Thread: Hooking up 2 tv's to one receiver |
Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 01:25 pm: |
The sat guy told me how to hook my second tv up to my receiver, but I can't remember all he said. Please help |
Smith Carol Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 02:18 pm: |
Both TVs would be on the same channel. Just split the signal that comes out of the receiver going to your tv. It will only work with co-axial or RCA not S-video. |
Bronze Member Username: Max5wm
Post Number: 16 Registered: Jun-05
| Posted on Wednesday, September 21, 2005 - 03:04 pm: |
Or you can use the Loop Out in the back of a C00LSAT Pro. |
New member Username: Chico
Post Number: 6 Registered: Sep-05
| Posted on Wednesday, September 21, 2005 - 06:57 pm: |
max power can another receiver be connected to the loop out in the back of the coo*sat 4000 pro. will this allow me to watch different channel from the other receiver. |
| Posted on Wednesday, September 21, 2005 - 08:41 pm: |
chico you can use the loop out with another receiver. But if you have both on at the same time the first receiver turned on takes control of the disqe switch. So if the first receiver turned on was on 110 the other receiver can only watch 110. If you wanted to watch something on 119 the first receiver would have to be changed to something on 119. |
Post Number: 7 Registered: Sep-05
| Posted on Wednesday, September 21, 2005 - 09:58 pm: |
anonymous thank you |
