Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Blacklist uploader will not let my ul...
Author Thread: Blacklist uploader will not let my ultra use fortec stb 3.1
bombats
downloaded Ultra281_patched_09-13-05_ECM with Blacklist STB UPDATER 1.3 last week now i am trying to download Al7bar FTA Ultra_050909_281_apiNTSC with the Fortecstar STB updater 3.31 and the 3.31 will not respond or download anymore....what am i dto do...thanks
use the blacklist loader
Username: Xpehbam
Greensboro, NC
Hi bombats! Where did you find this... Al7bar FTA Ultra_050909_281_apiNTSC..This is NEW ??
bombats
i did use the blacklist loader but i am getting lots of glitching and want to try this new file but can't get it to work with the blacklist or the fortec stb3.31
Username: Xpehbam
Greensboro, NC
I think this is not a bin file..you need to try load in fortec stb3.31 like Flash rom file.
bombats
where do i get the flash rom file....chinese to me
Username: Xpehbam
Greensboro, NC
When you open fortec stb3.31 you will see 4 files type...select second (FLASH ROM FILE)
DVB MAN
WWW.PANTECDVB.COM
IT HAS THE BLACKLIST UPDATER 1.4,
AND ALL NEW FILES, AND TELLS THE OLD ONES DON'T WORK AND WAITS FOR NEW ONES.
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2005 > Blacklist uploader will not let my ul... [ « Previous ] [ Next » ]
