Thread: CHANNEL LIST ?? |
New member Username: Lance_barr
Post Number: 7 Registered: Apr-05
| Posted on Wednesday, September 21, 2005 - 05:39 pm: |
ANYONE WIT A CHANNEL LIST FOR 2500A?? ::110,119, AND 61.5:: |
Post Number: 8 Registered: Apr-05
| Posted on Wednesday, September 21, 2005 - 05:42 pm: |
ONE THAT MATCHES DISHNET'S ONE |
| Posted on Wednesday, September 21, 2005 - 07:16 pm: |
Hello, find chanel master, then if you don't have the list, you can do a blind scan, after it is done,from the receiver downloaded to pc and with chanel master you can make your own. If this doesn't help, let me know and I will send you a list. |
Post Number: 9 Registered: Apr-05
| Posted on Wednesday, September 21, 2005 - 08:41 pm: |
well i have channel master.. i was juss lookin to see if anyone had theres set like dishnet's one, b/c i had mine set to that, then when i updated to nag2, i had forgot to save my list... so please if anyone has a list juss like dishnets lineup(including int'l 61.5) please send one .. .thank you |
Channel Master Lists Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 09:43 pm: |
dude go to any site except this one... al7bar. tc al7bar. tk futuefta.com- they all have channel lists, where did you get channel master? if you found that then find a channel list but don't ask here cuz nobody posts files here,they just post where to get files. |
