Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Channel display order on Panasonic DM...
Author Thread: Channel display order on Panasonic DMR-EH50
Username: Gi58
Florida
Post Number: 17
Could be I'm just blind, but I didn't see this in the manual. When I'm looking at program listings in the TV Guide menu, the channels are in some odd sequence, determined by who knows what. I want to get them into numerical order. Does anyone know how to do that?
fx
Guy,
It is in the manual and I have done it but is too complex to do from memory. It seems like you go to the setup portion on top of the screen and then select from the choices but I'm reallly not sure about that. If it wasn't Friday night I'd look it up for you but you are on your own on this one.
xvxvxvx
Username: Gi58
Florida
Post Number: 24
I'll haul out the manual again and first try to figure out why I didn't see it the last time I looked. :-) Then I'll work on reordering things to suit.
Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Channel display order on Panasonic DM... [ « Previous ] [ Next » ]
