Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Pansat 3500s not OK
Author Thread: Pansat 3500s not OK
nangaufa123
I replaced my old fake burned receiver for an original 3500s but I can see only a couples of HBOs ans Showtimes etcc, no more , I got signals in each channel but it says scrambler signal, Why I can open all of them ?
Thanks, need help
bin filer
try loading new keys, after these new bin files.
Username: Nangaufa123
Miami, Fla
Bin Filer, I need your help on this , I did a lot of thing to make this work ,but still nothing, I flashed, installed new bin, new channel table and still nothing , I changed the keys but the receiver start to downloading data and get back to the same state, do you have any working Key that I can test?
Thanks A lot.
edo
does the program guide work on the pansat 3500s
Nan-Gua-Fa
Nanguafa are you sure you have the newest bin? My 3500 is fine using:
X-05BL_050914_114eubx_api ecm 09-13-05 fix.bin
Miami, Fla
The program guide work perfect also with the titles of the movies, can somebody send me that bin just in case please, but the one that I have was downloaded from dsscentral.
riquilawton@yahoo.com
Thanks you all
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Pansat 3500s not OK [ « Previous ] [ Next » ]
