregion code Standby/Power off Power on Setup 1379 - Comes up with the DVD info - This shows you that you have done everything correctly. Setup
Unregistered guest |
| Posted on Friday, October 14, 2005 - 07:20 am: |
Does anyone know if this player has a resume / last memory feature or if there is a firmware upgrade that would enabel this? |
Nath123456789 Unregistered guest |
| Posted on Tuesday, November 01, 2005 - 03:55 pm: |
Can anyone confirm this? Having a problem with the first bit... |
mark-spaced Unregistered guest |
| Posted on Thursday, November 17, 2005 - 04:41 am: |
this region hack works tested 17/11/05 cheers for that Brendan Zuke, you the man..... |
| Posted on Thursday, December 01, 2005 - 05:54 am: |
works a treat nice |
| Posted on Saturday, December 03, 2005 - 08:58 am: |
Yeah, works fine. Excellent! Thanks! |
| Posted on Saturday, December 17, 2005 - 06:00 am: |
Found this worked better: Open Drawer >Clear< 1369[0] - with 0 representing the multiregion code Standby/Power off |
| Posted on Tuesday, December 20, 2005 - 08:30 am: |
Hi there First time on this forum...just brought myself a Dual DVD 860! Can someone talk me through this hack, the 13690 numbers? do I just type these in or am I suppose to be able to see the numbers somewhere? Would really appreciate some help. Thanks in advance |
| Posted on Wednesday, December 21, 2005 - 06:08 pm: |
Just type them in. (The only way you know it works is by doing the second part from the original post.) |
| Posted on Friday, December 23, 2005 - 03:32 am: |
nice one worked perfectly thx |
