Home > Message Board > Home Video > DVD Recorders > Archive through November 29, 2005 > What is the easiest dvd recorder to r...
Author Thread: What is the easiest dvd recorder to remove macrovision from
reboot
i am going to purchase another dvd recorder soon and was wondering what is the easiest dvd recorder to remove macrovision from.
Username: Dmwiley
Post Number: 1106
Not sure that it matters when the DVD is copy protected. I know of no consumer DVD recorders that internally remove the protection.
Username: Samijubal
Post Number: 1650
The older Lite On recorders were easily hacked, I don't know about the new ones.
Username: Gi58
Florida
Post Number: 9
You might go visit http://www.codefreedvd.com. I believe they sell a recorder that is both region- and Macrovision-free.
Username: Dovehill
Marshall, TX
Most all Lite On recorders can be hacked to make region free (RPC1) and remove the microvision on their DVD burners. Unless the internal software prevents you, this is quickly done using a simple program from CDFreaks.com (LTNRPC.EXE)and your PC. You will have to remove the top cover from your unit to access the burner. You would then connect the burner to your PC as Master Slave.
I've used it many times and it works.
Home > Message Board > Home Video > DVD Recorders > Archive through November 29, 2005 > What is the easiest dvd recorder to r... [ « Previous ] [ Next » ]
