Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Dreambox 7020 Scart Adapter?
Author Thread: Dreambox 7020 Scart Adapter?
Hi,
I was just wondering if you need a scart adapter for dreambox 7020 to work in north america? Can I use the regular RCA?
Username: Maple_leaf
Post Number: 837
Yes you can. the scart is just for adding more outputs.
my2cents
scart adapter is for HDTV output.
so you do not have to buy a separate scart adapter in order to get the dreambox set up and working? hdtv? I thought no receiver supported hdtv yet
Post Number: 838
They don't just simmulated. Helps picture work better on HDTV's
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Dreambox 7020 Scart Adapter? [ « Previous ] [ Next » ]
