Thread: Unzipping Nagra 2 Bins ( .stb files ) |
techno dude Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 01:46 pm: |
Somebody please explain how to open the zip files once they're downloaded from those file sites and before you load them into your FTA. What viewer do you use? |
Nobody listens to techno Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 02:09 pm: |
Winzip or Winace should work both are free to download just do a google search for them |
Mervin S. Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 05:00 pm: |
hello guys. Do you have to unzip the bin before flashing it to the fta?????? |
uploader t Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 06:38 pm: |
hello, you dont view the files, you download them from the updater. do not try to "open" them, just have them in the "unzipped" state, find where it is on your computer, thru you updater program, then choose it, and download on your receiver, t |
Bronze Member Username: Dallas4lr
Post Number: 15 Registered: Sep-05
| Posted on Wednesday, September 21, 2005 - 06:44 pm: |
Don't listin to him!!!! He's full of crap!!! Download zip file to your disk top. Creat a new folder run winzip and place unziped files in this new folder. Now to update your reciever you will need either the blacklist uploader, fortec uploader, or the STB uploader to flash you unit with this new file. Dallas |
Post Number: 16 Registered: Sep-05
| Posted on Wednesday, September 21, 2005 - 06:45 pm: |
Don't listen to him!!!! He's full of crap!!! Download zip file to your desk top. Create a new folder run winzip and place unziped files in this new folder. Now to update your reciever you will need either the blacklist uploader, fortec uploader, or the STB uploader to flash you unit with this new file. Dallas |
| Posted on Wednesday, September 21, 2005 - 06:50 pm: |
Heard a rumour that the P4 card has been hacked. Any truth to it? |
lostwithout-tv Unregistered guest |
| Posted on Thursday, September 22, 2005 - 01:00 am: |
I really hope so....I miss my direct tv |
