Thread: Panasonic DMR-EH50: scrolling through schedule |
Bronze Member Username: Gi58
Florida
Post Number: 21 Registered: Sep-05
| Posted on Friday, September 30, 2005 - 10:20 am: |
When I'm looking at the TV Guide program listings, it seems that the only way to move ahead in time is to scroll sideways one click at a time, a half hour per click. This can be a pain if the show you want to schedule for recording comes on 36 hours from now. Anyone know if there's a way to go directly to the desired time? |
| Posted on Friday, September 30, 2005 - 11:30 pm: |
Guy, When in the guide scroll all the way up to the top. Then a little +24 and -24 should appear which are activated via the respective green and blue buttons on your remote. xvxvxvx |
Florida
Post Number: 23 Registered: Sep-05
| Posted on Monday, October 03, 2005 - 08:40 am: |
Thanks! I'll look for that tonight. It's not as good as being able to enter a date & time, but it's certainly better than going through every hour between now & the target! |
| Posted on Monday, October 03, 2005 - 04:06 pm: |
You bet it is!! I tried it last night and found if you scroll all the way to the top when in the guide menu until the "LISTINGS" selection is highlighted. Then the +24 will be visible and the green button on your remote will advance 24 hours at a time. After you have gone forward at least 24 hours the blue button will move you back 24 hours at a time. Good luck, xvxvxvx
Florida
Post Number: 25 Registered: Sep-05
| Posted on Tuesday, October 04, 2005 - 11:17 am: |
Found it; works as 'advertised.' This will make my recording life easier. Thanks! |
| Posted on Tuesday, October 04, 2005 - 12:01 pm: |
You are welcome Guy. xvxvxvx |
