Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Installing Directv HD in a Newly Buil...
Author Thread: Installing Directv HD in a Newly Built Home Question
Username: Nachoman91
Cincinnati, OH
Post Number: 20
Directv installation questions. I am building a new house and would like to install the system myself. I am installing an Oval HD Directv triple line dish.
1. Upon inspection of my current dish I notice it has 4 coax connections but only 2 of the connections are being used, meaning 2 coax lines are connected. Why is that? Can I use all 4 connection points?
2. If I’m installing 4 TV’s in the house can I split both lines coming from my dish to 4 way splitters each?
3. If each line is goes through a 4 way splitter will I be able to watch different programming on all 4 TV’s at the same time.
4. How much signal degradation will I lose from splitting the lines? Is there a signal booster I can buy to help this if it’s a problem or won’t it be a problem?
Sorry for the stupid questions but I’m a novice that this.
grimreeper
1 the lnb is set up for 4 recievers
2youll need 4 reivers or youll have to split the signal coming out of your recievers and watch the same thing on 2 tvs from one reciever and the same thing on 2 fron the other
3 4 way splitter wont work
4 if you split the lines coming out of the reciever and run to 2 differant tvs youll see little to no loss.
your best bet is a reciever for each tv.
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Installing Directv HD in a Newly Buil... [ « Previous ] [ Next » ]
