Samsung dlp "not supported mode"
we bought a 50" samsung dlp tv and have been using normal cable through comcast. we just got HD installed today, but all we get is "not supported mode" on component 2 and 3. the guy says the box is 1080i so it should work fine since those inputs take that. i dont get the "searchign for signal" so its definitley the tv. any ideas?
palmsterr
i figured out the problem by calling samsung. i plugged it into the component 1 and then got to change the signal output of hte box. it works. is it possible to make it widescreen though? i can only do normal and wide.
Username: Emkmd
Post Number: 50
Those are the only viewing modes that are selectable with HD. .
-E
