Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Bush DVRH501, help needed,
Author Thread: Bush DVRH501, help needed,
I got a Bush DVRH501 dvd recorder/vhs combo last November from Argos. It has now died, Argos offered replacement/refund I took the refund after trying various models in-store (Bush has changed to +r/rw format since I bought). Here is my problem: I have a collection of around 40-50 DVD -r disks on which I was compiling on-going music collections of various artists. I have now been left with these disks which I can not finalise or even play on any other machine. Any suggestions or solutions would be gratefully received
Username: Samijubal
Post Number: 1629
If you have a burner in a PC, DVD Decrypter has a finalize option, I don't know if it will work on standalone recorded discs though. It's called syncronize cache in Decrypter.
Thanks David, I downloaded DVD Decrypter but it did not allow any use of the -r, I will try the DVDD forums. Thanks again for your help.
Eric.
Home > Message Board > Home Video > DVD Recorders > Archive through October 04, 2005 > Bush DVRH501, help needed, [ « Previous ] [ Next » ]
