Thread: Archive through September 29, 2005 |
New member Username: Chico
Post Number: 3 Registered: Sep-05
| Posted on Tuesday, September 20, 2005 - 09:02 pm: |
i have the latest file for my cool*at 4000 pro but i am missing a few channels (ex. o*l*n & esp*n news) but i have all the others channels. does anyone have any ideas? |
Silver Member Username: G3n0cyde
Post Number: 143 Registered: Aug-05
| Posted on Tuesday, September 20, 2005 - 09:35 pm: |
Mike Partridge. What kind of receiver do you have bro? Email me. mic69hael@gmail.com Chico. If you have the latest Cool Sat bin, you would have all channels. So the answer is no you don't have the latest bin or you have and this is more likely a cloned Cool Sat. I'm sure of it. 99% of the Cool's out there are clones. |
| Posted on Tuesday, September 20, 2005 - 10:01 pm: |
All I can say is the person BlTCH BOY needs to grow up and stop talking like some cool azz dude with a foul mouth. Either get with the program on this thread or go back to school and learn how to speak/write. If I were a mod, he'd be banned from this site. |
Post Number: 5 Registered: Sep-05
| Posted on Tuesday, September 20, 2005 - 10:11 pm: |
mc how can you tell if my FTA is a clone or not. also after i download the latest bin do i have to put in the latest keys. |
Jim Jim Unregistered guest |
| Posted on Tuesday, September 20, 2005 - 10:41 pm: |
I Gotta Fortec lifetime Ultra. Do I have to load a old factory binfile before I load the 281 bin? The old file is 280 bin. I was told to also do a factory reset.Is this correct?There are a lot of different instuctions out there. I also need the old factory bin file,I do have the new 281. Thank You All. |
| Posted on Tuesday, September 20, 2005 - 11:04 pm: |
PS.,I ment to say that I need the original bin file,I only had the 280 loaded when I got the reciever. |
cosmeguy Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 08:38 am: |
more info abou the future of plastic and nagra2 |
PRFRMNJ Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 11:41 am: |
MC - I still get freezing on some channels and I've tried just about everything. Not that I'm complaining, but it seems someone knows how to fix this (it just isn't me). I've loaded the original 272 bin and did a factory reset. Then loaded the 281 bin and did a factory reset. Then I loaded my channel list, but the same channels keep freezing up. Any suggestions? |
Post Number: 144 Registered: Aug-05
| Posted on Wednesday, September 21, 2005 - 12:40 pm: |
2 channels freeze solid after 10 seconds. FNTSY and TXTSY. Other than those, there is minor glitching on a few channels but nothing severe. The next update should have the freezing fixed. new email is ftatoronto@hotmail.com Website building has started, and is still under construction. It will be an information based website with links to major sites and install info, set ups etc. Should be good when it is complete. I'm in the process of password protecting it this week. Those in my address book will be invited. I expect the site to be up in a couple weeks. |
Silver Member Username: Vibr84me
Winnipeg,
Manitoba
Post Number: 227 Registered: Aug-05
| Posted on Wednesday, September 21, 2005 - 01:32 pm: |
You should not be getting any freezing on any channel - there are some minor gliches - pixelation and key generation but not a frozen picture! If you are experiencing this tell me what kind of receiver you have and what fix you are using as well as the switch config. |
Post Number: 145 Registered: Aug-05
| Posted on Wednesday, September 21, 2005 - 01:44 pm: |
Vibe. 2 adult channels freeze solid after 10 seconds. This has been documented by programmers. It will be resolved with the next fix. My systems are Cool sat 400 pro, Lifetime Ultra and Dream Box, but you know this LOL. |
FNTSY freezes Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 01:55 pm: |
I have a fortec lifetime ultra and it is doing the samething freezing up after about 10 seconds on FNTSY then goes to a scrambled channel message for about 5 seconds and then black for 5 seconds. It just repeats this cycle. Other channels work ok with occasional glitches. Is everyone else with a fortec having this problem? |
| Posted on Wednesday, September 21, 2005 - 02:45 pm: |
Vibe & MC - I have a Fortec and yes, that's about what's happening. I only asked to see if anyone had a solution I didn't know about. Thanks for the info! BTW MC - Don't forget to include me in the selected few! |
Post Number: 146 Registered: Aug-05
| Posted on Wednesday, September 21, 2005 - 03:00 pm: |
No PRF. At this time there is no fix, but my sources tell me that issue will be fixed after the next update. |
Bronze Member Username: Skyboy
Post Number: 23 Registered: Sep-05
| Posted on Wednesday, September 21, 2005 - 03:02 pm: |
What is the latest bootfile for fortec star lifetime ultra NTSC? Is it version 6.1 or 6.0? Do they update when you download the newer bin files? Thanks |
| Posted on Wednesday, September 21, 2005 - 03:18 pm: |
MC or Vibe, I have a Stealth ST2000a, do you know if any files work on this receiver for Nagra2? If so, can you provide me with instructions and files? Thanks. |
| Posted on Wednesday, September 21, 2005 - 05:30 pm: |
You guys that have freezing, need to install a heat sink on processer or small cp fan. This is whats causing freezing, too much heat.Find out how to do it yourself at Al7bar .tk |
Post Number: 147 Registered: Aug-05
| Posted on Wednesday, September 21, 2005 - 05:38 pm: |
Thanx anonymous. I am going to be using a Pansat 2700 Original to test with. Keep us posted. |
salvator Unregistered guest |
| Posted on Thursday, September 22, 2005 - 12:51 pm: |
I HAVE PANSAT 2500A WITH CHIP : STi5518BVC is clone or not and bin please. |
Post Number: 148 Registered: Aug-05
| Posted on Thursday, September 22, 2005 - 01:14 pm: |
salvator. As long as you do a couple factory resets before botting and loading, you should be OK. If it burns out, you will know it's a clone. There is no other way, to my knowledge, to confirm whether it is or not. Good Luck!!! |
| Posted on Thursday, September 22, 2005 - 02:38 pm: |
Do anyone have the update bin file to fix the freezing channels? |
Post Number: 149 Registered: Aug-05
| Posted on Thursday, September 22, 2005 - 02:48 pm: |
It will be released as part of the next fix. After we go down. |
Bronze Member Username: Jspeeney011480
Post Number: 22 Registered: Sep-05
| Posted on Thursday, September 22, 2005 - 03:37 pm: |
I was searching the web yesterday and came across extrememicro.com. I have a fortec ultra. The website gives youa new n2 download and a complete channel list. I followed the instructions and at the end of the instructions it says hook back up to tv and everything comes in. I did that and all I get is black screens and messege saying scrambled channel or bad signal on every channel. Do I have to perform a scan or is there something wrong. My dish is getting 99% as I have a birdog meter. Can anyone help me with this? Should I do a factory reset and then flash with new bin. Please help. |
Post Number: 150 Registered: Aug-05
| Posted on Thursday, September 22, 2005 - 03:50 pm: |
First problem, is getting the files off the net instead of through a reliable source or a moderated members site. 2nd. Yes you have to scan all channels. read the antenna set-up in your manual and instead of using FTA to scan Press right and switch to ALL then scan. What bin are you planning to load? And using what to load it? |
lostwith-tv Unregistered guest |
| Posted on Thursday, September 22, 2005 - 03:52 pm: |
I saw that download yesterday too. Didn't do it because it said for fortec lifetime ultra and I have fortec Star lifetime ultra. Wasn't sure it was for my fta or not. Let me know if you get it working and if you have a star version. Thanks |
| Posted on Thursday, September 22, 2005 - 04:06 pm: |
Ok If i do a scan which scan should I use? There are a few scans on the menu not sure which to use. I am planning on loading N2-ultra-9-20-05. the loader i am using is al7bar*tk stb updater. Also i do have a fortec star lifetime ultra. |
Post Number: 24 Registered: Sep-05
where can i find factory bin for fortec lifetime |
Post Number: 151 Registered: Aug-05
| Posted on Thursday, September 22, 2005 - 04:32 pm: |
ok quickly menu right antenna set-up choose your satellites one at a time. when checked OK brings you to sub-menu lnb std khz off disecq is whatever ports match your switch connections out side. coax 1=port 1 ts=...-20.000 high sig quality where it says FTA... Press right til you see ALL not ALL+D and now scan. Do this for each satellite dish. 110, 119, 121 etc. Scan takes about 30 minutes per satellite do not interrupt it. THOSE OF U WITH FORTEC LIFETIME ULTRA'S, MAY WANT TO COPY N PASTE THESE INSTRUCTIONS. |
Post Number: 152 Registered: Aug-05
| Posted on Thursday, September 22, 2005 - 04:33 pm: |
Use a blklst loader |
| Posted on Thursday, September 22, 2005 - 06:45 pm: |
I tried to flash my Fortec Lifetime Ultra with all the uploader programs but everytime it says "writer failed" or "model not correct" mirza090@hotmail.com |
| Posted on Sunday, September 25, 2005 - 10:31 am: |
hello guys, just had a question. I have a multistar Reciever, PF2500. I wondered what file should i put in it, to make it work for nag, and wat uploader should I use? |
Post Number: 154 Registered: Aug-05
| Posted on Sunday, September 25, 2005 - 02:05 pm: |
I'll help with that Multistar user. Use a Digiwave 7000 bin dated after 09/14 and use the FTLink 3.4 loader. Enjoy... |
| Posted on Monday, September 26, 2005 - 11:09 am: |
I got same problem as adaad (to flash my Fortec Lifetime Ultra with all the uploader programs but everytime it says "model not correct") I even did backup to factory 247 bin, and then tried upgrade to 281 bin and got "model not correct" message again. Please help ts520_steve@yahoo.com
Post Number: 155 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 11:18 am: |
Are you in Toronto Steve. I tried to email you but your address sz yahoo.com doesn't exist. |
Post Number: 27 Registered: Sep-05
| Posted on Monday, September 26, 2005 - 12:07 pm: |
I have a birdog satellite meter. I was having trouble with my fortec, so I pulled my birdog out and started testing the lines. I found out that from the dish to before the disecq switch is good. 99% signal. I tested after the switch and got nothing. How fast do these switches burn out? I just bought it less than a week ago. |
| Posted on Monday, September 26, 2005 - 12:35 pm: |
Necesito ayuda con un Stealth St2000a. Need help with a Stealth St2000. Not sure if this is a clone to any of the working fta. |
ts520_steve Unregistered guest |
| Posted on Monday, September 26, 2005 - 01:01 pm: |
Thank you MC, I'm in Montreal. my email ts520_steve@yahoo.com works fine, please try again. Vibr8tor Guy, what do you mean default key, how can I code for loading it? thank you! |
Winnipeg,
Manitoba
Post Number: 231 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 01:10 pm: |
Encryption specialist Nagra Kudelski says its 'Aladin' smart card version has been compromised. There have been widespread reports of a hack, especially in Spain where it is the card of choice for Sogecable's DTH service Digital+. CEO Andre Kudeski confirmed two weeks ago that Aladin represents some 70% of its business, as of June 2005. The company's biggest customer is Echostar's DiSH DTH system in the US, while Canada's Bell ExpressVu is another major. Between them they have taken some 11.7m cards. A report from investment bankers Credit Agricole Cheuvreux talked last week of Kudelski planning electronic counter measures to cure the hack: "It is still very possible that the hack will not stand up to the electronic countermeasures," said the bank's note. However, the bank warns of several negative implications for Kudelski, not least the firm's basic reputation given that much has been staked on this iteration, as well as churn amongst clients with players like NTL and Telewest planning on switching to the system. "Under Kudelski's new rental model," said the bank report, "the cost of swap-outs, which would be automatically triggered by piracy, is borne by Kudelski. We estimate that around 11-12 million cards are currently on the rental model (including the Premiere and Canal+ platforms)." These direct costs could amount to SFr50m, suggests the bank. A Nagra source, speaking at IBC, said the original 'Aladin' card was issued in 2000, and was now in its 5th year of use for some clients. "We are already well advanced with swapping out and upgrading that card with only a few hundred thousand cards to go. This was always planned to be completed by about the end of this year." Our source said that 'Aladin' was a suite of products on which there had been a "small" problem. "This is never a small problem for our clients, however. We spoke to our customers in a timely fashion, and initiated our upgrade plan." -- Just so you know the last paragraph is about rom 10 and 11 cards the first ones are the rom 101 102 103 cards
Winnipeg,
Manitoba
Post Number: 232 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 01:37 pm: |
The rumors should be flying by the end of the week - Directv has been hacked cracked and canned - but when can we get it?? I'm still hearing October and I hope this is true. Again I have no proof only that a person here has shown me a working system and I have no idea how it works - it may be a dupe! I hope not. |
Post Number: 156 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 03:39 pm: |
Heads up... All you end-users that are loading up your Ultra's with pansat fixes are damaging your systems. I know you want to end the freezing but you're killing the firmware. What i have heard from mods on Al7bar, and programmers alike are... By loading this bin you are turning your receiver into a cloned Fortec and unfortunately, this can't be reversed. It also voids your warranty on the box. i have already heard of ppl frying the Ultra's as a result of going to the new bin then trying to reload the 281. Just be careful and don't ruin a great thing. If you have channels leave it at that and remember a fix is coming for the freeze issue. Vibe, don't mean to be a nay sayer dude. I'm hearing the opposite regarding Direc. There is NO timeline as to when or IF we will ever see Direc back up and running. Direc is running on a much more advanced Nagra program. But again, things change daily. No one would be more extatic than me to have good ole Dave back in full form along side Charlie. Keep your RG-6 cables crossed, but not the spotbeams. |
Post Number: 157 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 03:44 pm: |
Still ain't workin bro... This is an automatically generated Delivery Status Notification Delivery to the following recipient failed permanently: ts520_steve@yahoo.com Technical details of permanent failure: PERM_FAILURE: SMTP Error (state 12): 554 delivery error: dd This user doesn't have a yahoo.com account (ts520_steve@yahoo.com) [-5] - mta219.mail.mud.yahoo.com |
TINY TONY Unregistered guest |
| Posted on Monday, September 26, 2005 - 03:48 pm: |
I HAVE A QUANTUM 4000 PLUS,DOES ANYONE KNOW WHICH BIN CAN I USE FOR MY SYSTEM . THANK YOU |
Post Number: 158 Registered: Aug-05
| Posted on Monday, September 26, 2005 - 04:02 pm: |
Quantum is a clone. You may be able to use a Pansat 2700 or Digiwave 7000 bin. Check with a local programmer to be sure, or the person who sold it to you. |
| Posted on Monday, September 26, 2005 - 04:13 pm: |
Sorry MC my email account is ts520_steve@yahoo.ca Thank you again! |
1 Tina Chick Unregistered guest |
| Posted on Monday, September 26, 2005 - 10:55 pm: |
What about a new flash for Cools@t 4000 p on N2 ? |
| Posted on Tuesday, September 27, 2005 - 11:57 am: |
There is a new bin file out 282 for the Lifetime Ultra (NTSC). It's available on the Al7bar web site. I haven't tried it yet, but it's supposed to correct the freezing problems with some channels. I'll be flashing with this file later today and let everyone know if it works. If anyone has already tried it, let me know how it worked for you. |
Post Number: 159 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 12:13 pm: |
PRF. Let me know when it has been confirmed. Does it use the same loader and same method. Any other steps involved in comparison to the 281? Just load and go so to speak??? |
| Posted on Tuesday, September 27, 2005 - 01:27 pm: |
MC - I'll post my resolts later. I'm still at work and won't be able to work with this until later this evening. Just for the record, I've used both the Fortec STB Loader and the Blacklist STB Loader. My personal preference is the Blacklist STB Loader. |
Post Number: 160 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 01:44 pm: |
OK I have confirmation. My MOD friend on Al7 confirms that this bin is a modded 282 and it works. You may need a special loader which i am still in the process of solidifying the truth. The new bin 282 does work. After installing. menu=Fortec screen not Pantec etc. It is legit and DOES fix the freezing issues. TY PRF for the info. |
Jenevie Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 02:31 pm: |
What is a SPDIF port? I have toslink optical port, is there some kind of adapter? thanks |
| Posted on Tuesday, September 27, 2005 - 02:48 pm: |
MC- Is this new 282 bin work for Fortec Ultra clone? |
| Posted on Tuesday, September 27, 2005 - 03:24 pm: |
for apansat2500a al u need is the 254 bin file download with gtools mines been working for aweek know 24/7 |
Post Number: 161 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 03:34 pm: |
No Fortec Ultra bin is for the Fortec. It may work on a clone but it was tested on original Lifetime Ultra's and works great. SPDIF is for 5.1 sound. Unfortunately I don't know how to use it on the Fortec Lifetime Ultra yet but thatz what it does. |
| Posted on Tuesday, September 27, 2005 - 04:05 pm: |
Wow.I flashed the new 282 and I lost all but one (1900 radio) radio stations,still only 2 HBO's,and no MTV.When I look at the bottom of the screen,the info says either nagravison of free.Is'nt it suppose to also say nagravision 2? My programing never has but I hear that most channels went to nagra 2.Is there something other than the flash I'm not doing right? As far as loading it,guess what I found.If you unzipp the file then either put the file or zipped file in a seperate folder(away from each other),the fortec updater will work also in flashing.Seems that that updater goes after the zipped file when both are on desktop of in folder together even though you choose the unzipped file,in my case anyway. Thanks. PS,wass up MC,Vibe.
Post Number: 25 Registered: Sep-05
| Posted on Tuesday, September 27, 2005 - 04:18 pm: |
Oh yea,the file I got is from the the Al7bar web site that PRFRMNJ mentioned. But remember,when you flash you flash at your own risk. |
Post Number: 162 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 04:21 pm: |
Ronald. waz up to you dude. OK. New bin. Great idea to move the file to a diff hardrive or another area of your pc before loading. Use BlkLst loader. When it says OK. Re-scan all your satellites one at a time. make sure you choose the option to scan ALL not FTA, FTA+D or ALL+D. And yes, Nagravision means Nagra 2 so you're hooked up. |
Post Number: 26 Registered: Sep-05
| Posted on Tuesday, September 27, 2005 - 04:26 pm: |
Will do MC,Thanks as always. You and Vibe's advice is always on the money! Some of us really appreciate the help! |
| Posted on Tuesday, September 27, 2005 - 05:03 pm: |
Hey Guys, Just wanted wer can i find the new bins that become available free, cause i cant seem to find anywer that have the bins. Plz give the exact URL |
Post Number: 163 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 05:16 pm: |
www.al7bar.com |
| Posted on Tuesday, September 27, 2005 - 05:58 pm: |
C/P,,,,,,Heck with that 101, and the 102 for that matter ...... has anyone seen the new white ( some blue ) progammable cards with the perforated CPU's ?? Not only will they work in FTA, but since they come unloaded and empty you simplt take the new programmer, take the base tier package from the Rom 101 or 102 dump that no one really wants to release at this point and you use a new tier maker ( soon to be released ) and a Valid Cam ID, enter your Boxkeys and VALID Ird # and you just did your very own card. Since its VIRGIN you get to put in the revision, place the blocker ( which is the only issue I foresee ) and see if Charlie can hit it or not .... and best of all they are UNDER $100 USD. Just remember you read this thread here first and mark my words, you'll see these for everything from Coolsats to MOST Echo IRD's as well ....... The future is before us, and the guys on this project are like dollar store people, they are not looking to make a fortune per card, just sell 250,000 cards........and the GUI to run it will be everywhere....... best of all if you screw it up, you can get a new card alone for about $50-60 USD. Coding as we know it is changing, cause them " Furriners " ( Bush accent ) will sell it soooo cheap, everyone will want at least 3. do some research and you'll find it just being released at a Sat wholesaler near you............
Post Number: 164 Registered: Aug-05
| Posted on Tuesday, September 27, 2005 - 10:28 pm: |
alanc. Big problem with that. It all sounds good but once you program the card and put it in the datastream... You can not reprogram it after an ECM. Just a heads up. Fortec Ultra users. I have confirmed the new bin 282 that fixes the freezing. I am now running it myself. No freezing on FNTSY or TXTSY. matter of fact. No freezing on Tele Future Telemundo etc. You get the drift. Load at your own risk tho. It does work if you know how to professionally loan a bin. |
LOST IN ORBIT . Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 11:36 pm: |
Mr Mc. and Vibr. With our present HARDWARE can we change transponder designations as fast as N2 can do it? |
BITE-ME Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 11:52 pm: |
-MC-Bend over and u will never freeze up gain because Iam going to pump u full of come!!! |
| Posted on Wednesday, September 28, 2005 - 08:54 am: |
MC and all others - Sorry I didn't get to post last night, but the 282 bin does work and all freezing has gone. Word of advice! Although I have scanned all sats for signal and haven't had a problem, it's best if you load a channel list. I have a good channel list if anyone is interested. (110 & 119). Additionally, I have found that reseting factory settings before and after every flash cleans any mess left behind on your receivers. Last butt not least. I've used a few loaders and I find that the easiest one to use is the Blacklist STB Loader. I use gTools to load the channel list. |
| Posted on Wednesday, September 28, 2005 - 09:10 am: |
hey PRFRMNJ, where did you find the channel list for the fortec lifetime ultra |
Post Number: 166 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 10:22 am: |
PRF. Yes the 282 works great. Email me the channel list dude and instructions on how to load it. I believe I have GTools but email everything I need so I can be sure. mikecda@hotmail.com I know the average person wouldn't get the things I asked for, but I'm sure that for me you can do that. |
| Posted on Wednesday, September 28, 2005 - 12:04 pm: |
Anonymous - I found the channel list at DSS-Testers. MC - I just emailed you the files and instructions. Let me know if you need anything else. |
Post Number: 28 Registered: Sep-05
| Posted on Wednesday, September 28, 2005 - 12:20 pm: |
Hey PRFRMNJ can you send me channels list please. email at jspeeney011480@aol.com. Thanks. |
Post Number: 167 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 12:31 pm: |
If anyone wants lists, files etc. Go to the website PRF gave you and register. We are not providing info or files that is readily available free of charge on the net. PRF and I share files which is why I requested the email. DO NOT BOMBARDE PRF with requests. Go to DSS TESTERS and register. Pay the $$$ and put a smile on your face. Or be a jabroni and use the free untested files available without paying LOL. These ppl are called end-users. |
| Posted on Wednesday, September 28, 2005 - 01:25 pm: |
MC - I loaded 282 bin and everything works great, but I lost MTV, did I do something wrong?? |
| Posted on Wednesday, September 28, 2005 - 01:38 pm: |
MC - You beat me to the punch! LOL For everyone else, please get these files from the DSS Testers! My files are no different other then that they have been tested. I don't mind helping out and pointing you in the right direction, but please don't ask for files you can get just about anywhere. Oh and yes, if you don't pay to register, you will be downloading untested files, so read the threads before you load anything. |
Post Number: 168 Registered: Aug-05
kma. could have deleted in the channel menu by accident. rest assured all channels do work. I even got the MLB channels to actually show baseball LOL. |
Post Number: 169 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 01:48 pm: |
PRF. Is there an echo in here. |
| Posted on Wednesday, September 28, 2005 - 01:52 pm: |
MC - Must be! LOL |
-NO-SHAME- Unregistered guest |
| Posted on Wednesday, September 28, 2005 - 02:37 pm: |
-MC-Loves little boys!!!!!!!!!! M Jackson told me that him and MC use to touch little boys dickeeeeeeeebirds........ |
Post Number: 170 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 02:53 pm: |
Does anyone if the channels that are changing over at the end of the month from Nag 1 to nag2. Are these channels available on our current FTA nagravion or are there still pending channels to be crossed over. I know that DN completes their conversion this weekend so we may all drop like flies. Don't say I didn't warn ya. It is temporary tho. |
| Posted on Wednesday, September 28, 2005 - 02:59 pm: |
MC, I have the same question...Is there is a fix for N2? If it is how can I get it. Whats the latest firmmware for Fortec Ultra receiver and the channel list? Please help... |
Post Number: 171 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 03:09 pm: |
JDP. Are you in Toronto? |
| Posted on Wednesday, September 28, 2005 - 03:14 pm: |
No |
| Posted on Wednesday, September 28, 2005 - 03:18 pm: |
MC, can you help me please and advice too..? |
| Posted on Wednesday, September 28, 2005 - 03:25 pm: |
PRF can you help me in getting the N2 firmware (if its out) or the latest firmwre and the channel list? |
Post Number: 172 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 03:31 pm: |
Itz difficult to help you if you aren't local. You have to get the load, bin and cable and then upload to your receiver. I don't know if you have a clone or what so I can't recomment you doing it. Email me mic69hael@gmail.com |
| Posted on Wednesday, September 28, 2005 - 07:39 pm: |
Thanks MC, I rescan and got my MTV back, On a different note, I'm trying to help one of my friend who has a Multistar Pantec Ultra, I did a little bit of research on it, and now I'm more confused then before I started. I'm trying to find the bin files that'll work for it, some say its the pansat 2500 bin, some say its the same as the fortec lifetime ultra. Who is right???? Help! |
| Posted on Wednesday, September 28, 2005 - 09:31 pm: |
-MC-As a class place to live....Its the Don Jail (He-Ha-He-Ha)....He goes there every nigh to to get his azz screwed...He loves the boys dick in his azz....I also understand he gives good head......(He-Ha-He-Ha) |
Post Number: 173 Registered: Aug-05
| Posted on Wednesday, September 28, 2005 - 10:15 pm: |
KMA. Neither of those dude. Email me mic69hael@gmail.com I don't publicly give out file info due to the kmc's LOL. let em find their own shiz!!! |
| Posted on Wednesday, September 28, 2005 - 10:56 pm: |
where can I get a GTD file for gtools? |
| Posted on Wednesday, September 28, 2005 - 11:38 pm: |
Thx MC for the site, so I have a Multistar 2500 PF. If i wanted to program my reciever, so can i put the fortec files from the site or I need something else? An Can i also use the black loader software? |
Joe TTTTTTTTT Unregistered guest |
| Posted on Thursday, September 29, 2005 - 12:28 am: |
Where do I find the 282 bin on Al7bar.com? Can someone e-mail it to me dprofili@hotmail.com.
| Posted on Thursday, September 29, 2005 - 08:54 am: |
jdp - The firmware files are all available at the Al7bar website. Just make sure you download the right file! |
Post Number: 174 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 10:34 am: |
NO MORE ASKING FOR FILES. You were told where to find them. Register on the site you were told to. The files are untested if you don't pay. I will not give out files, that you can register and find yourself. No offence but this is a forum not Kazaa and if you want the goods... GO FIND EM!!! This includes bins and loaders. If you have questions, email me at mic69hael@gmail.com or if you are in Toronto area, maybe I can help you out. |
| Posted on Thursday, September 29, 2005 - 10:36 am: |
PRFRMNJ, thanks for the info, my email is jagathp@yahoo.com, if you have the firm where and the channel list is it possible to email to me.. (Hi PFR, Thanks for replying to my mail. Yes I have the cable and I know how to upload the file to the receiver too. I have done this, but I do not have the latest file and the settings for me to get all the channels including ZEE tv,PB and the PPV etc. Even I do not have the MTV. I would very much appreciate if you could help me out. I have 110,119 and 61.5 installed. Please let me know the Antena setup too. Thanks a Million.... JDP)
| Posted on Thursday, September 29, 2005 - 10:49 am: |
Thanks MC, I tried few times loading the files,each one of them had their own problems, thats he reason I asked the expertice for the files. No offence but appreciated if helped. Thanks.... |
Post Number: 175 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 10:56 am: |
JDP. You emailed me the same thank you as PRF. Did one of us give you bin files. I know I didn't. I did answer a few questions for you but no distribution. You don't have to thank us. We're here to help. |
Post Number: 176 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 11:10 am: |
JDP. Email me your issues. mic69hael@gmail.com We'll talk |
Post Number: 177 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 03:17 pm: |
ZYME. You got it dude!!! |
PRFRMNJ the man Unregistered guest |
| Posted on Thursday, September 29, 2005 - 03:33 pm: |
OKay, MC doesnt mind asking/getting files from PRFRMNJ but doesnt't wanna share. Like you said, MC, go find them yourself, too!!! |
Post Number: 178 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 04:20 pm: |
PRF clone. Already have all the bins and I provide em to the real PRF. Sux to be you I guess. He provides me. I'm sick of all the spoon fed newbies that are just hoping that free files will work. And when they don't, you cry like a 2 year old. Those who know me, know that I am very supportive. You wanna cry. GO TO HELL or just keep jivin' if ya feel better. Either way, SUX TO BE U |
Winnipeg,
Manitoba
Post Number: 233 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 05:04 pm: |
play nice |
Post Number: 179 Registered: Aug-05
| Posted on Thursday, September 29, 2005 - 05:10 pm: |
LOL Vibe. Good 2 see ya. Howz the weather out there bro |
