Home > Message Board > Home Video > Rear Projection TVs > Mitsubishi tv problem > Archive through July 25, 2005
Author Thread: Archive through July 25, 2005
John Ranger
50" Mitsubishi approx 10 yrs old; twice in a week.....just goes off, no pix, no sound, black screen
turn off few min. turn back on....it's fine
no problem before this
is it worth checking out or should just replace?
Relevant Product Info
Username: Paul_ohstbucks
Post Number: 526
Only you can decide. At 10 years old, it has served you well........IMO...Just replace the darn thing. It's not worth anything anyway.......so why pay a lot to fix something that is worth very little.
Go HD....you wont regret it!!
rb952
PAUL:
Can you help with the codes to unlock the video inputs?
I have a mitsubishi tv that is about 6 or 7 years old and i have perfect sound but no picture... i can see the menu and volume on the screen but nothing else any sug.?
Post Number: 651
Call a service tech.
I have a 55" widescreen that I have had for about three years. Everything is fine but the color is off. Sometimes, it comes on with full color, then, in an instant, or very slowly, it turns to a reddish brown tint. 95% of the time, the tv is in the reddish brown tinted color. It is pretty large so i haven't taken it to a repair shop yet. Does anyone have any idea what the problem may be and a cost?
Post Number: 683
Mrs Jones,
For about $50-75, service techs make house calls. Only they can answer your questions.
Good luck.
Username: Joe_c
Oakwood, Ga
Post Number: 191
I have codes for service menus on newer mits rptv's but use at your own risk, lemme know if you want them.
I have a wt-46805 mitsubishi rear projection tv (HD 1080 series). 4 years old.
It has the image deformed like an horizontal hourglass and the convergence is bad. Can you give me some tips where to start look/check for fixing it? I'm an electr. eng but not experienced in tv repairs.
Username: Joe_c
Oakwood, Ga
Post Number: 201
service menu but like I said you need to be very careful. If you decide you want to ry and mess with the settings , make sure you write all the old settings down before you change each one. You can fix the shape of images on the screen as well as advanced convergence. Basically every adjustment can be made in that menu. I am not sure about your specific model, but try : menu button, 2,1,5,9 or menu, 2,1,5,7 if these don't work lemme know but once more please be carefull. I will assume NO responsibility if you screw you tv up.
Post Number: 706
tips?? Where to look?? Why not start with your owners manual?
Too many people ask for help without putting the slightest effort into educating themselves on their own first. Im not about to download the pdf file for the WT-46805 to do your reading for you.
If you had read your manual and asked a specific question, you'll get much better response.
Steve from wolcott
I purchased a new WS62525 Mitsubishi. Only after a few months I notice spots on the picture. I called for service, and they told me dust was in the light engine. Upon replacing the light engine, the spots were still there. The serviceman, with my help, proceded to remove the front of the TV. A mirror at the base was covered with dust. I assumed the front of the TV would have been sealed, but is is open at the bottom. Talking with Mitsubishi, I am the only one who has this problem (Hard to believe). I am now starting to see small spots again. Has anyone else has or had this problem?
I have a mitsubishi projection t.v. ts-50611. Picture perfect, sound still great but after a few seconds after turning the power on it goes off!! I can still hear the t.v through my sony audio video control center. I've read the manual twice and tried everything but there's no mention of this kind of problem? Anyone out there can help? Please!!!
i have a Mitsubishi TV modle CS-27305. I turn on my Tv & it says parently code. If anyone has the code or knows how i can get this off please let me know.
I have a Mitsubishi tv Model CS-27305 August 1995 M1GA. The parental lock is on & don't know how to shut it off. I have no manual for the TV, Is there a way to over rid it? PLEASE HELP!!!!!!!
pinkstir222002@yahoo.com PLEASE!!!!!!!!!!!!
I have a 65" diamond series HDTV and I can't figure out how to turn off the closed caption when it is broadcasted and I don't want it on my screen. I've looked through the manuel and it not clear how to turn it off. Can it be done with the remote?
Toudeshki
Ken Baldwin,
Go to menu, go to captions and on "Analog caption' or "digital caption" you can turn them off or on or... Page 62 of your user manual.
Big Screen Owner
I have a Mitsubishi Model#VS524RS,with a Model#VE524RS screen and I need a repair manual for it. I live in the Buffalo,Rochester N.Y. area. Any chance I could find one?
Hello Paul,
I have read all over the internet about the same problem I have. No one seems to have an answer. I have a Mitsubshi VS-6047. The problem is the red tube is way off. I tried to degauss with a coil. It helped, but did not fix. The red has an hour glass like image. It concaves at the top,bottom and sides. Attempted changing the tube angle. NG!
When I try to align using convergence, the red will not move up or to the left enough. On the top right, the red is way down to the right. On the top left, red is down and left. At bottom left, red is down left. At bottom right, red is down right. It seems that red is saturated. Without a schematic, I have no way of testing. I loved the older sets with the schematic printed on the cover...lol. From experience, my thoughts are the red tube. Without a schematic, I am not sure.
Looking in the back there is what appears to to be a driver board on the back of each tube. I thought of swapping the red with the blue to see if it changed the convergence. Any help would be apreciated.
Thank you in advance.
Walley
46" HD1080 TV. The screen will bend on the top and bottom when first turned on like a bowtie. After 10 to 30 minutes it goes back to normal and is fine the rest of the day. Going to call a service tech but would like to know what it might be. Thank You
I have a 65" Mitsubishi HDTV. Recently, I noticed that sometimes the picture appears to be curved and the text appears to be in multiple colors and curved towards the bottom. Some times the problem appears and sometimes it disappears. Any idea? By the way, this TV is only 2 years old.
Post Number: 925
It sounds as if your convergence is off. You might want to refer to your owners manual to fix it. If you cant figure it out yourself, have a tech come out, and he'll do it for you.
I have a 55" Mitsubishi TV VS-55707, about 7 yrs old. Never had problem w/ it until i tried to turn it on this week. When I pressed ON, little light on panel turns green, and TV clicks (green light goes off). The screen never turns on or flickers. Can anyone help? Thanks.
Username: Gegi63
Georgetown, Georgia
Quitman
i have a mitsubishi CS-27205 1997 but i have no manual for it plus it is Spanish it is asking for a code but i dont have any codes it is a 4 didg code can you help me
I have a VS414R model big screen tv and when I turn it on it usaully goes black with the sound still going and when it does turn on there is a moving black area on the left side of the screen and the top has a jumbled area, while the right has the 3 colors HELP!
model vs5044 power problem: while watching a dvd it stopped and tv turned gree i shut it off and pressed pwr butt. green pwr lite came on and went off i pulled all lines from the outlet for 1/2 hr thentried agai same thing green pwr lit on and then off
Paul: Thanks for your sugesstions to check convergence of my 65" Mitsubishi HDTV. I tried "Factory Default Setting". Even after the result came back as "Convergence Complete" nothing changed much. Lines at the top and bottom still remains same. I noticed that sometimes the picture appears to be curved and the text appears to be in multiple colors and curved towards the bottom. Some times the problem appears and sometimes it disappears. Any other sugesstions. Thanks.
Username: Bhumi44
Ahmedabad, Gujarat
India
Post Number: 13
I HAVE 1,60,000 SERVICE MANUALS FOR ALL ELECTRONICS COMPONENTS AND EQUIPMENTS INCLUDES SCHEMATIC DIAGRAMS, PCB
LAYOUT, FAULT FINDING, PARTS LIST, VOLTAGE SENSOR IN ABOVE 960 CDS !!!Post by spammer - Please send e-mial me:
info@bhumitapes.com
bhumi44@rediffmail.com
regards
kirit shah
I have a mitsubishi ws65313 projection tv that will not turn on, no pic or sound. Clicks when power button is hit and 3 seconds later clicks off. Tv is hardly used. Any common problems or suggestions. Nothing visually wrong internally.
i have 29"mitsubishi TV made in UK (MITSUBISHI ELECTRIC COMPANY)But unfortunetely one day when i turn on it show some light beam on the screen and i fail to see the pcture , so this problem where it come from and how to solve it? i need its Manual.I buy without it as a 2nd hand
Post Number: 969
TVs dont last forever. Maybe your TV is finished. If it's worth it to you to have it looked at by a trained tech for $75, then by all means do so.
If not, pitch it in the garbage and buy a new one.
I have a Mitsubishi TV that is 10 years old. It has run perfectly until last month. I looked up the nearest service representative, called and took my TV to him. He is still holding my TV saying he can not find parts. The Model # is CS-27405. I just need to know if parts for this model are still available or if I am getting the run around.
The power light comes on when I push the on botton but after a few seconds it goes out again
susie q
My Mitsubishi CS 35401 TV seems to need the Vertical Hold adjusted. I have lost the manual and cannot find any place on the TV or in the Menu to try to adjust the picture's Vertical Hold. The TV was built in July 1993. Can this be adjusted at home?
Authentic DLP4me!
GET RID OF IT!
TOO OLD,AND UNLESS MITS STARTS MAKING A LCD PROJECTION,STAY AWAY FROM RAINBOWS,FAN AND COLOR WHEEL NOISE!
IT WILL ALL DRIVE YOU NUTS-IT HAS DRIVEN ME LOONY,AND I RETURNED MY DLP
Username: Dlp4me
Dallas, Texas
Authentic?
I don't think so, punk!
I have a 65" mitsubishi medallion hd1080. Every so often it loses the red color and looks more green. What could be the problem?
Username: Dlp4me
Dallas, Texas
Post Number: 11
Check your component video connections.
My bet is that they are not fully seated.
Otherwise, it's a faulty cable.
If the problem persists even after trying a different video connection method you can start freaking out. It might be the video board. I doubt it, though.
Username: Gullrion
My TV turns on and goes immediately to a bright, white line in the middle of the screen. The rest of the screen is black. It seems the electron gun is not scaning vertically properly. Is there something i can do to fix it. is it safe to try to do myself or is there stray voltage stored in the set even when its unplugged that is a unsafe to deal with.
I have another tv that keeps changing to channel 2, more frequently with time turned on.
It sounds like the high voltage has gone south.
The capacitors may be holding a previous charge.
Better leave it to the professionals.
Must be a ghost in the machine that likes channel 2.
Username: Nashphil
Murfreesboro, TN
This inquirey is for a 50" Mitsibushi VS-50609 and I am experiencing a horizonal "ribbon" line about 2/3's the way down the screen...sort of a bowtie effect. This just happened this morning for the first time. Is there a degausse feature on this set? This 2 year old set is too nice to discard. Any help would be greatly appreciated. Thanks, Phil
Post Number: 1020
Phil,
I'd call a local service contractor and have them come out and take a look at your set.
I have a Mitsubishi VS-55601 Big Screen that is about 7 years old. The sound is fine, but the picture went black yesterday. Worth having it fixed? I don't think it is HD. Thanks, Terrie
I need instruction manual for a Mitsubishi TV model VS-5052 as I don't know how to use the remote to tune it in.
Username: Jcmono
I have a HD1080 TV "65.
My TV randomly turn to black/white, but after I hit the top case of TV couple times. It turn back to color again. It only happened when I'm watching regular TV. When watching DVD, play video games all has color no problem. How can I fix it? Thank you!
I have an old Mits. Projection tv 1998. 65inch. When i turn the tv on it goes to ant a. but there is no picture or sound. then i press PIP and i see the picture, i switch it so that the pip picture becomes the full screen but when i remove the small pip window it goes back to blank. I was wondering if anyone had any idea what the problem might be and the best way to fix it. Thanks
SAOPP
I have an 8 year old 50" Mitsubishi rear projection TV. There is picture and sound but there is a GREEN tint dominating the picture. Any ideas?
I have a VS-403R Video Scan System TV which I have had for many, many years. It still projects a good clear picture, but I do not have sound. I was watching TV and a buzzing noise sounded, so I turned it off. The next day, I turned it on and no sound. I then waited a week, turned it on and the sound was back for a brief moment, then the buzzing, static sound was back. My manual doesn't show any trouble shooting for this. Can you advise or guide me to a Mitsubishi TV repair shop in Dallas, TX.
I have a CK-35304 that is 8 years old. The remote is sending out signals but the TV is not reponding. I need to re-tune the TV and add a channel. Is there any way to do this?
I have a 2002 model WS-55809 big screen t.v. Somehow the v chip got turned on and I don't have the code to turn it off. Does anyone know how to reset the code?
peyton
JOE C can you post the codes from the new t.v.'s that you have PLEASE PLEASE PLEASE
help me please
Just got a 2001 WS-55907 Diamond Series, it was my dad's. I used it for the first time after moving it and it worked great, but after about 3 days of usage, the images were and still are surrounded by red, blue, and yellow. Why would the image just suddenly do that? I tried to align the colors using the factory default setting and maually, but had no luck. What do I need to do?
Username: Joe_c
Oakwood, Ga
Post Number: 404
try a convergence reset and go from there if that doesn't work either call a service man(suggested considering that tv is awesome and shouldn't be f'd with) or go into the service menu and tweak settings.
peyton, try : menu, 2,1,5,7
or menu, 2, 1, 5, 9
if those don't work then try this link : http://www.keohi.com/keohihdtv/brandspecific/mitsubishi/mitsu_servicecodes.html
Hey i have the same exact problem you posted about the vs-45502 turning itself off in 3 seconds if you got this problem repaired please tell me how much it cost, or was it too much to repair (ie repair cost more than tv, do you have an owners guide
Username: Madbc
Fairfield, OH
NEED HELP! Bought (used) a VS-4562.. moved it. WHen it's connected to the cable, we at first got a green rolling screen; now we have nothing but sound. ANy suggestions would be GREATLY appreciated!!!
Username: Joe_c
Oakwood, Ga
Post Number: 449
Sounds like something a service man needs to look at. Plan on spending a couple hundred at least to fix it.
Username: Madbc
Fairfield, OH
Hi joseph I see alot of your posts on here and obviously you know alot about TVs.. Can you tell me what year this TV is? Also, does the convergence need to be set by the serviceman? On the newer TVs you can enter the codes through the remote right?
Top of page
