Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Which fta reciever is best?
Author Thread: Which fta reciever is best?
ftanewbie
i'm new to this fta reciever thing.
can someone give me some advice on which one to get.
pansat 2700a or
dreambox dm500 or
coolsxt 4000pro or
cooltec pro
COOLSAT4SHO
coolsatpro or dreambox
go4theDream
i go for dreambox, because it has SCART adapter for components output, an excellent picture quality for HDTV.
ftanewbie
will i be able to update dreambox with window xp since dreambox is linux
Username: Max5wm
Post Number: 14
If you are new, go with the C00LSAT Pro. The Dreambox is way too complicated to setup. It will take you many, many hours whereas you can setup up a C00LSAT in less than 15 minutes. Dreambox is a high performance machine, but not without its headaches. And its performance does not justify the many more hours of setup and all of the extra tools for updating. A Pansat has too many problems and a Cooltec is a clone which you should stay away from.
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Which fta reciever is best? [ « Previous ] [ Next » ]
