Thread: Copy hdd to dvd on LG RH7500 |
Merlina Unregistered guest |
| Posted on Tuesday, September 20, 2005 - 05:14 am: |
Hi. Please can anyone help? I have 6 hours worth of recording (a single recording) on the HDD and I need to copy 20 minutes worth from the middle of the recording onto a dvd. Can anyone please tell me the easiest and quickest way of doing this as the manual is fairly useless. Thanks |
www.svsweddings.co.uk Unregistered guest |
| Posted on Friday, September 23, 2005 - 04:04 pm: |
See page 51 of the manual. First divide the clip from the start till the beginning of the 20mins you want, then you will have 2 clips, go to the 2nd one (which has your bit on it) and divide that from the end of your 20 mins. you will now have made 3 clips from the one, with your 20mins as one of them clips, then dub that clip to the DVD, clear as mud? |
| Posted on Monday, October 03, 2005 - 06:58 am: |
Thanks for that. I presumed it had something to do with all this dividing stuff, but was hoping I had overlooked a far simpler way. Cheers. |
