Thread: Record on DVD from cable |
New member Username: Saruzza
Post Number: 1 Registered: Sep-05
| Posted on Tuesday, September 20, 2005 - 06:32 pm: |
Hey guys, I'm new here and also I'm new in the USA so I don't know very well your cable system. Anyway... I'd connect my DVD recorder (ILO DVDR04) to the TV but I can record only the first 13 channels, I think it's the 'regular' TV. What if I wanna record something from the other channels?!?!?!?!?!?!? Please help me because I can't find a solution and need to tape Extreme Dodgeball next week PLEASEEEEEEEEEEEEE |
Gold Member Username: Samijubal
Post Number: 1648 Registered: Jul-04
| Posted on Tuesday, September 20, 2005 - 08:38 pm: |
If you aren't using a cable box, go into the DVD set up menus and set the antenna/cable select to cable, then autoprogram the channels. |
| Posted on Tuesday, September 20, 2005 - 09:43 pm: |
I have the cable box... there is some kind of scheme to see how everything as to be connected and hopefully work?!?! |
New member Username: Gi58
Florida
Post Number: 3 Registered: Sep-05
| Posted on Thursday, September 22, 2005 - 02:38 pm: |
If you have a cable box, you'll need the 'cable mouse' that most DVD recorders use to change channels on the box. You may need to use the line input (S-Video or composite) on your recorder to receive the signal from the cable box, rather than the RF cable. Check your recorder's manual for specific advice about the connections and the set-up. (Be aware that some brands of cable box may not 'play nicely' with your recorder.) Hope this helps.
Post Number: 2 Registered: Sep-05
| Posted on Thursday, September 22, 2005 - 04:02 pm: |
thanks man!!!! Hope it will work. I was looking on amazon.com for a 'cable mouse' but can't find anything.. just mouse for the computer... there is another name for it? Sorry but I'm from Italy and not really good with this kind of stuff. thank you |
| Posted on Monday, September 26, 2005 - 05:19 pm: |
IR Blaster, never heard it called a cable mouse either Sara. Also your DVD recorder cannot accept a digital input only analog signals. Since you have a cable box (aka STB) use either an RCA cable connection (normally a single yellow cable) or an S-Video cable to connect to your DVD recorder. Only analog signals pass on these connections so whatever channel you are viewing on your STB will be recordable on your DVD recorder. It seems like you are currently running a coax cable connection to your recorder and this is why it is only recognizing the first 13 (analog only) channels. xvxvxvx |
