Thread: Panasonic vcr no input |
New member Username: Nitinrk
Post Number: 1 Registered: Sep-05
| Posted on Thursday, September 29, 2005 - 04:24 am: |
everything working ok accept video recording. shows no audio/ vedio input signal trough av 1-2-3 inputs. seems to me a software probelm. where can get the free software and manual fro my panasonic nv-mv40 vcr. or any solution. regards |
Gold Member Username: Samijubal
Post Number: 1675 Registered: Jul-04
| Posted on Thursday, September 29, 2005 - 01:16 pm: |
Are you changing the input on the VCR? Just connecting something to the line inputs doesn't set the VCR to line. If there is an input button on the remote, use it. If not, go through the channels till you get to the right input. |
Post Number: 2 Registered: Sep-05
| Posted on Friday, September 30, 2005 - 12:33 am: |
yes i have checked input setting and basic fault finding. |
Post Number: 1679 Registered: Jul-04
| Posted on Friday, September 30, 2005 - 11:34 am: |
It's possible the connections were never soldered. I saw it happen once before. |
New member Username: Acgang
Post Number: 1 Registered: Mar-06
| Posted on Sunday, March 12, 2006 - 07:21 am: |
Lost remote and can't find the right way to input line mode to play dvd, and gamecube videos. So I'd need help to select line mode on my Panasonic VHS cassette player. Model #PV-9455S Thank You Al Cornwell |
Post Number: 2421 Registered: Jul-04
| Posted on Sunday, March 12, 2006 - 11:34 am: |
Try going through the channels and see if you can get to line. If not, you need a remote. |
