Thread: Still Freezing |
Robotic$ Unregistered guest |
| Posted on Sunday, September 18, 2005 - 02:18 pm: |
Downed the new 281 bin, I get all the channels but some freeze up, go black and then come back. Is yhere something that can be done to fix that, or is that just the way it goes? |
Don Stemeicky Unregistered guest |
| Posted on Sunday, September 18, 2005 - 02:51 pm: |
I have same prob.can sombody help |
Bronze Member Username: Jdq
Post Number: 78 Registered: Apr-05
| Posted on Sunday, September 18, 2005 - 03:04 pm: |
Maybe you need a heatsink on your chip lotta receiver chips get hot with new files ,I ADDED ONE TO MY DGIWAVE AND NO MORE FREEZING |
memememem Unregistered guest |
| Posted on Sunday, September 18, 2005 - 03:39 pm: |
Your digiwave has sw fix for longer video packets, ultra does not.
d.ollzar Unregistered guest |
| Posted on Sunday, September 18, 2005 - 05:54 pm: |
memememem, can something be done for the ultra? |
D. Ollzar Unregistered guest |
| Posted on Sunday, September 18, 2005 - 05:56 pm: |
memememem, or anyone can something be done for the ultra because I have the same freeze problems? |
